Old 07-04-2013, 11:54 AM   #407
supra2nv
supra2nv's Avatar
Drives: 10 Series TRD
"Nature uses only the longest threads to weave her patterns, so that each small piece of her fabric reveals the organization of the entire tapestry" Richard Feynman
I just wanna figure as much of it out as I can, figure I'm up against a clock tho, time is against me ive become an information whore...
edit: my bad, should stay on topic
[URL="http://[quote=ATL"][QUOTE=ATL[/URL] BRZ;1045171]
Originally Posted by supra2nv View Post
"Electrons act like photons. They are both screwy, but in exactly the same way." Richard Feynman
Wave Particle Duality
supra2nv is offline   Reply With Quote
Old 07-11-2013, 09:12 AM   #408
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I can't believe I'm two and a half weeks shy of a full year of ownership!
I should drive her more...
Old 07-11-2013, 01:39 PM   #409
ATL BRZ
ATL BRZ's Avatar
Tom's tail lights just arrived! Installing now...
Old 07-11-2013, 03:13 PM   #410
ATL BRZ
ATL BRZ's Avatar
Just installed my Tom's tail lights!
The install was an absolute breeze as these are UDSM wiring spec for plug & play use. They come with a new turn signal relay which is a simple swap under the driver's side lower dash.
I love them! I'll have to wait until this weekend to snap some better shots of them outdoors.
Old 07-11-2013, 03:16 PM   #411
swift996
swift996's Avatar
Mine arrive today too! Are you able to lay on the floor and reach the relay or do you have to pull off the lower dash cover thing?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-11-2013, 03:24 PM   #412
ATL BRZ
ATL BRZ's Avatar
I followed this DIY just for the relay part and found it to be very straight forward getting the lower dash panel off. The relay is easier to get at from behind. It's hanging on a little white slotted plastic hanger. Get a short flathead screwdriver as the DIY instructs. Take the screwdriver and bring it up under the dash behind the relay and stick it right in the white hanger and give it a light push and then wiggle the relay away from you. Don't pull it down, slide it back.
Old 07-11-2013, 03:37 PM   #413
ML
ML's Avatar
Drives: 13 White MT FR-S
wow, Its been 10 months for me and I have 15600 miles! Do you only drive it on the weekends? Also how did you make the plastic intake "mouth" part of your brake duct system?
thanks
Old 07-11-2013, 03:45 PM   #414
ATL BRZ
ATL BRZ's Avatar
It's my daily driver but I have the ability to work from home when I need to. My office is about 5 miles away when I need to be there.
Just lucky, I guess...
Well those are all custom @Touge Factory pieces so they may have a more accurate answer, but I believe they took a generic plastic duct and shaved it down to perfectly fit flush against the back of the BRZ's bumper grille.
Old 07-11-2013, 03:52 PM   #415
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
correct.
Touge Factory is offline   Reply With Quote
Old 07-12-2013, 02:45 PM   #416
2pt5RS
Berz
You were spotted the other day
http://wrxatlanta.com/forums/showthread.php?t=34583
2pt5RS is offline   Reply With Quote
Old 07-12-2013, 04:35 PM   #417
ATL BRZ
ATL BRZ's Avatar
Originally Posted by 2pt5RS View Post
That was a sweet WRX, I knew I'd be safe parking next to him
Old 07-15-2013, 12:35 PM   #418
ATL BRZ
ATL BRZ's Avatar
Anyone with Tom's tail lights think the supplied turn signal relay makes a worse sound than the stock relay when the signal is activated?
@swift996 @switchlanez @F1point4
To me it sounds really dinky now. Meh.
Old 07-15-2013, 12:37 PM   #419
swift996
swift996's Avatar
I didn't notice any change
Old 07-15-2013, 12:42 PM   #420
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
It does make a slightly louder click and blinks at a slower frequency by milliseconds. But I like the change... TOM'S tails signal more authoritatively than stock, hehe.
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
