Old 08-25-2015, 07:57 AM   #29
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Yeah I never did think it was supposed to be that way but a couple of other locals told me their 6 puck behaves similarly. Then again I don't have a six puck. I got the first gear to misbehave yesterday and when trying to shift into the others straight out from 1st, the rest went it smoother and improved as I kept going through them, weird. I'll pull this out eventually and will see what's going on. I know for sure a mild clutch shouldn't be behaving like this. It certainly isn't as hot as after completing a few hot laps or drag racing, it's just city traffic and no longer than 1 hr drive.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 08-25-2015, 07:58 AM   #30
yomny
yomny's Avatar
Hmmm... That just doesn't seem right in any case. Sticky for real, or warping?
Wouldn't a warping cause the behavior to be constant as with a brake rotor?
Old 08-25-2015, 08:22 AM   #31
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Just installed this clutch too...should I adjudt my pedal before driving it?
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 08-25-2015, 02:03 PM   #32
Ultramaroon
not playing cards
Ultramaroon's Avatar
The friction disc can deform when it's hot and then return to the correct shape when it cools. If it's common with those clutches I'm thinking it's a design flaw.
A hot spot on the flywheel is more analogous to a warped rotor. That's permanent.
Old 08-25-2015, 02:08 PM   #33
Ultramaroon
not playing cards
While stopped with the engine running, pick a gear and repeat engaging-disengaging while at the same time lifting the pedal a tiny bit each time. You will find the exact point at which the clutch makes contact because it won't go into gear.
If that distance changes between hot and cold conditions, something is warping.
civicdrivr (08-25-2015), yomny (08-25-2015)
Old 08-25-2015, 03:49 PM   #34
yomny
yomny's Avatar
I think then something's warped because without doing this I know my engagement point is very different when cold vs hot. I'd say about 1/2 to 3/4". So basically the clutch is crap lol, I wouldn't mind changing it if I knew that's the problem. I guess I have to find a decent shop and just check for stuff. Really appreciate your help man.
Old 08-25-2015, 05:23 PM   #35
yomny
yomny's Avatar
I need your help, more than before, now lol. Something's definitely not right, wanted see what my options were in case I need to replace the clutch disk, pressure plate or flywheel. I was looking at the South bend clutch but not sure if my ACT streelite FW would work with it, don't know anything preventing it but, they may work better with steel flywheels. Exedy, im a little confused, everyone says Stg 1, is that the OEM replacement clutch, as I can't find anything but the OEM, and is that good for low boost? Don't really want to spend over 700 but then I guess if I have to I'll push myself, maybe the price point of my ACT is what is giving me these issues now. I'll be taking it in to see what could be my problem and possibly replacing the parts but I didn't want to stick to ACT giving my current experience. Any input would really save this guy a lot sleep deprivation and headaches
@Ultramaroon
@cividrivr
Old 08-25-2015, 05:26 PM   #36
yomny
yomny's Avatar
I'd go for a drive and see where the engagement point is.. I think the pedal coming from the floor up, it should be about 3" from it or so but this is subjective and you may like it to engage closer to the floor.
Old 08-25-2015, 06:34 PM   #37
Ultramaroon
not playing cards
I don't remember the exact numbers but I know a couple guys running blowers just fine with the stock clutch. I have zero firsthand experience with aftermarket clutches on this beast. My $0.02 - go back to stock if you can.
Someone else will chime in and tell me I'm full of shit, tho. @civicdrivr?
yomny (08-25-2015)
Old 08-25-2015, 07:40 PM   #38
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Hey this sounds really dumb. Jack the rear end of your car up. Check all your transmission mounts, and your drive shaft mount. Make sure they're tight. That's free
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
yomny (08-25-2015)
Old 08-25-2015, 07:51 PM   #39
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Youre full of shit.
Old 08-25-2015, 08:27 PM   #40
Ultramaroon
not playing cards
Originally Posted by cdrazic93 View Post
Youre full of shit.
Haha... see!
cdrazic93 (08-26-2015)
Old 08-25-2015, 10:48 PM   #41
yomny
yomny's Avatar
Lol well my stock clutch held up but not really much, started to slip at 9psi.
Old 08-25-2015, 11:06 PM   #42
Ultramaroon
not playing cards
Old people will get it.
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 01:11 PM
Windows, Tranny, Clutch, Rattles Chalk Issues | Warranty | Recalls / TSB 7 06-30-2015 03:48 AM
Windows, Tranny/clutch, dealer issues. Help! Chalk Issues | Warranty | Recalls / TSB 9 02-15-2015 04:11 PM
Need your expertise(clutch and tranny) WatchmaN Issues | Warranty | Recalls / TSB 18 12-31-2014 09:32 AM
clutch issue yurgirlishot Issues | Warranty | Recalls / TSB 14 11-15-2013 05:20 PM
