#29 | |
Drives: E92
1. All the issue will be fixed once we get it produced on the machines. 2. Most of the ambient letter/logo are still up in the air. I have a few ideas in mind. 3.That little graphic above the RPM needle is straight from a LFA, where it serve as a transmission setting indicator, like on those BMW M cars with different shifting program/ferocity. Purely cosmetic here, could be change or replace with something else. Depends on general feedback. 4. Fonts are ripped straight from the LFA, looks a bit off here but it will be fixed once the file are sent in to be cleaned up.
2013 Scion FR-S 6AT
#30 | |
Drives: E92
The aim is to produce a high quality straight replacement to mimic the high tech look and sophistication of the Lexus F Sport series within the physical constraint of the Scion/Toyota/Subaru gauge cluster. I am sure with enough money and time, it could be made to work ![]() Another teaser for now... post #86!
2013 Scion FR-S 6AT
#31 | |
Drives: 2020 BRZ PP Silver
sub |
#32 |
Drives: Asphalt 2013 FR-S
Yup. Ill take one now please.
#33 |
Drives: 2013 Ultramarine FR-S
Really interested!
In my opinion (Lots of these being shared) 1: Transmission Graphic needs to be removed, as it serves no purpose on our cars 2: Get rid of Sport+ and move the FRS/BRZ in it's place (or just remove it and the car model all together. I don't see a need for either) 3: Dual MPH/KM/h gauge on left side. Everything else looks really good
#34 |
Drives: 2013 FRS
Really awesome concept. I would pick one up. Only thing I would request is to remove the sport s+, remove the FR-S, and the design under the needle where the rpm is.
#35 |
Drives: 13 FRS
can you make the rev needle flicker up to redline and down like the lexus does when you start it? Then i buy
#36 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
#37 |
Drives: Mazdarati
mine dose........after I set the shift point indicator
#38 | |
Edit: This cluster design would look sick with the needles from the F-Type Jag ![]() It has the cutout for the numbers to be seen through the Needle.
| The Following User Says Thank You to DustinS For This Useful Post: | JW89225 (01-08-2016) |
#39 | |
Drives: E92
2. I think I will move FRS/GT86/BRZ to that place as well. Maybe place another graphic where the existing FRS logo is. It will be something discreet and clean in fitting with OEM style. 3. I am planning to have mph fill the red inner ring.
2013 Scion FR-S 6AT
#40 | |
Drives: E92
2013 Scion FR-S 6AT
#41 |
Drives: Raven Toyota GT86
Dang, didn't think i'd ever want to change the cluster, but seeing this, i'm in if the price is right!
Toyota Corolla E12 Hatchback (2005) - GONE
Toyobaru GT86 ハチロク - CURRENT |
| The Following User Says Thank You to JoeHK For This Useful Post: | JW89225 (01-11-2016) |
#42 |
Drives: E92
Just a heads up for you guys, latest revision have ACUTAL water temperature gauge in Celsius ala GRMN 86 's dash. Will reveal the update when I get a chance.
I know some of you are asking for this Also, new template is far cleaner and FRS/86 logo moved to an illuminated position per popular request. Color scheme have been updated to follow the newest RC-F and GS-F Lastly, most warning lights have been converted to appear much cleaner and understated.
2013 Scion FR-S 6AT
| F/S: FR-S instrument cluster | MissDeb | Audio/Visual, Electronics, Infotainment, NAV | 5 | 04-08-2014 05:02 PM |
| led cluster help | Grip Ronin | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 02-14-2014 01:29 PM |
| Gauge cluster mod? | kALMIGHTY | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-27-2013 11:59 PM |
| BRZ cluster on FRS? | Shipwreck | Electronics | Audio | NAV | Infotainment | 6 | 03-07-2013 12:09 PM |
| New Lexus ES leaked. Who said it's Camry of Lexus? | Dark | Other Vehicles & General Automotive Discussions | 25 | 02-24-2012 02:34 AM |
