Old 02-21-2021, 02:40 AM   #29
Compelica
Compelica's Avatar
Drives: 86 GT
Originally Posted by serialk11r View Post
Ah crap, I don't have the image anymore. Take a flashlight and study the mechanism that the slider latch handle/bar attaches to, you should find a tab that it's supposed to rest on. When the car is moving and bouncing, the latch will bounce around on it because it doesn't have enough spring tension. If you glue something soft there, it will stop rattling.
Thanks! I think I've got it - will grab a picture of the solution in a bit
Edit: solution in the link below.
https://www.ft86club.com/forums/show...8&postcount=14
Compelica is offline   Reply With Quote
Old 02-21-2021, 11:15 AM   #30
ermax
ermax's Avatar
serialk11r's FR-S
Ending thoughts, I really wish I could take an MR2 or Cayman to one of these. The FRS is really not that grippy overall, and mid-corner at least on my car I found that between letting off the throttle and barely touching it is the range you get to play with if you don't want a big drift. I like how the throttle plays a much bigger part in a rear heavy car.
Pictures to come.
Everyone walks away from their first autox blaming the car. The Twins kick ass at autox. No offense but drive is always to blame after your very first autox. My suggestion to most people just starting is to let an experienced driver do a run in your car. That will keep you from blaming the car so you can focus on driver mod.
As for not being grippy, OEM tires are a joke. I’m not sure what you are running on yours but a set of just about any performance tire will obliterate the OEM tires.
Edit: just realized this was a really old post. Hahaha
Old 02-21-2021, 11:35 AM   #31
serialk11r
Drives: '06 AM V8V Coupe
Oh yea no doubt I'm a terrible driver, I was actually talking about the "fun factor" though. Because an MR2 is so much more twitchy and dangerous, it's more fun to slide (and more dangerous). In fact, I crashed my 2nd MR2 at Laguna Seca because I'm so bad at driving XD
In either car, I would not be able to put up a good time, but I find the FRS less fun because the front end pushes, instead of inertial oversteer (which again, is dangerous, but that's kind of what makes it fun).
