#407 | |
Again, different oils for different uses. The CS-Cup is the same engine we have. They just specify the oil needed for the task at hand, racing. Not daily driving, not track days, not time attacks, not autox. I can guaranty they didn't specify 10W-60 with the goal of destroying the engine as fast as possible. If I recall the GT86 manual in Japan also lists optional oils depending on use. Same engine, same tolerances. |
#408 | |
Anti stance.
You can even have tolerances on your allowances/clearances. Last edited by Tokay444; 12-22-2020 at 12:40 PM. |
#409 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Without starting a pissing match (hopefully) I'd like to ask a favor. Lots of folks toss around the term "tolerances" when discussing oils and such. Like, we need to use thinner oils because of tighter tolerances. What you're talking about are "clearances." The distances between rod bearings and their respective journals on the crankshaft are clearances. You measure them with plastigage. The allowable variation in the sizes of machined parts and the resulting differences in the clearances in various iterations of assemblies are the "tolerances." If you tolerate poor machining and widely varying measurements/clearances you have loose "tolerances." If the dimensions/clearances are held within very small fractions of each other you have tight "tolerances."
This is NOT grammarnazism - the concepts are different and it matters!! Please guys - you can do this.
Slow is smooth, and smooth is fast
#410 |
Anti stance.
Words have meanings.
#411 | |
Drives: 2013 FR-S Argento
Yup, apologies, incorrect usage of words, I should get my shit together with terminology. Clearance is concept I am addressing. And Tokay444 excellent point on "tolerance" != "allowance". All that said, my poor wording aside, I still stand by the fact that engine design/clearances are a major factor in determining what oil you should use, and there can be repercussions from using 50 or 60w oil in a motor with tight clearances designed for lighter weight oils. The counter arguments here seem to claim the only negative impact would be to fuel economy. There's plenty of reading out there from reputable sources supporting it's not quite that simple. |
#412 |
Anti stance.
I run 0w40 year round, and at many track days in the summer.
I have no issues getting the oil above 100 degrees Celsius in the winter, and no issues with oil over heating over multiple 30 minute track sessions on even the hottest summer days. I have over 140,000 trouble free high revving kms with the 0w40 going in at 1000kms on the ODO. UOAs routinely suggest I could double my 8000km oil change interval, but for the cost oil 5.4 litres and a factory filter every 8000, it's cheap piece of mind. Fuel economy has never been a number that has entered into any personal equation. Engine longevity was my primary concern when making the switch. |
#413 |
FR-S manual:
![]() GT86 manual: ![]() The US manual says 5W-30 is fine in a crunch but you better get it back to 0W-20 ASAP while the Euro/Asian manual says either 0W-20 or 5W-30 are fine. Same engine, same tolerances. Different countries, different environmental requirements. |
#414 |
Anti stance.
And here's the Japanese manual, for the same car. Same engine. Same clearances.
#415 |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Does anyone think comparing the oil and engine in the race car to our cars is a bit of a stretch. I mean no race team plans on keeping the engine running in tip top shape for over 100k miles. A race team will tear it down in the off season or maybe during the season if issues arise. That’s very different then our cars which we would like to see go forever. Plus the teams do a lot more testing related to the oil and what’s needed. The balance they need is different than our DD.
If I were tracking I would not run 0w20, but probably not 10w60 either. Best bet is to experiment and do UOA to confirm, obviously. |
#416 |
Drives: '13 Whiteout
I run an IAG Stage 1 short block with an oil cooler and their warranty states Motul 0-20 synthetic must be used to keep their warranty intact
#417 | |
Drives: Crapcan
#418 |
Drives: '06 AM V8V Coupe
#419 |
Meow
Drives: Focus ST mk4
What's the US recommended interval for oil changes on this car?
#420 |
Drives: Crapcan
Yes, running an oil cooler. If you look in the UOA thread there are others who have posted similar recommendations from blackstone. I remember one of them being boosted.
| Tags |
| brz, cayman, s2000 |
| 2013 981 Cayman | ironchef | Other Vehicles & General Automotive Discussions | 49 | 12-09-2012 07:03 PM |
| FR-S vs Cayman | colganc | FR-S / BRZ vs.... | 102 | 09-13-2012 04:17 PM |
| GT86 vs. 370 vs. Cayman S | wrxgoose | FR-S / BRZ vs.... | 0 | 08-27-2012 11:26 PM |
| FRS/brz VS Porsche Cayman | jurjurson | FR-S / BRZ vs.... | 22 | 08-15-2012 04:14 PM |
| FR-S, Cayman S, & Lexus GS | Mcdj18 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 06-23-2012 04:49 PM |
