Old 11-29-2011, 11:48 AM   #407
Dimman
Kuruma Otaku
Dimman's Avatar
That power and torque curve looks very close (hard with the pic's detail) to the same one they used in 2006 for the intro to D4-S.
And it doesn't seem to be on a scale that makes it match. (ie, the peak should be more to the right if it really is at 6600)
Because titanium.
Old 11-29-2011, 11:51 AM   #408
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Wow, those graphs are very similar.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 11-29-2011, 01:26 PM   #409
Levi
Drives: Toyota
Ryephile, I noticed the same thing. I wonder why torque curve and straight line performance were not yet revealed.
Levi is offline   Reply With Quote
Old 11-29-2011, 01:45 PM   #410
Allch Chcar
Drives: N/A
Originally Posted by Levi View Post
I don't know if you already noticed this, but this is the torque curve of the GT86.
We can see the 205 Nm at 6.600 RPM.
Check the translation for that page. I believe that graph is for a different engine as an example.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 11-29-2011, 03:13 PM   #411
bambbrose
Wiring Nerd
bambbrose's Avatar
Drives: 1994 Supra
Does anyone know what the fuel pressure is for the direct injector? Is it a static system or a return? Does it pressurize internal to the injector or have a pump and a separate fuel rail from the standard system?
bambbrose is offline   Reply With Quote
Old 11-29-2011, 10:40 PM   #412
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Figure these might be relevant for this thread:
I've seen headers like this before on Subaru's, just not very often. They are crossed over like that due to the piston firing order to make a near-perfect exhaust flow for the headers.
The muffler looks damn close to an Impreza hatchback muffler, even has Subaru stamped on the muffler.
Kostamojen is offline   Reply With Quote
Old 11-29-2011, 11:06 PM   #413
torquemada
natural born kraut
Drives: EDM WRX STI MY06 WRB
yeah, and it rusts like a Subaru muffler
torquemada is offline   Reply With Quote
Old 11-30-2011, 12:12 AM   #414
Kostamojen
Not something I ever have to worry about, LOL!
But the catback will be the first thing to go of course.
Old 11-30-2011, 12:33 AM   #415
Ryephile
Hot Dog
Ryephile's Avatar
Good call.
Looking at the engine stand pictures versus what's installed in the car, it's possible to discern the three fuel lines coming from the chassis to the engine; one for each port injection rail, and one going to the DI HPFP, which appears to be the right bank intake [behind the oil filler] and camshaft driven [usually via its own lobe]. No return lines from what I can tell, which puts it on par with everything current. Speaking of the DI system, the injectors appear to be inboard of the intake manifold, virtually out of sight.
I see cam phasers for intake and exhaust along with corresponding cam position sensors, all good. I see a pre and post O2 sensor on the main catalytic converter. The exhaust is fascinating; I have to admit I'm bummed there's no asymmetrical exhaust [and thus the warble tone], but this design looks reasonable for stock.
Oh, and i can't wait to rip off that "sound generator".
Old 11-30-2011, 01:33 AM   #416
Allch Chcar
Drives: N/A
Those port fuel injectors are going to be easy enough to change I think. Should they ever need changing. >.>
-Allch Chcar
Old 11-30-2011, 12:01 PM   #417
Dimman
Kuruma Otaku
Dimman's Avatar
Layout like that exhaust will be probably what turbo kits do, with the turbo around where the catalyst is.
The intake runners are weird, really flaring away from the plenum.
Because titanium.
Old 11-30-2011, 12:14 PM   #418
Ryephile
Hot Dog
Ryephile's Avatar
They are? How else would they run them without forcing the hood several inches higher?
Old 11-30-2011, 02:07 PM   #419
Dimman
Kuruma Otaku
Dimman's Avatar
In the side view, when they come off the plenum they look narrow, but they flare out to quite wide towards the head where the port injectors are. But in the front view the alternator is blocking the view from that angle, so it's difficult to say if they are expanding, or just changing shape.
Is this thing using TGV's/variable intake runners? Subaru and Toyota both use them currently, except the D4-S 2GRFSE motor doesn't.
Because titanium.
Old 11-30-2011, 04:41 PM   #420
Kostamojen
No TGV's on this motor. The new DI turbo motor next to it is however, which is rather interesting.
Joke Thread VenomRush Off-Topic Lounge [WARNING: NO POLITICS] 27 07-09-2011 01:44 AM
The Music Thread aliphian Off-Topic Lounge [WARNING: NO POLITICS] 13 03-28-2011 12:35 PM
engine swap thread aspera Engine Swaps 231 03-15-2011 06:10 PM
FT-86 to debut new GPS-track day technology for use on track and GT5! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 17 01-30-2010 12:30 PM
