Old 04-06-2015, 10:29 PM   #29
steve99
Originally Posted by spatcha88 View Post
I haven't tried cleaning my throttle body at all yet. I'm going to try just resetting the battery.
TSB for brz idle stability will be equivalent one somewhere for frs\86.
if its been reflashed it should have sticker in engine bay or read calid with obd scan device. Resetting ecu wont fix anything other than clearing cel codes.
http://www.ft86club.com/forums/attac...1&d=1395947828
Old 04-07-2015, 08:07 PM   #30
spatcha88
Drives: 2013 Scion FRS Whiteout
Originally Posted by muffinz View Post
Does it happen 100% of the time or only when the A/C is on?
my car doesn't do it at all unless the A/C is on...
basically the compressor kicks in during the slow down with the clutch engaged (aka 0% fuel injection) and it makes the RPMs drop past idle causing it to stutter for a second before the car reintroduces fuel.
I wouldn't worry about it if this is the case.
This does this all the time when the AC is off and when it's On as well. I hardly ever use my AC btw. I disconnected my battery overnight to do a HARD reset. The problem went away as of Sunday and going to work Monday Morning. Felt how it should normally feel. Since I left work yesterday afternoon and leaving to and from work today the problem came back. Coming to a stop i get an idle shake and drop about 200 rpm which leads me to believe it's an ECU issue. So answer is it does this 100% of the time :|
spatcha88 is offline   Reply With Quote
Old 04-07-2015, 08:08 PM   #31
spatcha88
Would you happen to know where in the engine bay that sticker would be?
Old 04-07-2015, 10:30 PM   #32
steve99
They can put them anywhere but should be pretty obvious, only 100% way to know the calid of ecu revision is to read it from ecu with torque or obd scanner ect.
Old 04-09-2015, 08:01 PM   #33
Bader
Drives: 2013 WRB BRZ
How is your cold start. Do you feel vibrations from the engine bay?
Bader is offline   Reply With Quote
Old 04-12-2015, 02:34 PM   #34
AustinG
Drives: '15 Halo FR-S, '95 240SX Turbo
no no, you said ft first but I don't know what that means.
I think he's referring to 'FT'86Club.
AustinG is offline   Reply With Quote
Old 04-12-2015, 02:47 PM   #35
Ultramaroon
not playing cards
Ultramaroon's Avatar
Oh! Haha.... Thanks! God, that was awkward.
Old 04-12-2015, 03:41 PM   #36
Fnbeast86
Drives: Firestorm red fr-s
I told my dealer to make sure it had the latest flash he laughed at me and said that's not the problem it's the fuel pump
Fnbeast86 is offline   Reply With Quote
Old 04-20-2015, 09:30 PM   #37
Estey
Drives: Scion FR-S, Ultramarine
hahaha, damn the confusion just wont end
Estey is offline   Reply With Quote
Old 04-20-2015, 10:29 PM   #38
Ultramaroon
not playing cards
lol
Old 04-21-2015, 07:27 AM   #39
rinnamon
Drives: Toyo
Does anyone know if there actually is a tsb for scion? I went to dealer and they didn't find one .
rinnamon is offline   Reply With Quote
SOLVED: Idle Dip only when coming to a stop? spatcha88 Issues | Warranty | Recalls / TSB 38 04-14-2015 12:16 AM
Do you ever feel like an asshole for coming to a complete stop? Ozzman Off-Topic Lounge [WARNING: NO POLITICS] 53 01-20-2014 12:35 AM
Difficult to shift into first when coming to a stop ZackZ Scion FR-S / Toyota 86 GT86 General Forum 21 08-31-2013 12:05 PM
Shifter clicking when coming to a stop larryt1026 Issues | Warranty | Recalls / TSB 1 07-15-2013 07:34 PM
Single knock when coming to a stop oops86 Issues | Warranty | Recalls / TSB 14 08-05-2012 01:17 AM
