#29 |
Drives: 2015 BRZ Limited 6MT
#30 |
Maybe it's just in my head because from what I saw when the installer showed me there was only a tiny bit of clearance when he carefully mounted the wheel onto the Hub just as a test fit...
I'm not really sure what to look for and with my exhaust it makes it hard to sense rubbing if its based on hearing things |
#31 | |
Time Traveller
So the easiest way to know is to listen for it. Rubbing will generally be kind of obvious because it will be a grinding sort of noise that changes with the speed of the rotation of the wheel. The other way is to inspect the inside of your plastic fender liners after about 100 miles of driving, you will see a spot in the plastic that looks marred in the direction of the wheels rotation (think of a pencil eraser that's only been used on one side, it gets rubbed flat on that side, the mar would look kind of like that, flat and smooth). |
#32 | |
#33 | |
Aloha!
I wanted to also make it flush with the fender. Is the extended bolts necessary for the 15mm spacers? |
#34 | |
Time Traveller
| Michelin Pilot Super Sports | TimR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 64 | 06-10-2017 03:35 PM |
| F/S: 18"x8" Avarus AV-8 Matte Black wheels w/Michelin Pilot Super Sports | Opie | Wheels and Tires | 5 | 04-09-2014 08:35 AM |
| FS: Work XD9 with Michelin Pilot Super Sports | truenosan | Wheels and Tires | 1 | 08-02-2013 11:22 AM |
| FS: Work XD9 with Michelin Pilot Super Sports | truenosan | Canada Classifieds | 0 | 07-31-2013 11:27 AM |
| Michelin Pilot Super Sports Warrenty? | FLASCH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 05-11-2013 10:39 PM |
