Old 06-25-2012, 07:01 PM   #29
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
the MR2 (all generations) and the Lotus Elise use shift cables.
uspspro is offline   Reply With Quote
Old 06-25-2012, 11:05 PM   #30
Marrk
Drives: Honda Fit
and the Lotus Elise gearbox famously sucs ballz, bro. Can't comment on the MR2. Never drove it.
Marrk is offline   Reply With Quote
Old 06-25-2012, 11:38 PM   #31
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
For transverse-mounted setups, cables are very common. Honda liked to use mechanical linkage for a long time, but even they have now switched to cables, much easier to route, etc. Same reason throttle pedals went from mechanical linkage to cables as well (before going DBW now of course). This includes most FF, MR and RR setups and some AWD setups. There are exceptions to all of this of course.
For RWD setups that don't use a rear transaxle, the shifter is usually either mounted right into the extension housing on the rear of the transmission case (especially on older cars which commonly had a shifter that came out of the console/floor much further forward and sloped back towards the driver), or it is remotely-mounted with a tripod or similar shifter extension. These setups are more common now that the more typical shifter setup is to have the shifter itself more vertical, and you move it along that plane.
The remote extension shifter is what most current non-truck setups seem to be employing, and the TL70/AZ6 in the Zx6 is no exception.
Here's a diagram from the 1993 JZA80 Supra NCF book illustrating the difference in shifters between the older and newer transmissions. It sort of helps illustrate the 2 common RWD shifter setups, with (especially from Toyota/Lexus), the "New" one being much more common now.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 06-27-2012, 03:01 PM   #32
groucho
Drives: '65 Lotus Elan, '05 Elise, '22 BRZ
I suspect that most mid/rear-engine cars use cable shifters, especially those with transverse engines. A quick Google check indicates that Porsche uses cable shifters in the Boxster/Cayman, and I believe the 911 also. My old mid-engine Porsche 914 (which IIRC used a 911 shifter) had a cable shifter, and the feel was OK but nothing special.
I was a LITTLE disappointed with the shift feel when I first picked up my BRZ, but it "broke in" and I'm pretty happy with it now. It is definitely not as short as I had hoped, and the feel isn't quite as good as I hoped, but it's very good, certainly much better than your usual FWD/AWD shifter. My Elan is still the benchmark that I compare everything else to, though... I had hoped the BRZ would match it, but alas, it doesn't. I'm still loving the BRZ though!
'65 Lotus Elan S2, '05 Lotus Elise, '22 WRBlue BRZ 6MT Limited
Formerly '13 DGM 6MT BRZ Limited
groucho is offline   Reply With Quote
Old 06-27-2012, 03:30 PM   #33
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
All water cooled Porsche 911's (996, 997 and 991) use a cable linkage shifter. Some of them such as the GT3's are actually quite nice. The air-cooled 911's all had a rod that went back to the trans and they have a nice solid mechanical feel.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 06-27-2012, 07:04 PM   #34
Marrk
Drives: Honda Fit
I drove the FRS today.
The gearbox is not "notchy" in any negative way. What you feel is the direct linkage doing its job. I did not experience anything that I would call "notchy."
I would say that the gearbox is like the S2000, but not as tight and not as short a throw. Also, the 3-4-5-6 shifts felt a little off. Hard to find the gates. Maybe just take some getting used to. Owners with seat time can comment on this.
I agree with Groucho above. Some cable linkage systems seem to work just fine. My Fit has a lovely little gearbox for a $15K five-speed econo-box. And, as noted, Porsche uses cable linkages (as well as MacPherson front suspension).
Old 06-29-2012, 03:19 PM   #35
GFo12ce
Drives: '10 Nismo 370Z
Originally Posted by Marrk View Post
Now that the cars are out in the hands of retail buyers, do we now know for certain whether the gearbox has a cable linkage or a mechanical linkage or something else?
I haven't seen anyone post on this. In fact, I haven't noticed a lot of comments regarding the MT gearbox.
Thanks. :happy0180:
Are you referring to a shifter linkage? This is a RWD car, the shifter goes directly into the transmission. I noticed you drive a Fit so I understand where you are coming from (FWD) but there is no need to link the shifter to the trans via any linkage in a RWD car. The Trans sits behind the engine, not beside the engine like in a FWD:
GFo12ce is offline   Reply With Quote
Old 06-29-2012, 04:31 PM   #36
vividracing
vividracing's Avatar
vividracing is offline   Reply With Quote
Old 06-29-2012, 05:03 PM   #37
GFo12ce
Originally Posted by vividracing View Post
LOL WTF, I guess I stand corrected. I worked for HKS USA, I've owned a Hachi, S13, S14, JZA80 Supra, and a Z and that's the first RWD trans I've seen with that configuration. I guess you learn something new every day...
Old 06-29-2012, 05:28 PM   #38
Jeff Lange
Jeff Lange's Avatar
The JZA80 has the same type of shifter linkage. Never looked under the car? LOL.
Jeff
Old 06-29-2012, 08:22 PM   #39
Marrk
Drives: Honda Fit
I believe Porsche and Lotus, to name two, use cable linkage. Most are quite happy wih Porsche. Most think that Lotus gearboxes suc ballz.
:happy0180:
Old 06-29-2012, 10:51 PM   #40
Jeff Lange
Jeff Lange's Avatar
Neither Porsche or Lotus use a similar setup to what an FR car does though, which is why they use cables. They are MR/RR.
Jeff
Old 06-30-2012, 02:34 AM   #41
Marrk
Drives: Honda Fit
Jeff
Thanks. I know that.
Old 06-30-2012, 01:50 PM   #42
Jeff Lange
Jeff Lange's Avatar
I figured, I just thought I'd clarify for others. People in this thread keep saying "RWD" when they really mean FR, since MR/RR are usually more typically related to an FF setup than an FR setup, even though they are driving the rear wheels.
So many exceptions to all of this though, but I don't think I can think of an FR setup that didn't use a transaxle in the rear with a cable setup.
Jeff
Link to FR-S standard and premium HU manual Sport-Tech Electronics | Audio | NAV | Infotainment 22 06-02-2012 06:46 PM
Five Axis Poll Thread Link Memphis Scion FR-S / Toyota 86 GT86 General Forum 3 05-26-2012 09:28 AM
Brand new FT-86 video w/ring tone link - Final reveal ezmayo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 12-01-2011 06:40 PM
Top Gear UK are ecxited too (article link) Infernal Scion FR-S / Toyota 86 GT86 General Forum 4 10-20-2011 12:55 PM
