Old 06-22-2012, 02:06 PM   #29
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Originally Posted by Kiteless View Post
Fantastic write up. Great work and thanks for sharing here. What is your opinion about this car for very occasional track use in stock setup? After I get an FR-S I want to take it to a track a few times a year, otherwise it will be my weekend and once or twice a week to work car.
- J
Oh, it's a fantastic car for that, probably nothing better in the price range.
AVOturboworld is offline   Reply With Quote
Old 06-22-2012, 02:12 PM   #30
GED68
Drives: VW
DBW throttle controller
Can you give any more info on this? Better 0-60 times or does it just feel better sitting in the drivers seat?
GED68 is offline   Reply With Quote
Old 06-22-2012, 02:55 PM   #31
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
Fantastic read! I plan on switching out the bushings as well. Mine will be a DD with occassional (no more than a dozen times a year) track use for the first 3-4 years of ownership but eventually it'll be relagated to track duty only. I'm concerned over those LCA's however, once the new bushings go in with them being so pliable. For those track days I'd like to avoid as many nightmare experiences as possible
"Sweet Subaru, sweet Subaru, send your BRZ unto me, for the roads of the unworthy must be baptized in speed and glory." ~Zaku
SVTSHC is offline   Reply With Quote
Old 06-22-2012, 02:58 PM   #32
AVOturboworld
Don't make any mistake here, it doesn't add an ounce of power. It just reworks the throttle mapping (via voltage) for far better response (or far less if you use the "inclement conditions" settings). The main benefit is to get rid of that initial hesitation, and to give the throttle a quicker, more linear feel.
Old 06-22-2012, 03:11 PM   #33
Toy86
Toy86's Avatar
Drives: 2013 VW Scirocco R
Great write up, Thanks so much - Subscribed!
Toy86 is offline   Reply With Quote
Old 06-22-2012, 03:15 PM   #34
Nardi330
Nardi330's Avatar
Drives: 86
Can u please share how and where u mounted the harness?
Thanks
Nardi330 is offline   Reply With Quote
Old 06-22-2012, 03:30 PM   #35
RaceR
Drives: 2010 Cooper S, 74 Beetle
The best thread I have come across in regards of tuning experiences!
THANK YOU!
Please share future findings and information!
RaceR is offline   Reply With Quote
Old 06-22-2012, 03:40 PM   #36
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Nice to see you here Paul! I had a few your your products on my LGT...
Opie is offline   Reply With Quote
Old 06-22-2012, 05:09 PM   #37
YeloFva
YeloFva's Avatar
Drives: 2006 Subaru STI
The overall impression was still excellent, with great response at the track and clearly superior cornering compared to, say, an STI. Light weight and an ideal balance will do that for you.
Gasp!
I can't wait to test drive one!
2006 Aspen White Subaru STI
YeloFva is offline   Reply With Quote
Old 06-22-2012, 06:30 PM   #38
EvoTME
Drives: vw polo gti
What will be the goal of this car? Will it be a fully stripped down track car or something that could also be used on daily driving? Which is your targeted tsukuba time? Dyno of the stock car?
iThank you for the answer and great post!
EvoTME is offline   Reply With Quote
Old 06-22-2012, 07:28 PM   #39
SnapOv3st3r
Drives: 400whp Scion tC
Originally Posted by AVOturboworld View Post
Yes, thinner/lighter. There's a certain logic about it - the car is lighter, so they feel they can make the components lighter. But if you are going to be tracking the car heavily like we are, we don't have confidence they'll hold up to the stresses of traction generated by bigger, stickier rubber.
Paul Hansen
www.avoturboworld.com
www.facebook.com/BRZSportsCarClub
That's good to know. Car is crazy light for RWD, but a little weight in the form of beefier components sounds like a good idea.
SnapOv3st3r is offline   Reply With Quote
Old 06-22-2012, 08:11 PM   #40
AVOturboworld
While it's mostly going to see track duty, we aren't going to strip the interior out - going to keep it DD enough to drive to and from the track. It's a R&D platform for our parts development, and developing parts that only work in a race environment would leave out 90% of the market.
Old 06-22-2012, 09:40 PM   #41
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Updates from the Option 2 magazine event, with Orido driving:
We fitted our 18mm solid rear bar halfway through to see how that would affect the handling. Unfortunately, not in a good way - it was nearly a second slower than with the standard rear bar. Orido said it was initially quite entertaining, the rear end would drift through nearly any sort of corner, but also quite twitchy, and ultimately harder to get through the course fast.
What we found so far is that, with the perfect 50/50 balance of the car from the factory, putting on a larger rear bar only, or a larger front bar only, will just upset that balance. Subaru/Toyota really did a good job of setting up the car out the door. Any swaybar upgrades need to be very carefully balanced front to rear, or you'll upset the balance, and ultimately, grip.
Excellent writeup and followup observation. Praise to Toyota/Subaru engineers for making it hold its own in balance! Will you guys be tweaking with which front and rear swaybar setup will better the stock setup?
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 06-22-2012, 09:51 PM   #42
AVOturboworld
We'll definitely be working out new front/rear swaybar sizing for better track performance, but that will take some time.
I've had some questions towards the alignment specs, here's what we have them at now.
Front Camber: -2.5°
Front Caster: +5.5°
Front Total Toe-in: 10 minutes (Japanese measurement, not degrees)
Rear Total Toe: zero
Rear Camber: -1.3° (max available) wasn't too bad tire temperature wise.
We used the factory seat belt mounts for the harness - we didn't have much choice at the time, we need to build a half cage to mount it up properly. At this time, the harness was mainly to keep the driver in place more than for crash safety.
Element Tuning Track Tested and Track Proven FRS Video Element Tuning Tracking / Autocross / HPDE / Drifting 47 07-17-2012 05:12 PM
$110 Track day at Willow Springs- Big Track -May5 in SoCal Louie Southern California 3 05-04-2012 02:05 AM
$110 Track day at Willow Springs- Big Track -March24 in SoCal Louie Southern California 1 03-10-2012 02:31 AM
$85 Track day at Willow Springs- Big Track -Feb 18 in SoCal Louie Southern California 0 02-12-2012 04:09 PM
$109 Track Day@WillowSprings-Big Track-August 13-14 in Socal Louie Southern California 1 07-26-2011 05:34 AM
