Old 02-29-2016, 04:38 PM   #29
Godzilla35
Drives: Nissan GT-R
subbed.
Godzilla35 is offline   Reply With Quote
Old 03-01-2016, 11:35 PM   #30
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Hydra EMS is plug and play with full CAN support to run FA20, EJ, and 2 JZ. Everything works but cruise control and traction control is handled by the Hydra EMS so it's programmable. We just supply you with a plug in harness and then give you a few extra flying leads to wire in the extra cylinders.
I don't have 2JZ maps but they have been around for years so I'm sure I can get someone close on the ignition timing map but the fuel map will need some work for sure.
All oem dash functions, traction/stability controls, ABS, climate control, and power steering. It's also direct plug and play with AIM CAN dashes or AIM Solo DL which I use for racing.
If you have any questions just let me know.
Phil
Element Tuning is offline   Reply With Quote
Old 04-07-2016, 06:16 AM   #31
Zer0
Drives: 2015 frs
Phil
Can I use a Hydra EMS to run a LS in my FRS, and are the maps available? thanks in advance for any info you might have
Zer0 is offline   Reply With Quote
Old 04-07-2016, 06:13 PM   #32
protpibe
protpibe's Avatar
Phil
That's actually AWESOME news. I had just made my mind up to go Motec but have been puking a little bit in my mouth from having to spend almost $5k US.
Just to confirm, this will plug and play into the car, retain all canbus functions, and will run a different motor (obviously with re-pinning/wiring)
http://elementtuning.com/store/#!/El...ategory=439245
Old 04-07-2016, 09:02 PM   #33
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
It's confirmed that Emtron works. I just got back from driving the car. EPS, tach, fuel level, coolant temp, speedometer are all working. @Ross will be using the Emtron to control traction control.
[ame="https://www.youtube.com/watch?v=B8Bne1XCBLg"]2JZ FRS Idle - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=T3lDx5ptZYw&nohtml5=False"]2JZ FRS low speed drive-ability - YouTube[/ame]
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
The Following 2 Users Say Thank You to slicktop For This Useful Post:
Jeff Lange (06-06-2016), tirespin782 (04-08-2016)
Old 11-04-2016, 12:34 AM   #34
surfingisfun
Drives: Scion FRS
Im currently doing a 1jz swap into my FRS and am also looking for wiring options.
I would be very interested to find a plug and play system that will work!
surfingisfun is offline   Reply With Quote
Old 11-20-2016, 09:36 PM   #35
slicktop
There are exactly zero plug and play systems on the market. Good luck with your swap!
-slicktop
2013 Scion FRS
Old 11-23-2016, 01:09 PM   #36
surfingisfun
Drives: Scion FRS
LOL I know there are no plug and play options.. This guy was saying he was making one?
Im planning on running a Motec M130.
Old 11-23-2016, 01:14 PM   #37
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
We are working on it still. Taking longer than we wanted but we are testing everything before it goes anywhere near a car that's not our own 2j and ls test cars
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
2jz, ecu, swap, wiring
Wiring in IAT for SD mrk1 Software Tuning 13 04-14-2023 09:15 AM
Need some help with some wiring timmydatooth Scion FR-S / Toyota 86 GT86 General Forum 41 08-14-2015 10:10 PM
Wiring for DRL Yap Cosmetic Modification (Interior/Exterior/Lighting) 2 01-19-2015 02:13 AM
LF VA Wiring Help OURO3OROS Mid-Atlantic 0 02-23-2014 09:24 AM
Sirius(ly) Irritated poudre BRZ First-Gen (2012+) — General Topics 12 07-16-2012 12:06 AM
