| Member's Car Journals Car journals by our members. |
#29 |
Canada Eh!
Drives: '13 FRS
Avest Japan Clear LED Side Markers! ![]() DSC_0003 by joeag., on Flickr ![]() DSC_0004 by joeag., on Flickr Some Japanese warning... Hope its nothing too serious... ![]() DSC_0005 by joeag., on Flickr ![]() DSC_0006 by joeag., on Flickr ![]() DSC_0012 by joeag., on Flickr ![]() DSC_0011 by joeag., on Flickr ![]() DSC_0010 by joeag., on Flickr Last edited by Joe-G; 01-04-2016 at 12:28 PM. |
#30 |
Canada Eh!
Drives: '13 FRS
Hey sorry, I dont have a specific link. You'll find that the forum vendors can get you a set... Or the ebay/amazon route works too, BaysonR seems to have products that generally fit well.
#31 |
Canada Eh!
Drives: '13 FRS
So my drivers side mirror has had a crack in it for awhile now. I gather it was caused by using an automated cloth wash at the dealership I used to work at...
Since I've recently been in the spirit of making some DIY pieces (ie. Front splitter), I figured I'd try fitting a set of universal mirrors. If it turns out looking like ass, I can always put the stock ones back on. All you really need is cardboard, sheet metal, and tin snips (or dremel). Mirrors Removed. What a PITA. Trying to fish the plug through the hole was a nightmare. Its easier to de-pin the connector (preferred method), or cut the plug off (and re-wire later if needed). ![]() 12401830_10156497610015347_7606791784173115987_o by joeag., on FlickrFlickr Carboard dreams ![]() 12473968_10156497612605347_4446761771655950194_o by joeag., on Flickr Fitting the cardboard template ![]() DSC_0141 by joeag., on Flickr Transferred onto sheet metal ![]() DSC_0145 by joeag., on Flickr Doubled it up! ![]() DSC_0147 by joeag., on Flickr Measured the bolt for hole size (M6x1.25 I beleive) ![]() DSC_0149 by joeag., on Flickr Didn't really fit so great without a gasket. Ended up being a little too big ![]() DSC_0150 by joeag., on Flickr So I trimmed both down, and fitted the oem gasket. ![]() DSC_0154 by joeag., on Flickr Right side ![]() DSC_0159 by joeag., on Flickr and the left! ![]() DSC_0158 by joeag., on Flickr Now I'm just waiting for the mirrors to come in, so I can mount them up to the base plates and get better looking hardware. Mirrors and base plates will probably be color matched and painted the same time I get my wing. Thanks to @Tye300 and his DIY thread. Couldn't have made it any easier =). |
| The Following User Says Thank You to Joe-G For This Useful Post: | Tye300 (01-05-2016) |
#32 |
Canada Eh!
Drives: '13 FRS
#33 |
Drives: Asphalt 2015 FRS
That wing really matches the lines of the car! If it turns out that good in reality, I would say it has to be my the best wing I've seen!
#34 |
subbed!
#35 |
Drives: Subaru BRZ Limited
I was with you until you fitted a sheet of plywood to the front. maybe I'm being too judgmental but does that really do anything except look like a sheet of plywood on the front?
It looks like you're having fun with the car though. It's all good. |
#36 | |
Canada Eh!
Drives: '13 FRS
For what its worth, plenty of teams use plywood. From what it looks like, even the Rasty 86
#37 |
Canada Eh!
Drives: '13 FRS
So the mirrors showed up... amongst some other goodies if you can spot it ![]() Overnight from...Taiwan! haha ![]() DSC_0205 by joeag., on Flickr Nice packing! ![]() DSC_0211 by joeag., on Flickr Not bad for under $100 USD! ![]() DSC_0213 by joeag., on Flickr And the weight! 7.70oz ![]() DSC_0220 by joeag., on Flickr Or 219g ![]() DSC_0222 by joeag., on Flickr and mocked up.. Will probably get it all bolted down properly on the weekend... ![]() DSC_0246 by joeag., on Flickr ![]() DSC_0243 by joeag., on Flickr Also found a set of replacement decals for the CE28. They're reproductions. ![]() DSC_0249 by joeag., on Flickr Last edited by Joe-G; 01-05-2016 at 11:18 PM. |
#38 |
I dig the mirrors! I think the mounting plates will look better painted black. Also, will you be able to attach the mirrors to the center of the plates?
#39 | ||
Canada Eh!
Drives: '13 FRS
Bottom right Similar to Quote:
#40 |
You're probably right about the sturdiness being able to use an existing mounting point.
(also, i just noticed you are joe-g and I'm joec, hahha) |
#41 |
Canada Eh!
Drives: '13 FRS
#42 |
Canada Eh!
Drives: '13 FRS
Grazzio & Co. Style Tail Light DIY
Itching to do something to the car this weekend, I went ahead and tinted my rear tail lights. It's always been something that I've wanted to try, but I've never really had much patience or skill when it came to painting and taping.
It came out ok... Not perfect, but idk I guess we can let the pictures speak for themselves. I used 4-5 coats of Red Duplicolor Metalcast, and 2-3 coats of Duplicolor Acrylic Clear Coat. I also used some autobody grade wax and grease remover I had laying around from a previous project. However, I didn't bother to scuff up the housings... Others seem to have no problems, but I guess only time will tell... All taped up... Should have taken more time during this step. Oh well... ![]() Right. After a few light coats of Metalcast. ![]() 2-1 by joeag., on Flickr Left, also after a few light coats of Metalcast. ![]() 3-1 by joeag., on Flickr Couple coats of clear, and after drying. Color came out OK! Here's the left side ![]() 4-1 by joeag., on Flickr ![]() 5-1 by joeag., on Flickr ![]() 6-1 by joeag., on Flickr ![]() 7-1 by joeag., on Flickr Right Side ![]() 8-1 by joeag., on Flickr ![]() 9-1 by joeag., on Flickr Side by Side ![]() 10-1 by joeag., on Flickr ![]() 11-1 by joeag., on Flickr ![]() 12-1 by joeag., on Flickr ![]() 13-1 by joeag., on Flickr And sitting indoors to cure! (Garage is a little too cold up on this side of the border) ![]() 15-1 by joeag., on Flickr |
| My Journal | Weasel Soup | Member's Car Journals | 27 | 10-03-2016 05:07 PM |
| < RYO > Car Journal | RYO | Member's Car Journals | 3 | 04-16-2015 01:48 PM |
| EWY's Raven FR-S Build Journal | EWY | Member's Car Journals | 22 | 02-25-2015 10:30 AM |
| 1 SIK FRS Raven FRS Build Journal | 1SIKFRS | Member's Car Journals | 20 | 01-19-2014 03:58 AM |
| Duder's BRZ Mod Journal | duder | Member's Car Journals | 17 | 06-26-2013 11:54 PM |
