Old 12-27-2019, 03:29 PM   #29
Gamace
Gamace's Avatar
Drives: 2012 Toyota 86
Are you not able to order parts through a dealer there?
Well I tried one dealer but they referred me to their special parts order department which im waiting to hear from.
Other Businesses are closed today until Monday. So I wanted to try and see if there were stores online that had them in the interim. Oh I'm in Jamaica by the way .
Sent from my SM-N975U1 using Tapatalk
Gamace is offline   Reply With Quote
Old 12-27-2019, 03:46 PM   #30
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yeah. That's why I asked. I see only a couple Toyota dealers. I'd just reinstall the old one while waiting for the replacement to arrive. Just be really careful about backing up.
https://parts.toyota.com/p/Scion_201...U00300821.html
Old 12-27-2019, 04:20 PM   #31
Gamace
Gamace's Avatar
What I did, or my mechanic rather, as a quick fix was to install an additional washer to the switch which enables it to be sunk fully when the Reverse Gear touches the Switch. We did that quick fix today and it works now but I still need a new switch to permanently get it fixed again. I will check out this link that you provided though. It seems to be it.
Thank you very much for the assistance though!
Old 11-30-2020, 07:53 AM   #32
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
What's the location of this switch? I think I have the same issue.
Sent from my Pixel 4 XL using Tapatalk
Rican_D is offline   Reply With Quote
Old 11-30-2020, 01:11 PM   #33
Joon525
Joon525's Avatar
Drives: 2016 BRZ
https://demos.starbase7.net/t3Portal...modelyear=2016
Joon525 is offline   Reply With Quote
Old 11-30-2020, 01:12 PM   #34
Rican_D
Rican_D's Avatar
Thanks
Old 11-30-2020, 02:19 PM   #35
Rican_D
Rican_D's Avatar
Just went under the car. Looks like a bitch to get to. How did you guys do it?
Old 11-30-2020, 02:58 PM   #36
e1_griego
e1_griego's Avatar
Drives: Many
I did it from up above, just reaching back.
It's not super fun.
e1_griego is online now   Reply With Quote
Old 11-30-2020, 04:28 PM   #37
Rican_D
Rican_D's Avatar
It's not super fun.
Yeah I can tell
Old 12-01-2020, 07:01 PM   #38
Rican_D
Rican_D's Avatar
It's not super fun.
No way I can get my arm in there lol.
Old 07-19-2021, 03:00 PM   #39
BleedingRust
Drives: BRZ S
Would an extra washer make the button further away? I would assume he grid down the shoulder of the sensor? I am having a similar problem i think. My indicator shows fine but my lights only show if I wiggle the shifter.
BleedingRust is offline   Reply With Quote
Old 07-19-2021, 05:02 PM   #40
Ultramaroon
not playing cards
I wondered about that too. Didn't want to make it a thing. It might be like the door switches where the circuit is closed upon release. Then adding the washer makes sense. We can check the wiring/circuit diagrams to verify. Look for the manuals in my sig line. I'll study them after work today. The disagreement between reverse indication, and lights would make sense if the indicator latches electronically between reverse and neutral. Then, even a momentary reverse signal would not be cancelled until switching back to neutral.
Old 07-20-2021, 12:27 AM   #41
BleedingRust
Drives: BRZ S
Thanks Ultramaroon. I will try to hook up a multimeter on the sensor after work. If it's open when not in reverse then i know it's opposite of a door switch. Really bugs me that no one can see me back up. I thought it was the reverse cam but i noticed my back up lights are also not on when it reads no signal. My gear indicator works just fine so I figure it's the switch. It intermittently works when I jiggle the shifter and flickers when in motion. I am pretty sure it's either out of adjustment or just worn out. I will report back once I find out.
Old 07-20-2021, 01:43 AM   #42
Ultramaroon
not playing cards
It's normally open - opposite of a door switch. Just looked it up. Washer would not have worked.
https://gt86stuff.onrender.com/t3Por...017MP03IX.html
FR-S / BRZ Reverse/Backup LED Bulbs! See Comparison Photos, Ships Same-Day! Diode Dynamics Exterior Parts - Lighting 72 11-30-2021 02:19 PM
Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! Diode Dynamics Exterior Parts - Lighting 192 10-04-2017 11:51 AM
Reverse gear signal on factory HU harness? Panman Electronics | Audio | NAV | Infotainment 2 01-24-2014 10:24 PM
Interior LED + Reverse backup package? Intake Scion FR-S / Toyota 86 GT86 General Forum 1 07-12-2013 11:46 AM
Radio Signal Issue When shifting into Reverse ruskymx Scion FR-S / Toyota 86 GT86 General Forum 13 01-22-2013 09:05 PM
