Old 02-07-2016, 05:53 AM   #29
denso
Drives: 86
Awesome build!
denso is offline   Reply With Quote
Old 02-07-2016, 04:31 PM   #30
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I disagree, I say MOAR PICS!
Just for you. Confirmation that the overpipe will fit. It's even equal length!
Now to get this thing back together and attend a super bowl party
kask2_6.0 is offline   Reply With Quote
The Following 8 Users Say Thank You to kask2_6.0 For This Useful Post:
-Phil (02-07-2016), BigFatFlip (02-07-2016), DustinS (02-07-2016), NotSoJDM (02-12-2016), Shankenstein (02-08-2016), texasbound972 (03-06-2016), Thorpedo (02-07-2016), VerusEric (02-07-2016)
Old 02-15-2016, 08:01 PM   #31
Mingo
Drives: 2015 BRZ Limited
subbed
Mingo is offline   Reply With Quote
Old 02-18-2016, 02:07 AM   #32
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Working on a design for the tube to T4 flange transition. Going to have this part investment cast. Trying reduce turbulence into the compressor by having a gradual expansion through the bend rather than an abrupt transition right at the flange. This is the biggest part I've printed yet. Had a couple of instances where the print shifted a bit. I think the tension on the drive belt is just a bit too loose.
The Following 3 Users Say Thank You to kask2_6.0 For This Useful Post:
sato (09-25-2016), VerusEric (02-19-2016), xkalelx (02-19-2016)
Old 02-19-2016, 01:27 AM   #33
Jollibee86
Jollibee86's Avatar
Drives: 2014 Scion FR-S
Do you use support material?
Jollibee86 is offline   Reply With Quote
Old 02-19-2016, 08:09 PM   #34
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I do. This part needed a ton of it both inside and out. Really sucked to remove it from inside the runners. I think it would successfully print without any internal supports though. Prints like this are really tempting me to upgrade to a dual extruder so I can print the supports with a water soluble material.
Old 02-19-2016, 08:21 PM   #35
Docmattic
Drives: GT 86
Great work so far! subbed along!
If you don't mind me asking. How much are you expecting this setup to cost from start to finish?
Docmattic is offline   Reply With Quote
Old 02-19-2016, 09:07 PM   #36
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
That's a good question. And one I don't really want to know the answer to
But if I had to guess I would say about $10k. A lot of tool purchases and supporting mods included in this.
The main components are:
Turbo: $2,400 w/ turbosmart IWG actuator and BOV
Intercooler core: $300-500
321 stainless tubing and merge collectors: $1,100
Aluminum tubing: $300-$500
The rest is hard to add up. $50 here, $100 there an so on. So I don't really know lol.
Old 02-26-2016, 02:27 PM   #37
denso
Drives: 86
Any updates??
Old 03-03-2016, 12:43 AM   #38
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Sorry, not much for updates. Just got home from a nice 10 day ski trip in Colorado. Why did I have to come back home to work? Will be traveling for work the next couple of weeks as well so probably nothing new for awhile. I have been talking with a few casting companies about the above part getting quotes and design suggestions to help with the casting process. Hopefully I can finalize that soon. I did get some presents in the mail today though..
The Following 2 Users Say Thank You to kask2_6.0 For This Useful Post:
texasbound972 (03-06-2016), xkalelx (03-08-2016)
Old 03-05-2016, 03:28 PM   #39
denso
Drives: 86
Okay
How do you realise the oil reservoir? To be more specific - how "big" should this be? Im looking to go the same route like you but I will just mod the frontpipe with vband clamps to fit the turbo. I want to use the FA20DIT scavenge pump just like you.. Is this plug and play? We need a adaptor plate I guess - like the avo one.
Old 03-05-2016, 11:39 PM   #40
Astroboy
Astroboy's Avatar
Drives: None
I love this. Always love people who engineer their own stuff for their cars. Nice!
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
The Following User Says Thank You to Astroboy For This Useful Post:
kask2_6.0 (03-06-2016)
Old 03-06-2016, 12:09 AM   #41
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Now I want to get one of those for my 7064 efr! Glad you went the EFR route. Can't wait to finally see some dyno numbers one day!! Keep up the good work!
Sent from my SAMSUNG-SM-N920A using Tapatalk
texasbound972 is offline   Reply With Quote
The Following User Says Thank You to texasbound972 For This Useful Post:
Astroboy (03-06-2016)
Old 03-06-2016, 03:07 PM   #42
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Originally Posted by denso View Post
Okay
Not sure exactly on how big the reservoir should be. It really doesn't need to be very big. Just large enough to allow an additional port that is vented to atmosphere so the pump isn't pulling the oil through the turbo (cannot create a vacuum). The FA20DIT pump drive is a direct fit to the cam but the flange does not fit the head and will need an adapter plate like the AVO. @VeloxEric or @Mrc@ptuning should be able to help you out with this. If you aren't dead set on an EFR turbo or doing a custom job like I was it would be worth checking into the ptuning setup if you haven't already. They have a really good package that matches what you have planned.
On a side note I build a really cool temp controlled encloser for my 3D printer today. Its really just pieced together Ikea furniture with a fan controller, led's, and added structure so the printer doesn't shake it apart. But I'm pumped on it. Now I can run my printer even more without my girlfriend getting irritated with the noise in the kitchen.
BigFatFlip (03-06-2016), denso (03-07-2016), VerusEric (03-06-2016)
Considering a CSP Build from my STX twin.. Scooby South Tracking / Autocross / HPDE / Drifting 9 10-17-2015 12:10 AM
Best twin build performance wise? gt8613 BRZ First-Gen (2012+) — General Topics 9 01-19-2015 08:29 PM
- 86FLY - Australian Custom Turbo Jetkit 4.0 Build + Custom Flex Fuel Dyno Tune aaronsadventures Member's Car Journals 6 12-04-2014 03:01 AM
JET86. The Australian self built, twin charged build. jet86 Member's Car Journals 85 11-15-2014 05:35 PM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
