Old 02-06-2016, 09:30 AM   #29
Shady195
Drives: '13 10 Series FRS #1203
Originally Posted by cocaine_coupe View Post
what is the offset? and how's the inner clearance?
Not bad at all for DD, however when drifting I noticed a little rubbing on the inside wall at full lock.
Offset is +35
Shady195 is offline   Reply With Quote
Old 04-24-2016, 11:41 PM   #30
PeterFRS
PeterFRS's Avatar
Drives: FRS
In need of some advice here please
my fronts are fine where they are, just wanting 1/2" lower with rears..
the rear bottom "cup" is pretty shallow in our application and it is maxed out currently.
still lots of threads left on the shock body itself I am not right up to the spring perches.
I hope I am explaining this right..
and my question is.. by me "squeezing" or compressing the springs would that result in lower height?
or by "lowering" the pre load rings essentially "releasing" spring preload result in lower height?
thank you.. lol geez reading back what i wrote it's confusing for me too.
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 04-25-2016, 01:40 AM   #31
tyler_win_photo
tyler_win_photo's Avatar
By "squeezing" the spring, aka increasing preload you will lose droop and possibly make your car higher. It isn't recommended to use the preload as a means to adjust ride height. If you reduce your preload too much you're going to get some noise from your coilover.
If you want to lower the car more in the rear you can get a lower control arm like stance or voodoo that lower the mounting point of the rear strut, effectively dropping the rear.
tyler_win_photo is offline   Reply With Quote
Old 04-25-2016, 02:33 AM   #32
PeterFRS
PeterFRS's Avatar
Drives: FRS
first of all, thank you
Yup, if I were to "compress" the springs to get the height..I might have done so...
but to "loosen" the spring preload to acheive, would have been a no no.
good to know that compressing would not have helped in this situation
and like you said..
I will be looking for stance, voodoo or PBM LCA's.
Thanks again
'14 Scion FRS
Tein Flex
TE37
Old 08-08-2016, 10:13 PM   #33
ZX88
ZX88's Avatar
Drives: 22 BRZ
Originally Posted by Shady195 View Post
Just an update and some advice:
So I noticed my springs were "loose" in their perches up front (rears were still fine). I decided to look at the tein specs again for initial setup and preload.
Given some searches and talking with people it was advised to just "snug" them in the perches and leave it be unless/until you get a corner balance. Well what i thought was "snug" apparently was not snug enough as their was not enough tension from the spring on the locking collars to keep them from backing off.
I figured id try and do tein's specs and see what that does. SO i started snugging up the preload to teins specs. This takes a bit of muscle with the spanner wrenches, and now i understand what "snug" means.
Adjusted the front preload to teins specs, and now the collars are tight from the tension pushing back and it does not look like they will back off.
I checked the rears, and they did not loosen up at all, I only had to adjust those a few turns to get them to teins specs for the rear.
The only other thing I did after someone else with the Street flex series complained about the coilovers "lowering" themselves (which I have not had this issue after a few thousand miles on these already) is I torqued them with a torque wrench using the 1/4" port on the spanner wrenches and my torque wrench. Tightened them up good just to be safe..
front springs will always eventally loosen. These are spring on perch style correct? or is there a rubber spacer between the spring and the perch?
ZX88 is offline   Reply With Quote
Old 08-09-2016, 04:56 PM   #34
Shady195
There is a rubber spacer between the spring and the perch
Also, have not had a single issue since I torqued them. Haven't moved one bit.
Old 10-05-2016, 11:05 PM   #35
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I just installed mine with Tein's manual front 28mm and rear 35mm along with Cusco LCA
I didnt touch anything on front camber.
I am wondering how you guys set up on front camber and rear.
I don't know what setting is good for street.
Old 10-05-2016, 11:18 PM   #36
shattered_memory
Drives: Satin White BRZ Limited
I have -1.5 camber and -1 in the rear.
shattered_memory is offline   Reply With Quote
Old 10-06-2016, 10:20 AM   #37
zc06_kisstherain
Drives: SWP BRZ
how is it?
I was just wondering what others have.
I heard -1.2 front and -1 is good
Old 10-06-2016, 10:44 AM   #38
bfrank1972
Drives: 2013 FR-S Argento
-2.7 front -2.1 rear
(toe: 0 l/r front, -1/32 l/r rear)
bfrank1972 is offline   Reply With Quote
Old 10-06-2016, 04:50 PM   #39
zc06_kisstherain
Drives: SWP BRZ
dammm
I don't know what setup is ideal...
Old 10-06-2016, 05:21 PM   #40
strat61caster
strat61caster's Avatar
dammm
-Street, DD only, never going to trip traction control: 0 to -1 deg F/R
-'spirited, dd, canyons, memes, maybe one day I'll go to the track' -1 to -2 F/R, more front camber than rear by 0.2 to 0.5 degrees
-Occasional HPDE/AutoX, I don't care about tire wear -3 F, -2 R
-Max performance: buy a pyrometer, learn to make your own adjustments, rent a skidpad
Odds are your best results will come from asking the shop for suggestions and going with that (assuming it jives with what you've seen here). That's assuming it's a good shop though, not a crappy one or like a firestone/tire place that does quick-e alignments (places that sell lifetime alignments are usually a bit lazy about it just going with factory specs which are really loose).
ineedyourdiddly
zc06_kisstherain (10-06-2016)
Old 10-06-2016, 05:22 PM   #41
bfrank1972
dammm
Yeah, my personal opinion but seems to me there's a lot of 'sky is falling because you're running so much camber' going around. If you think about it, going from -1.5 to -2.5, it's one degree.
Uneven wear - I haven't seen any evidence of this yet. My tread is maybe not low enough yet to see any small differences, so maybe when I run out of tread I'll see it run out on the inside first, but overall no signs of uneven wear. No tram-lining issues, front end is super responsive, rear is nice and planted. I think getting the toe right is important.
Lots of other little factors too, like tire pressure, tire compound, sidewall stiffness, driving style. I'm running GY Asymmetric 2's and happen to be running very slightly stretched which stiffens the sidewalls (235's on 8.75 wide rims). Mostly back roads for me, not a ton of mileage on the interstante, but even when I'm on there doing 80+ it's a peach to drive.
The Following User Says Thank You to bfrank1972 For This Useful Post:
Old 10-06-2016, 05:30 PM   #42
zc06_kisstherain
Drives: SWP BRZ
I will try with -1.5 and -1 then see how i like.
The Following 2 Users Say Thank You to zc06_kisstherain For This Useful Post:
CSG Mike (10-06-2016), strat61caster (10-06-2016)
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Tein Street Flex Review! Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 52 04-20-2016 06:56 PM
Tein Street Flex Review and Short Video! RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 04-13-2016 02:17 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
New Tein Street Flex Coilovers - Review and Initial Impressions RallySport Direct Announcements, Contests, Giveaways 6 02-18-2013 12:06 PM
