Old 08-27-2015, 02:51 PM   #407
Scavanger
Avid searcher of things
Scavanger's Avatar
Drives: Scion Fr-s 10 series
on their website it says 9,999 for the fr-s but 0 for the brz.. whats the actual price of it?
Scavanger is offline   Reply With Quote
Old 08-27-2015, 02:53 PM   #408
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
According to their Facebook roughly $1000 usd.
Old 08-27-2015, 02:54 PM   #409
Scavanger
Scavanger's Avatar
I wonder if I can have the mount made to where I could also put an afr and boost gauge beside that...
Old 08-28-2015, 12:14 AM   #410
JD86
Drives: 2013 Toyota 86 GT
You don't need to. At least not for boost, according to dtm it is a boost gauge as well. It should be able to read your AFR from the factory sensor as well. I don't have a lot of details on the dtm. Only that it's a digital gauge that reads any channel from your canbus signal as well as anything the stock cluster would read. They seem to answer questions on their facebook though. What they have said to date is that it's customiseable and will have "extra features"
https://www.facebook.com/26610699357...2796048568439/
The motec on the other hand I can tell you about as that's what I'm putting in my car. However if you're complaining about the price of the DTM you won't like the motec price at all.
Mine I've got a jumper harness that makes it a plug and play replacement for the stock cluster. Just working on the housing at the moment. Ditto to the dtm it reads all the canbus channels, also does lap times off 10 htz gps sensor, g forces and has room to be upgraded with pretty much any sensor you can think of.
It works in conjunction with my ecu to read boost, oil pressure/temp, fuel pressure intake air temp, exhaust gas temp, lambda, boost/launch control/fuel/ignition control settings are all displayed and can be controlled by the display (if you have the motec ecu and are using that properly). Oh and it's a data logger as well... So it doesn't just display the channels but stores them as well for tuning purposes and race/lap analysis.
Display is fully customiseable by simple to use free software. So not just what channels it displays, but position/size/type/appearance of graphs/gauges/dials to. What's shown in mine is just one of the default settings. I'm currently putting together something similar to the LFA layout but with the channels I want for mine.
JD86 is offline   Reply With Quote
Old 08-28-2015, 12:53 AM   #411
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
This, I found it.
http://imeterdtm.com/product_info.php?i=4#
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
The Following User Says Thank You to Figo For This Useful Post:
Jive Turkey (08-31-2015)
Old 08-28-2015, 08:48 AM   #412
pepe
Drives: gt86
Give me two .... no .... best .... Give me three.
The world went crazy? $ 9,000?
pepe is offline   Reply With Quote
Old 08-28-2015, 03:40 PM   #413
Mirageo
Drives: Subaru BRZ
I'm positive that's not in USD loll
Mirageo is offline   Reply With Quote
The Following User Says Thank You to Mirageo For This Useful Post:
Figo (08-31-2015)
Old 08-28-2015, 04:05 PM   #414
pepe
Drives: gt86
Hahahahahaha
Old 08-29-2015, 05:28 AM   #415
JD86
Got to the fb link I posted and look at their estimated price. They have said scion one will be about $1000us. The $9999 is their isnt us dollars, seeing as the website is in chinese I'd guess it's Yuan, which makes it $1500 us roughly at todays exchange rates.
The Following User Says Thank You to JD86 For This Useful Post:
Figo (08-31-2015)
Old 08-29-2015, 04:21 PM   #416
pepe
Drives: gt86
OK! That is already more acceptable
Old 08-31-2015, 02:23 AM   #417
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Not a gauge pod but a cheap set of gauges. Scan Gauge "X Gauge". Mine is programed for water temp, oil temp, and auto tranny temp. Just plugs into the ECU port.
Lunatic is offline   Reply With Quote
The Following User Says Thank You to Lunatic For This Useful Post:
new2subaru (09-18-2015)
Old 09-14-2015, 10:24 PM   #418
randomthoughts
Drives: 2014 White BRZ
Originally Posted by Chad86 View Post
After finding the picture above in the BRZ, I'm not sure I like how it looks as it still covers parts of the dash displays. I might be better off going with 3 on the pillar and 2 on the blockhead as I mentioned above.
But from looking at these two pictures side by side, it seems this is an impossibility...
Okay, back to my original plan, unless anyone has any better ideas.
I wish the tanabe came in red to match the red cluster
randomthoughts is offline   Reply With Quote
Old 09-18-2015, 02:29 PM   #419
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
Originally Posted by JD86 View Post
I'll see your gauge pods and raise you the DTM iMeter.
Attachment 118884
Attachment 118885
Actually a little mad that they've finished that as I am finishing off something very similar for my Motec C127. Their mount neater than mine at this point, but mine is just a personal project. It's more motorsport based and has features to suit.
Attachment 118882
Attachment 118883
So are they selling these or not yet? It looks like their facebook post is from June, 2014. I really want this for my car!
Rookie84 is offline   Reply With Quote
Old 10-07-2015, 02:04 AM   #420
JD86
Can't help you on that one mate, sorry. Have you tried contacting them? I'm going to Sema this year so will keep an eye out for them.
But I wasn't waiting for them as I have my own solution to the problem. Test fitting prototype 3, made using a spare instrument cluster I had. Still needs a bit of a tidy up and some sheeting to close up the gaps on the side. But I'm almost there...
Name:  Motec Prototype 31.jpg
Name:  Motec Prototype 3.jpg
Rookie84 (10-07-2015)
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 06:46 PM
LHD 3-meter gauge-pod? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 27 02-11-2015 07:19 PM
Gas Gauge Issue Jruex22 Scion FR-S / Toyota 86 GT86 General Forum 12 04-04-2013 11:28 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 12:39 PM
