Old 05-21-2015, 01:54 PM   #29
gramicci101
Off Topic
Is the torque dip really that big of a deal?
I ask this while fully admitting I have no history of car ownership apart from the bathtub I currently drive. From my point of view, this will be a big upgrade and wouldn't mind since I don't plan on tracking or anything like that.
Not really. If you need to get somewhere, you'll be above it. If you're just cruising in that rpm range, there's still enough oomph to get up and go, just not as much as if you were to downshift.
If it really bothers you after you've been driving the car for a while, a stage 1 flash minimizes it, and a stage 2 flash with header completely eliminates it.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
soulreapersteve (05-21-2015), Tcoat (05-21-2015)
Old 05-21-2015, 03:29 PM   #30
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I don't understand how some of you guys haven't noticed the torque dip. It's always been pretty noticeable to me right after I hit 3k RPM's. A header and tune will probably be my next mod to kill it completely. As far as the chirps go, they're pretty much inevitable if you're running E10. Unless Toyobaru completely redesigned the fuel pump, which I highly doubt.
smg1138 is offline   Reply With Quote
Old 05-21-2015, 05:19 PM   #31
Ann1ne
Ann1ne's Avatar
Drives: 86 MY15 Satin White AT
E10, a fuel mixture of 10% anhydrous ethanol and 90% gasoline sometimes called gasohol.... avoid this thing and you wont notice the torque dip and criquets.
The D4S injection accepts but was not made for this
Ann1ne is offline   Reply With Quote
Old 05-21-2015, 05:28 PM   #32
cycleboy
Drives: 2013 Scion FR-S - Argento
Even though I've pointed out in this thread that I do notice the torque dip, it really is not a big deal to me. Noticeable, yes. If I was drag racing, it'd be a problem. Driving around and enjoying twisty roads with no stops, it's hardly there. I am surprised that people say they don't notice it, particularly when starting from a stop.
As for using ethanol-free gas, that's great for those of you that can do so. We don't have that option here.
cycleboy is offline   Reply With Quote
The Following User Says Thank You to cycleboy For This Useful Post:
Tcoat (05-21-2015)
Old 05-21-2015, 05:46 PM   #33
smg1138
smg1138's Avatar
That's the first I've heard that. Do you have any sources on that info?
Old 05-22-2015, 03:17 PM   #34
Ann1ne
Ann1ne's Avatar
Wiki
http://en.wikipedia.org/wiki/Common_...es#E10_or_less
Old 05-22-2015, 06:36 PM   #35
smg1138
smg1138's Avatar
I meant in regards to the D4S injection on the twins. I guess it makes sense that it was designed to use pure gas. Especially considering ethanol isn't even used in in Japan.
Old 05-22-2015, 06:44 PM   #36
Tromatic
No. Half the fun of this car is driving it well despite its "limitations". Half the people who complain about it can't go a day without bitching about something and the other half suck at driving, IM respectfully submitted O. If you are doing any sort of hooning at all, it's just not an issue. Seeing angry faces in the mirror of much "better" cars when they can't loose you in the turns is where the fun is.
ETA: My "criquets" (make them seem classy!) only ever die completely when running E85. I use a pump lube as well, and it's hit or miss with regular gas and e-free. FWIW, Shell gas is by far the worst for crickets. No idea why. I think it's cavitation in the pump, but I have no idea why some fuel does it and some does not.
Tromatic is offline   Reply With Quote
The Following User Says Thank You to Tromatic For This Useful Post:
soulreapersteve (05-22-2015)
Old 05-22-2015, 07:31 PM   #37
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
Originally Posted by Shady195 View Post
I NEED THIS SHIRT
http://www.cafepress.ca/mf/78629879/...ctId=855503804
Chad86 is offline   Reply With Quote
Old 05-22-2015, 10:58 PM   #38
cycleboy
That's funny because for me, Shell has kept them quiet most of the time.
Old 05-23-2015, 12:40 AM   #39
FRSupra
FRSupra's Avatar
Why does everyone make the HPFP noise into a negative thing? It adds character to this car.
FRSupra is offline   Reply With Quote
The Following User Says Thank You to FRSupra For This Useful Post:
Ultramaroon (05-23-2015)
Old 05-23-2015, 01:36 AM   #40
Ultramaroon
not playing cards
Ultramaroon's Avatar
It's really cool at meets when 10 or 15 of them are all chirping together.
Old 05-23-2015, 02:06 AM   #41
Aozora.BRZ
Aozora.BRZ's Avatar
Drives: '15 WRB Series.Blue
'15 with 8k miles. I only got a mild case of crickets that comes and goes depending on the gas level I use. Torque dip is there but not the end of the world.
Aozora.BRZ is offline   Reply With Quote
Old 05-23-2015, 02:32 AM   #42
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Unless you are tracking or racing you should barely notice it (if at all) during regular driving.
that's B.S. Just the other day coming home from work i was trying to pass a Prius and he sped up just as my tach was moving into the 'dip' zone, which forced me to downshift and edge past him at 35 mph. Without the torque dip, I could have taken him at 30.
shiumai is offline   Reply With Quote
