Old 04-30-2015, 10:34 PM   #29
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Originally Posted by jdp530 View Post
I couldn't resolve the ECU data issues even with the help of the AIM guys so I am returning it so they can check it out. I had the latest software and firmware updates. AIM customer service looked at the screens and couldn't see anything wrong with config.
It's likely the cable or the obdii port in the car.
I would see if I could borrow an obdii scanner to see if the port is working before shipping it back.
Mike
AZP Installs is offline   Reply With Quote
Old 04-30-2015, 10:57 PM   #30
jdp530
Drives: 2014 BRZ
Mike, I used a friend's Solo a few months ago and his unit worked fine in my car so I dont think its the ECU connection. I could have waited until the weekend and tried mine in someone else's car but I decided to send it in today to save some time.
jdp530 is offline   Reply With Quote
Old 05-06-2015, 10:06 PM   #31
jdp530
Drives: 2014 BRZ
I got a call from AIM this evening and there is a problem with the CAN bus on my Solo DL so they are sending out a new unit to me today.
The Following User Says Thank You to jdp530 For This Useful Post:
CSG Mike (05-06-2015)
Old 05-06-2015, 10:22 PM   #32
AZP Installs
Glad to hear they got to the root of the issue.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
Old 05-13-2015, 11:17 PM   #33
jdp530
Drives: 2014 BRZ
I got the replacement Solo unit today and plugged it into car and drove around neighborhood. This unit is working correctly and picking up ECU data. Thanks AIM!
The Following 2 Users Say Thank You to jdp530 For This Useful Post:
CSG Mike (05-14-2015), gkubed (02-02-2019)
Old 05-31-2015, 05:28 PM   #34
jdp530
Drives: 2014 BRZ
Changing unit of measure
Can units of measure for speed or temps be changed after tests have been run? I have all the units set up on Race Studio the way I want them but I see that units of measure after event yesterday are different. So I am wondering if I can change them in the RS2Analysis program. Thanks,
Old 05-31-2015, 07:31 PM   #35
Unfortunately, no. The Solo DL is taking the raw output from CANBUS, interpreting it (converting it) into the unit of your choice, and then recording that interpreted number.
You *can* open the file raw and run a macro to change the units, but you're probably better off printing out a quick conversion table for the units you're trying to convert, when you're looking at data.
When you do the device configuration, make sure you set everything the way you want (units, decimal places, etc.), and then upload it to the Solo DL. Make sure you pull your data from the unit first, as reconfiguring wipes the unit!
Old 05-31-2015, 07:55 PM   #36
jdp530
Drives: 2014 BRZ
Thanks, Mike! I did have units set up in configuration so I don't why they would have changed. I will look at config again and download it to the Solo. How many decimal places do you use?
I am using the Ram mount on quarter window on driver's door with the Solo tilted towards me so GPS results aren't accurate. Max longitudinal accel was .97! I will try mounting unit square with the car from side window, recalibrating it, and see if that works better.
Old 06-01-2015, 11:43 AM   #37
ubernostrum
Drives: 2013 Subaru BRZ Ltd GBS 6MT
Is it possible for the SoloDL to indicate when ABS is engaging? Either on the unit itself or afterwards when reviewing the data in RaceStudio? The documentation says it does not pull the ABS activation channel for our car like it does with the Miata, but can it be inferred by the brake pressure channel?
ubernostrum is offline   Reply With Quote
The Following User Says Thank You to ubernostrum For This Useful Post:
GSpeed (07-19-2015)
Old 06-14-2015, 09:32 PM   #38
jdp530
Drives: 2014 BRZ
Is it possible to install a oil pressure sending unit so that pressure can be seen on the Solo DL thru the OBD2 port?
Old 06-14-2015, 10:29 PM   #39
Negative.
Old 06-15-2015, 02:52 PM   #40
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
there's a lap comparison tool that lets you see in real time the relative positions of two laps, really need when comparing two drivers.
is there a way to export this as video or gif or something?
Old 06-17-2015, 10:05 AM   #41
enivid
enivid's Avatar
Drives: WRB JR BRZED
I'm wondering this as well. How do I tell where I'm engaging ABS when looking at the logs?
enivid is offline   Reply With Quote
The Following User Says Thank You to enivid For This Useful Post:
GSpeed (07-19-2015)
Old 06-17-2015, 01:47 PM   #42
Any screen capture app, such as Adobe Captivate.
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
SCCA Socal Solo 2 at El Toro, Socal, 3/22-23, noob questions JB86'd Tracking / Autocross / HPDE / Drifting 52 03-29-2014 04:00 AM
Wax Sealant Pad Questions / Care Questions l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-25-2014 11:19 AM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
