Old 04-17-2015, 01:41 AM   #29
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
http://www.ft86club.com/forums/showp...19&postcount=7
I have been happy with my Nexus 7, Torque app and Bluetooth ODB2 sensor method, it is way cheaper than the AIM solo option but pf course AIM solo is more comprehensive unit but TBH never needed one.. I also use GoPro and my cell phone app for track data and some new lap timer apps can also merge engine data if the RPM gauge and few other things are very important
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
yomny (04-17-2015)
Old 04-17-2015, 08:03 AM   #30
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Just got my obd2 wifi elm thing and tested it with a free iOS app and it worked great, right off the bat, with oil temps and all. I'll opt for the paid version which is supposed to be better. To keep an eye on temps I'd say a cheaper alternative like this is more cost effective. Thanks!
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
glamcem (04-17-2015)
Old 04-17-2015, 02:37 PM   #31
glamcem
glamcem's Avatar
You may be able to set alarms and etc, Torque app didn't have the PID for the oil temps so I had to manually edit the app to include the parameters..
What kind of app is that you installed in ios?
Old 04-17-2015, 03:45 PM   #32
yomny
yomny's Avatar
Its called EOBD- Facile, looks a bit cheap but then again its free lol. Probably end up getting either dash command or fusion for $10.
Old 04-17-2015, 03:52 PM   #33
ddeflyer
Hard to be an Aim Solo DL for a fairly stock 86. If you need more sensors though it becomes lacking. At this point I am trying out a "Race Capture Pro v2" on my spec miata so I can have analog channels.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 04-22-2015, 11:12 AM   #34
jflogerzi
jflogerzi's Avatar
Use an old Samsung gs3 Bluetooth odb2 adapter. This along with torque. I only monitor 2 things. Oil and coolant temps. Then i use the phone to track lap times. Its cheap and works decently.
2013 Series 10 FRS #553
Old 04-22-2015, 01:26 PM   #35
strat61caster
strat61caster's Avatar
Is it possible to get oil temps from Harry's Lap Timer? I know it's unlikely but it's really the only thing it's lacking for me.
Might have to compromise and use torque for the first few runs than switch to Harry's once I'm confident that the car is safe and I'm hunting for speed.
ineedyourdiddly
Old 04-22-2015, 01:31 PM   #36
jvincent
jvincent's Avatar
Yes, HLT provides oil temps. It was added late last summer.
Old 04-22-2015, 01:42 PM   #37
stugray
Drives: 2013 GBS BRZ Limited
I have used torque with the ELM327 bluetooth ODB reader.
I also have a traqmate with the camera, but it cannot read very many engine parameters and cannot do it over OBD (it uses analog inputs).
For my 71 vintage racecar I built my own datalogger from scratch.
It logs: Tach, 2XEGTs, 2XCHTs, AFR, Fuel pressure, oil temp & pressure & throttle position. it writes it all to a micro-sdcard or can display it realtime on a droid phone.
I plan on adding GPS & accelerometer data next.
Total cost was ~$300 in parts.
It can also monitor any of those and turn on the dash warning light if any go out of range.
Cool thing was at the track last weekend, I felt the car loosing power so I brought it in and looked at the data.
I could immediately tell that my AFR was tredning higher & higher and one of my EGTs dropped abruptly by 1000 degrees.
Pulled the main jets and sure enough - cyl #3 jet was clogged completely.
This was just minutes after a longtime "racing expert" was telling me that logging data was a waste of time :-)
Old 04-22-2015, 02:43 PM   #38
Pat
Pat's Avatar
Drives: 2023 BRZ
I know very little about data logging, but here is a new option for Android users:
[ame="http://www.amazon.com/Kircher-Electronics-Force-OBDII-Performance/dp/B00MI5GE5A?tag=viglink28253-20"]Force OBDII[/ame]
Disclaimer: this was developed by a friend of mine. I think he's a pretty bright guy and knows his stuff. That said, I don't have significant experience with data logging, so if you guys have any opinion about it, I'd love to hear it.
Old 04-22-2015, 03:12 PM   #39
Force OBDII
If he can get me a limited evaluation license (lets say... 30 days), I'll be more than happy to give him my feedback.
Old 04-22-2015, 04:05 PM   #40
strat61caster
Mind posting up how to get to it? HLT is not very intuitive for me to navigate.
I know the community had to develop a custom PID for Torque to work with the Toyobaru's sensor.
ineedyourdiddly
Old 04-22-2015, 04:26 PM   #41
jvincent
jvincent's Avatar
IIRC it just appeared on the display. I can check later.
Old 04-22-2015, 05:46 PM   #42
jvincent
jvincent's Avatar
Here you go. I just went to the car, started it up, launched HLT, waiting for everything to connect, and then hit the "start driving" button. This is what I see.
The Following User Says Thank You to jvincent For This Useful Post:
strat61caster (04-23-2015)
Datalogging 2nd gear pull? 1Cor10:23 Software Tuning 11 04-04-2014 01:42 AM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Datalogging Suggestions Shiv@Openflash Forced Induction 12 02-05-2014 02:31 AM
EcuTek Datalogging Question xxscaxx Engine, Exhaust, Transmission 8 05-24-2013 12:31 AM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 06:46 PM
