#407 |
Get the mtec springs man. Much much better feel. Not like buttery smooth but 100x better than without it. Worth the $40 for sure. Noticeably quicker shifting. I also had a cat less mispipe and a few trans mounts installed same time but yeah the shifting feels hella better. I'd go for it.
#408 |
Drives: 2013 Red FRS
I feel like mine significantly loosened up. I've retightened it twice now. It always feels good for the first drive then slowly loosens. I havent tried locktite or anything yet, but i think i am headed that way.
#409 |
When you say loose are you talking about when it's in a gear and still can be moved around?
#410 |
I wanna go fast
Drives: 2013 FR-S 6MT
Mine seems to be loosening up a little bit too, in a good way. I just wish it was a little less notchy. I will have to get some of those springs @Jake_86 and see if it helps.
#411 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
So I've been driving with mine for around 5k miles.
Question to you guys. My shifter seems to have a bit of slack when in gear. It won't move up or down, but will wiggle to the left and right. Is this normal? I've tightened it but that still happens.
#412 |
Drives: 2013 FRS
Is the slack gradual, or is it apparent even after you tighten the bolt?
#413 |
Gradual
#414 |
I have the same wiggle-room while in gear. When you tighten it all the shifts feel really stiff and notchy, but I kind of like that - I dont like the wiggle.
Eventually as time goes on that wiggle comes back after you tighten. |
#415 |
Drives: 2013 FRS
Unfortunately I think it's a fact of life that the shifter will get lose after awhile...
#416 |
Idk how long it takes before your wiggle returns but it's been slightly over a week and mines still tight as a virgin
#417 |
Drives: whiteout fr-s
mine has this same wiggle.. its quite frustrating for a TRD part i dont like it.. if its the nature of the beast fine i accept it. but scares me that something else will loosen up and fly out on a hard shift. anyone tried it with locktite? any results?
#418 |
Noob
Drives: FR-S Mammogram
I've had my TRD quick shifter installed for a few months now (maybe about 6 or so?) and it's still notchy and tight with no wiggle. I did have the dealer install it though, so if this becomes an issue I can always complain to them and see what they say.
#419 |
Get the MTEC springs. You'll like it I swear.
#420 |
Drives: 2013 scion FRS
| TRD Quickshifter | lovebeingbleu98 | Brakes, Suspension, Chassis | 3 | 02-13-2014 01:14 AM |
| Amazing Wax | geb2391 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 04-12-2013 05:42 PM |
| The most amazing thing I've done with my BRZ so far | azngolfur | BRZ Photos, Videos, Wallpapers, Gallery Forum | 8 | 01-09-2013 09:23 PM |
| Concept-Three-LED's DRL's are AMAZING! | soros151 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-09-2012 02:42 AM |
