Old 08-22-2014, 07:18 PM   #407
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
Originally Posted by cnk View Post
Finally gave in and ordered a Tomei EL from @ft86speedfactory. Should hopefully get it next week. It will be paired with a resonated Perrin header-back 2.5" exhaust with high-flow cat.
Please post a sound clip...that is what I would like as my set up, just want to make sure its not to loud.
kurbkilla is offline   Reply With Quote
Old 08-22-2014, 08:09 PM   #408
Beeboo4life
Drives:
Sorry in advance if this is a noob question. I'm new to all this.
I have the Nameless axle back exhaust and frontpipe/overpipe high flow catalytic converter. I was on FRSport website about to purchase the Tomei UEL header and on the description it said "Note: removes catalytic converter." Will I be able to install it without a problem or do I have to get it remove.
Beeboo4life is offline   Reply With Quote
Old 08-22-2014, 08:16 PM   #409
steezypenguin
steezypenguin's Avatar
Drives: SWP BRZ
Tomei EL and UEL Headers Teaser!
There are two catalytic converters in our cars. One in the front pipe, the primary catalytic converter is in the header. The tomei header will remove the cat located in the header since the tomei header is catless. (Does not contain any catalytic converter) You will still be able to maintain your catalytic converter in the front pipe! Although I highly suggest you get your car tuned after the header install for maximum power gains and to avoid any potential check engine lights that may pop up from removing the primary cat in the header.
steezypenguin is offline   Reply With Quote
Old 08-23-2014, 02:28 PM   #410
monkeyslide17
monkeyslide17's Avatar
Drives: frs
Just got my tracking number, Will be here Wednesday. I don't have time to get Friends car with Tomei to try and make vid.
monkeyslide17 is offline   Reply With Quote
Old 08-23-2014, 02:34 PM   #411
Killianti
Killianti's Avatar
Drives: 2013 WRB BRZ 6MT
I replaced my catback with the Invidia Q300, and I can say that a catless setup can be quiet. Tomei EL, Tomei overpipe, Tomei frontpipe, Invidia Q300.
Killianti is offline   Reply With Quote
Old 08-23-2014, 04:24 PM   #412
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Dihudaxia View Post
Here is the dyno charts for you guys to make some comparisons, my setup is as follows:
-Tomei UEL header
-Greddy CS Ver2 CBE
-Apexi Drop In Air Intake
-Crawford BPB
-Stock everything else
<Note>: I reside in south east Asia where the weather is perennially hot & humid so the absolute numbers will no way match up to the numbers seen in America or Canada dynos.
Run (1) & Run (2) are done on different days, but on the same dyno.
Run (1) was a cool rainy day, Run (2) was a hot & humid day.
(1) Stock Map with CBE, BPB & Drop In Air Intake
(2) Before and after Tune – UEL, CBE, BPB & Drop In Air Intake
My apologies, i have no stock car map run as i did my dyno run only after i installed all the mods (less header)
In a nutshell, the Tomei UEL performs as what Tomei USA states on their website. No surprises.
Torque dip is almost flat, high-end gains are minimal without a tune. You need to compare graph 1 to graph 2 to see that.
After the tune, the header’s performance gets way better, gains before and after tune is pretty decent. But that is probably down to tuning rather than anything else.
As for the UEL noise, I have heard a JDL setup and compared to this, Tomei is, IMHO, more UEL. The boxer note really shines thru and leaves no one in doubt of the boxer-ness of the exhaust note. But….
The noise is LOUD, make no mistake, it’s not a subtle gentleman’s racer kinda loud, it’s a bellowing thrumming constant blaring loud. But of course, your tastes and mine may differ. You might like it.
If i got the time, i will get a video of the exterior and interior sound. Meanwhile, hope this will do.
This is actually quite a bit more impressive than what Tomei advertise. You yielded a +20hps over baseline while Tomei advertises a +6ps over their baseline. That is a huge difference.
Old 08-23-2014, 04:25 PM   #413
Aerok
It's Korea backwards.
Aerok's Avatar
Drives: 2014 FR-S Whiteout
I will make a vid tomorrow and post it.
Tomei UEL, Berk muffler delete, OFT Stage 2 UEL tune.
Aerok is offline   Reply With Quote
Old 08-23-2014, 08:27 PM   #414
Aerok
Aerok's Avatar
[ame]http://youtu.be/PEhhxIh2qBM[/ame]
Sorry for the quality. Taken with my cellphone. I drove the car about an hour before so it's not really a cold start.
Old 08-24-2014, 02:42 AM   #415
Dihudaxia
Drives: 86
That one is after the tune (20hp gain). Before the tune, it only gave 2/3 hp more.
Dihudaxia is offline   Reply With Quote
Old 08-24-2014, 08:43 AM   #416
Aidos
Aidos's Avatar
Drives: Orange GT86
Here ya go. Tomei EL + Perrin OP + Catless FP + Kakimoto GT0.1z Catback
[ame]http://youtu.be/1pbxNRYHQ08[/ame]
Aidos is offline   Reply With Quote
Old 08-25-2014, 02:19 PM   #417
br@ndon
br@ndon's Avatar
Drives: 2014 Monogram FR-S
Did anyone else get a CEL for the UEL headers? Mine just went on....
br@ndon is offline   Reply With Quote
Old 08-25-2014, 02:36 PM   #418
CSG David
CSG David's Avatar
That's a very standard occurrence when your cat gets deleted from the system. There's a O2 simulator you can use, but it's never guaranteed. The best way to go is to get a tune to maximize the gains and take out that CEL.
Old 08-25-2014, 02:45 PM   #419
FR-S Matt
People still buy headers without a tune? That's some expensive noise.
Old 08-25-2014, 02:46 PM   #420
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by Aerok View Post
More like you and James installed it for me. lol
Yeah a Berk muffler delete with a UEL header is loud. Driving to work this morning was an adventure. I think I redlined it on every shift.
Honestly though I'm pretty sure I'm going to have to remove the Berk to daily drive this car now.
Can you get an audio clip? I'd really appreciate it. Picking up a used Berk single exit muffler delete from a local guy this week, and strongly considering buying the Tomei EL as a Christmas present to myself. I'd really like to hear how the setup sounds.
Are those the only mods you've done to the exhaust system? (i.e. no catless front pipe or anything)
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Tomei headers + overpipe coming! diss7 Engine, Exhaust, Transmission 64 07-06-2014 09:28 AM
Tomei Type 60R trade for Tomei Type 80? Krovi Engine, Exhaust, Bolt-Ons 5 06-11-2014 07:24 PM
Tomei 80r & VDS UEL Headers Clip Bl1tzkr1eg Engine, Exhaust, Transmission 15 03-10-2014 06:13 AM
Tomei Exhaust with Tomei Straight Pipe leech Engine, Exhaust, Transmission 10 01-07-2014 10:42 AM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 09:51 PM
