Old 01-12-2013, 09:40 AM   #29
Iddoit2er
Drives: S
Nitro, i just took the factory unit out and am about to put in a z140. it looks like theres one extra wire in the 6 pin connector. Did you find this? Is that for the amp?
Looking at your 6 pin connector, what is the orange wire for?
Iddoit2er is offline   Reply With Quote
Old 01-13-2013, 01:57 AM   #30
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
See this post (#20 there) about the power antenna and amp turn-on leads.
The extra orange wire on the aftermarket 6-pin Toyota harness is the illumination(-) lead in Subarus. This wire is not needed by aftermarket head units. If your aftermarket harness (Metra, Scosche, etc.) has that, either insulate the end, or extract the whole pin/wire.
You usually do want to use the illumination(+) lead, on the 10-pin harness.
Sometime soon I'll post a real pin-out table, customized for the BRZ and FR-S.
SVXdc is offline   Reply With Quote
Old 01-13-2013, 11:36 AM   #31
Iddoit2er
Drives: S
Thanks! I figured it out after i found a wiring legend. I even found the speed sensor wire.
Do you know if theres a reverse sensor wire? That wasnt on the wiring list i found.
Old 02-16-2013, 07:59 AM   #32
mbh1101
Drives: Raven 6mt FR-S
Installing my pioneer HU soon. Thinking about running the iphone cable into my glove box.
mbh1101 is offline   Reply With Quote
Old 02-24-2013, 10:43 AM   #33
HRTROB
HRTROB's Avatar
Drives: Toyota 86
If you're going to use the AppRadio mode, I wouldn't suggest running the cable to the glove box. When you switch to AppRadio you have to tap "Allow" on the iphone's screen.
HRTROB is offline   Reply With Quote
Old 02-26-2013, 03:08 PM   #34
mbh1101
I have a iphone 5 and the cable isn't out yet. Im just running the usb extension inside the glove box and mounting it there.
Old 03-13-2013, 09:41 AM   #35
vault
86TUP
Drives: 86 GT
great write up!!
The only thing i'm not too happy about is how far our the 2 din stereo sits with the factory brackets.
There doesnt seem to be any others on the market which solve this problem....unless ive overlooked it somehow
vault is offline   Reply With Quote
Old 09-08-2013, 10:22 AM   #36
Sewa
Drives: Subaru brz
Great write up, I will just add my 2c. The wiring in the BRZ (european spec, premium) seems a little different: the yellow cable on the metra connector (70-1761) does not match with subaru's connectors. It took me two days of hair pulling to figure this out. You have to remove matra yellow cable from the 6 pin connector and place it in the 10 pin connector in such a way that it connects to subaru's orange cable.
Hope it will help someone.
S.
Sewa is offline   Reply With Quote
Old 09-08-2013, 08:26 PM   #37
sufu05
Drives: Scion FR-S
Any body looking to get this head unit? I have everything you need. head unit, wire harness already connected to metra harness, gps antenna, the inserts around the head unit to fit the fr-s dashboard, the parking break relay. I bought this setup and then broke my iphone which is the whole reason i got this setup. I got a droid and just dont like how it connects with my droid. Asking $350 shipped. Pics to come tomorrow
sufu05 is offline   Reply With Quote
Old 09-10-2013, 10:44 PM   #38
ralpho
ralpho's Avatar
Drives: scion frs
bespoke radio
i have the base radio in my car im looking to get a bespoke radio any thing special i have to do?
does the bespoke radio come with nav? if yes any special antenna?
ralpho is offline   Reply With Quote
Old 07-12-2015, 10:02 PM   #39
kthxbai
kthxbai's Avatar
Drives: '13 Whiteout FR-S M/T
Sry to raise this thread from the dead. I followed it and got everything working except the parking brake bypass (PAC TR7). Hook black to black, red to res, white to lime green (ebrake), and green to blue/white stripe. Is there anything additional I need to do to get this working?
kthxbai is offline   Reply With Quote
Old 07-13-2015, 01:50 AM   #40
DieselDog
Shift it or lose it
DieselDog's Avatar
Drives: 2014 FRS, 2003 Celica GT
http://www.pac-audio.com/PACProductD...arine-Mode.pdf
You need a relay.
DieselDog is offline   Reply With Quote
Old 07-13-2015, 08:41 PM   #41
kthxbai
kthxbai's Avatar
Originally Posted by DieselDog View Post
Thank you for sharing the info. I am going to head out and pick up a relay tomorrow!
Old 07-02-2016, 11:02 AM   #42
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Just installed the pioneer avh-4200nex and used every thing in this write up he used. The only thing is my Sirius Xm is not even able to be selected now. Am I missing something to hook up to the oem Xm radio satellite?
tofurun is offline   Reply With Quote
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
Subaru iPod Connector Cable? Kimsey47 Audio/Visual, Electronics, Infotainment, NAV 25 07-05-2012 02:49 PM
BRZ Nav Unit owner's manuals eikond Electronics | Audio | NAV | Infotainment 0 04-11-2012 04:07 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
