go_a_way1
Old 10-23-2014, 03:34 PM   #407
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Originally Posted by wparsons View Post
If something with a crop sensor brings out the features the 6D has, I'll happily stick with that, but the FPS rate, wifi, GPS, ISO range, etc are what I was looking at. It's not much more than the 7D, and the features make it worth it.
I'd really recommend the 70D then. 7fps vs 4.5fps. Has wi-fi, but unfortunately no GPS. ISO up to 12800 (You'll be hard pressed to need anything higher than 6400). Far superior autofocus system; 19 point all cross type vs. 11 point only 1 cross type (center). Honestly, the only thing it tops the 70D on is the full frame sensor and GPS if you really care about GPS that much.
I really wanted to like the 6D when it came out, but they cut the budget on it waaaay too much.
As for the whole video thing, Canon still leads on that front. Granted Nikon might have better continuous autofocus, but most intermediate to hardcore videographers prefer manual focusing their lenses with some sort of follow focus system.
Manic is offline   Reply With Quote
Old 10-23-2014, 10:04 PM   #408
wparsons
wparsons's Avatar
My T2i can do 6400 and 12800 ISO, the 6D does 25600 without dipping into the expanded range, and will do 102400 expanded. I've had enough cases where 6400 wasn't enough to want a much higher range, plus if it can do a much higher range you'll get less noise at 6400 than a camera that maxes out there.
The 7DII looks interesting, but it's lacking in ISO and I can't seem to find anything that confirms if it has wifi.
flickr
Old 10-23-2014, 10:57 PM   #409
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
This got real nerdy real quick. I like it
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
The Following 3 Users Say Thank You to AznKirby For This Useful Post:
M-17 (10-29-2014), Manic (10-24-2014), wparsons (10-24-2014)
Old 10-24-2014, 12:14 AM   #410
Manic
Is not fast.
Manic's Avatar
Interesting. I never found myself needing that high of an ISO. Granted, you're right in that having a higher available ISO means lower ISO settings will be cleaner, but in most cases, if you're in that 6400+ range, I'd recommend using a speed light.
In any case, the bottom line is the 6D offers little in ways of tech advancements over the 70D or 7D Mk2. It's a weird little intermediary step that doesn't quite make it up to 5D standards, but doesn't offer enough to justify the cost of full frame and full frame lenses.
Old 10-24-2014, 04:10 PM   #411
wparsons
wparsons's Avatar
I'd only have to replace the 17-85. 50mm 1.8 and 70-200 F4L are both EF mounts already. I'm considering replacing the 17-85 with a 24-105 and 10-22 anyway, so it's not a real concern.
flickr
Old 10-24-2014, 04:32 PM   #412
Manic
Is not fast.
Manic's Avatar
Fair enough, just wanted to give you a heads up that full frame isn't all the jazz it's made out to be. Unless you really, really need that bump in performance, you're looking at a body that costs $800 more than the 70D's and lenses that are double the price of equivalent EF-S models.
There are some definite advantages to going full frame, but in most circumstances, those are designed for higher-end shooting and are often unutilized. More often than not, a photographer's skills will bottleneck before their kit does, and this margin can make the difference between dropping thousands of dollars on equipment you don't need and spending that money on lenses or universal tools like tripods and speedlights.
Sorry if I'm coming off a bit strong against full frame; it's just that I've had a number of friends make the plunge into full frame in order to take the exact same photos they were taking before albeit with slightly higher resolution and slightly higher quality. I had a similar debate with myself a while back and I just couldn't convince myself that I'd need the extra performance from going full frame unless I was making money off of my photos (which I no longer am).
The Following User Says Thank You to Manic For This Useful Post:
Pwolf (10-24-2014)
Old 10-24-2014, 05:48 PM   #413
wparsons
wparsons's Avatar
To me, the cost difference between the 70D and 6D is less than one good lens, so it's not as big of a concern. It'll be a while before I upgrade anyway (lenses first), so by then the 90D, 7DIV and 6DIII will be out
flickr
Old 10-24-2014, 06:16 PM   #414
Manic
Is not fast.
Manic's Avatar
Well if you're looking that far down the line, I recommended aiming for the 5D Mk3. Go big or go home!
Old 10-27-2014, 02:25 PM   #415
Skurge
Drives: 84 RX-7/13' FR-S
i promised pictures, though i haven't taken any of the ones off my camera yet, here's a little pano I took with my S5 sitting at camp
i'll get some real photos up soon!
1984 RX-7 GSL
2013 FR-S
Skurge is offline   Reply With Quote
The Following User Says Thank You to Skurge For This Useful Post:
Pwolf (10-27-2014)
Old 10-27-2014, 02:46 PM   #416
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
I have a T3i that I barely use anymore after I got the EOS-M... lol
tigermack is offline   Reply With Quote
Old 10-28-2014, 01:19 AM   #417
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Wow, just wow:
[ame="http://vimeo.com/110140870"]Stormscapes 2 on Vimeo[/ame]
SCCA T4 - FRS
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
Atticus808 (10-29-2014), M-17 (10-29-2014)
Old 10-28-2014, 01:39 AM   #418
AznKirby
Are you 20/20?
AznKirby's Avatar
^ Wow those night shots are just insane
2014 FR-S Monogram
IG: @MonKehC
Old 10-28-2014, 02:14 PM   #419
AznKirby
Are you 20/20?
AznKirby's Avatar
Quick edit. Not 100% happy with the results, but I was shooting with my friend's sister's Canon Rebel T3i (Something or other) & didn't look up how to switch it to shoot in raw.
Should've had my Nikon that day. Hah!
IMG_7628 by AznKirby, on Flickr
2014 FR-S Monogram
IG: @MonKehC
The Following 2 Users Say Thank You to AznKirby For This Useful Post:
M-17 (10-29-2014), Pwolf (10-28-2014)
Old 10-29-2014, 06:16 PM   #420
M-17
Ninja Cat Mod
M-17's Avatar
Originally Posted by rice_classic View Post
Camera: Canon T3i
Lenses:
Canon 10-22 EFS
Canon 50mm 1.8F
Canon 55-250mm
Sigma 150-500mm (w/ 2 stage OIS!)
Picture of rig @ the track:
Question, if you don't mind me asking, do you like that Sigma 150-500mm? Judging from the video it looks like it may be better used for pictures than video. I do like the video you posted though.
Wow, just wow:
Yeah... just WOW
