Old 09-07-2015, 07:16 AM   #29
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by 7thgear View Post
depending on how the camber is achieved, you might actually be angling the strut to compensate for the increased offset so the actual effect on scrub is much smaller than the raw offset value.
Reading this and a couple other posts, it looks like adding camber from the strut mount reduces scrub radius? And adding camber from the clevis doesn't affect scrub radius?
I thought scrub radius was a measure of the tires center line where it meets the road, to the pivot axis between the strut mount and ball joint. By this, wouldn't increasing camber (more negative) from the clevis also increase the lever arm, but increasing camber from the strut mount shouldn't affect scrub radius?
Thanks for any help.
Old 09-07-2015, 02:10 PM   #30
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by Calum View Post
staring from a perfectly perpendicular tire 90*, and a 70* (purple) strut, observe the relationship of black and purple on the ground
if you angle the strut more by 5* with camber plates but do nothing at the wheel attachment point, then observe the relationship of red and green at the ground
if you angle the wheel at the wheel attachment point by 5*, and not touch your camber plate, then observe the relationship of green and purple at the ground
if you angle at the camber plate, but then use the wheel attachment point to angle in the opposite direction, then observe the relationship between red and black lines.
this is assuming no changes to offset have been made... feel free to do that in your head.
Old 09-07-2015, 02:48 PM   #31
Calum
That Guy
Awesome!! Thank your for the explanation.
Great, now I'm considering getting camber plates.
Old 09-07-2015, 03:21 PM   #32
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
the only thing I'd want to know... is where to we actually start at?
Old 09-07-2015, 05:05 PM   #33
Calum
That Guy
Id also like to know if there is an ideal? If we adjust from the strut top it will also affect inclination angel. Is that making IA better or worse? If worse, which has more of an effect?
I'm presently driving with MPSS tires, T0 coilovers with standard springs, group-n strut mounts, stock stabilizer bars, -2.5/-1.5 camber front/rear, zero toe everywhere, and about 31 psi tire pressure because our roads are horrible.
Steering feel is good, but it was better with less camber and more tire pressure. I don't want to lose anymore steering feel.
The good news is the the car tracks as straight as an arrow despite the aliment. Another thing I don't want to screw up by adding to the scrub radius.
I love this topic, but every time I learn something new it only brings up two more questions. We should change the name of this forum from suspension to Hydra.
Old 09-07-2015, 05:45 PM   #34
Ultramaroon
not playing cards
Ultramaroon's Avatar
Intuitively, I've wanted to start with only camber plates for the very reason you illustrated. I see negligible effect on scrub radius by changing the angle of the line intersecting top hat and ball joint.
That's assuming we have the same goal.
Never mind what I said about fore and aft. Duh.
Old 09-07-2015, 06:12 PM   #35
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Well I guess it's good I got my camber from plates. Thanks for the math
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
Old 09-07-2015, 10:30 PM   #36
Racecomp Engineering
Yes, you can use camber plates to reduce scrub radius. There is also a very slight benefit to pushing them in...it raises your roll center a little.
However, angling the strut inwards more with camber plates and increasing your SAI has some drawbacks that IMO outweigh the scrub radius issue, namely the change in camber for the outside wheel as you increase steering angle. It's not as big of a deal if you add caster at the same time, but it's important.
In most cases I recommend getting most of your camber from the hub. The change in scrub radius is pretty small. For what it's worth, a lot of the really high end dampers will come with some neat camber adjustment at the lower mount, either specially designed bolts for a slotted lower mount or "keys" (I'm not sure what else to call them) that go in the slot. The Nurburgring Challenge STI that I saw in Japan for example simply has (roughly) center fixed location lowering top mounts and got it's camber at the lower mount. Group N rally cars get their camber at the lower mount as well. Part of it is application specific I'm sure (higher steering angles having something to do with it) and many very fast cars still do get a lot of camber from plates.
With regards to scrub radius, a very large value can feel pretty awful in terms of steering kickback, effort, and also do some funky things with toe change. A wider track width is generally a good thing, but you have to keep in mind the scrub radius issue.
I don't have any set numbers for you guys, but -10mm in offset from stock is certainly fine IMO.
- Andrew
Old 09-07-2015, 11:45 PM   #37
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
^ also there's the amount of camber gain (minute) under compression with the different ways to get camber. Or rather, the lack thereof
Intent > Content
Old 09-08-2015, 12:14 AM   #38
Ultramaroon
not playing cards
...and you confirm my suspicion that I was oversimplifying. Thanks, Andrew.
Old 09-08-2015, 05:03 AM   #39
Calum
That Guy
- Andrew
Thanks!
Old 09-08-2015, 08:21 PM   #40
JDM4E
Drives: Honda Accord Euro
- Andrew
Thanks a lot and especially thanks for for some number.
JDM4E is offline   Reply With Quote
Scrub radius help ChrisD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-08-2015 10:14 PM
FS: Whiteline bushings KDT926 (Positive shift kit) & KDT922 (Positive traction kit) Tim_Asphalt_FRS Transmission and Driveline 3 09-26-2014 11:41 AM
Decreasing radius corners ZionsWrath Other Vehicles & General Automotive Discussions 48 11-11-2013 07:34 PM
what could cause my avg mpg to drop .3 in 2 miles?? dealer screwing me over? fluffy-reindeer-slayer Scion FR-S / Toyota 86 GT86 General Forum 45 09-02-2012 06:18 AM
which one is positive and negative frs Scion FR-S / Toyota 86 GT86 General Forum 1 08-04-2012 10:42 PM
