Old 07-01-2022, 10:43 AM   #4201
Racecomp Engineering
I know that WRC tarmac rally cars were mostly running spring frequencies lower than 2 Hz, at least in the early-mid 2000s. I think some right around there but most were softer. That was with shocks a couple steps above anything we're talking about here and also sticky tires. Current/recent Group N cars (again with extremely good shocks) are around 2 Hz on tarmac. Meaning...you should probably be aiming a little lower than that.
2 Hz for a BRZ front suspension is around 6 kg/mm springs.
Suspension travel is also very important on these types of roads...we really liked our Ohlins in terms of valving but wanted more travel. If you're going to run relatively soft springs it becomes even more important.
- Andrew
Old 07-01-2022, 04:14 PM   #4202
marco_mc22
Drives: Toyota 86
- Andrew
How about frequency bias on tarmac?
marco_mc22 is offline   Reply With Quote
Old 07-02-2022, 10:46 AM   #4203
Generally less rear biased on tarmac than it is on gravel...but dependent on car, driver, and team.
- Andrew
Old 07-07-2022, 01:59 AM   #4204
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
Does anyone have any experience regarding tein endura pro plus shocks and how do they compre to bilstein b6/b8?
Lucky21 is offline   Reply With Quote
Old 07-17-2022, 07:04 PM   #4205
bradsm87
Drives: It has 4 wheels
Do you guys know of any good coilovers that have at least 115mm total stroke both front and rear? Not just ones intended for rally but rather ones that can still go low and just have lots of extension travel. Obviously helper springs would be needed to make it work.
I'd really like suspension that works well driving hard on bad roads and also to keep all tyres on the ground when entering driveways on an angle.
bradsm87 is offline   Reply With Quote
Old 07-18-2022, 08:56 AM   #4206
Our RCE coilovers (and most KW coilovers) have 142mm total shock travel up front and 108mm in the rear. With the motion ratio that rear is about the same 142mm wheel travel as the front. Bumpstops take up part of that travel.
- Andrew
Old 07-18-2022, 01:45 PM   #4207
marco_mc22
Drives: Toyota 86
- Andrew
Do you know bump to droop ratio relative to let’s say 20mm of lowering? Assuming stock mounts and rear arms used of course.
Old 07-18-2022, 02:48 PM   #4208
Roughly 60/40 bump to droop.
- Andrew
Old 07-18-2022, 04:33 PM   #4209
marco_mc22
Drives: Toyota 86
Just out of curiosity, does your Tarmac 3 based on 3 ways CS has different numbers due to their hybrid construction? If I’m not wrong they’re monotube on bump side and twin tube on the droop one? Also, their lowering top hats should shift everything allowing lowered heights keeping the same ratio right?
Old 07-18-2022, 05:07 PM   #4210
Our Tarmac 3s are unfortunately no longer available right now.
Yes lowering top mounts would shift the bump/droop ratio towards bump a little more at the same ride height.
- Andrew
Old 07-19-2022, 12:44 AM   #4211
bradsm87
- Andrew
That's great. HKS Hipermax S only have 87mm front stroke and 106mm rear stroke according to their spec page. I feel this would be annoying on bad roads and angled driveway entries.
Old 07-19-2022, 09:02 AM   #4212
That would not work for me either.
- Andrew
Old 07-20-2022, 09:46 AM   #4213
Tatsu333
Drives: 2020 BRZ Sport Tech RS
- Andrew
I'm trying to get my head around why the KW/ST coilovers (and presumably the RCE SS1's, though I don't know that for sure) that use the front lowering camber plates have shorter main spring free lengths in the front (170mm vs. 200mm) than those that don't. It seems counterintuitive to me.
If it were just a matter of limiting bump travel, that could be addressed with having the spec for the minimum lower perch position being changed a corresponding amount to match the change in upper perch height, no?
Thinking about it some more while typing this, I suspect it may have something to do with keeping the extension / droop travel of the dampers within range for a given ride height, but that only makes sense if those top mounts result in the damping rod being more extended at rest vs. the stock top mounts for a given ride height, and I can't imagine it would be a 30mm difference (though that magnitude of change in spring length is likely "just because" that's the next shorter step they produce).
Am I on the right track here, or do you have any other input / explanation / theory for why the shorter springs would be used in this application?
Tatsu333 is offline   Reply With Quote
Old 07-20-2022, 01:57 PM   #4214
marco_mc22
Drives: Toyota 86
They're stiffer, less sag under weight keeping the same preload.
They also use weaker helpers up front, 3-60-80 instead of 10-60-80, basically 3nm vs 10nm, well, I've never understood why honestly...hopefully Andrew will enlighten us ahah
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
