Old 03-27-2015, 04:19 PM   #29
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Although removing it is nice, the spring is NOT the main issue.
Well the main issue is that our current setup has too much leverage over the clutch right? So this reduces some of that leverage, so why not? :P
Will try this when I finally get a spare weekend with my car.
PandaSPUR is offline   Reply With Quote
Old 03-27-2015, 05:31 PM   #30
Ultramaroon
not playing cards
Ultramaroon's Avatar
Oh, I wholeheartedly endorse removing the assist spring. I did it right after swapping out my slave.
Technically, removing the spring does not change the leverage. The clutch will be a little stiffer and you will gain back the linearity of the clutch springs against your foot.
It's still vague as shit because it's such a loooooong arc.
Koa (04-01-2015)
Old 03-28-2015, 01:49 AM   #31
housecat
Computer Scientist
housecat's Avatar
Drives: 2014 BRZ Limited
Talking
HUGE TIP for anyone removing the spring once they remove the pin. With the clutch pedal not being pushed down, place a screwdriver or something stiff behind the clutch pedal so that it pushes on the spring when you push the clutch pedal down. Now all you have to do is push the clutch pedal down hard enough that the spring is pushed out (from behind the pedal towards the seat) by the screwdriver that is obstructing the way. Also, the spring didn't go flying when I tried this which I was afraid of.
Anyway, here's my results. This is the BEST thing I've done to my BRZ yet. And it was free! I've never driven my car with a bigger smile on my face. Shifting through the gears feels so good and natural now. Getting the car going from first gear and reverse is so trivial now. There's no more guessing where the clutch engagement point is. I can FEEL it now. I just want to drive my car everywhere now, it's amazing how much of a difference in driving enjoyment there is! My car actually feels faster after doing this, probably because I'm more focused on driving instead of the dumby clutch pedal. Who's idea was it to put a spring on the clutch pedal anyway?
One more thing I wanted to mention. I've only got to drive once since removing the spring, but while driving there was an odd rubbery smell in the car that I've never smelled before. I was afraid the clutch was slipping and burning, but that doesn't make sense. I think it was just coincidence, maybe there was something in the air outside that I was smelling. Was wondering if this happened to anyone else.
Keep calm and drive safe
housecat is offline   Reply With Quote
The Following 2 Users Say Thank You to housecat For This Useful Post:
jcw99 (03-28-2015), Kronos (04-23-2015)
Old 03-31-2015, 01:38 PM   #32
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
The original thread that details this mod is pretty old now and was not posted in the DIY section, if I recall. This is one of the best mods you can do to our cars. Stop hating your clutch and spend the 10 minutes doing this and I promise you, you will be a very happy driver
Also, if doing this, I would strongly recommend lowering the pedal at the same time: http://www.ft86club.com/forums/showthread.php?t=8040
xxBrun0xx is offline   Reply With Quote
The Following User Says Thank You to xxBrun0xx For This Useful Post:
keithr (03-31-2015)
Old 03-31-2015, 01:55 PM   #33
keithr
keithr's Avatar
Drives: 2014 BRZ Limited (DGM)
Thanks, I might give this a shot sometime soon, I just know that someday the clutch is going to have to be replaced and I wonder if I'll end up having to reverse this when that comes around...
keithr is offline   Reply With Quote
Old 03-31-2015, 03:44 PM   #34
Ultramaroon
not playing cards
Like @Koa suggested for us. Just keep the old one handy.
keithr (03-31-2015), Koa (03-31-2015)
Old 04-01-2015, 06:47 AM   #35
xxBrun0xx
xxBrun0xx's Avatar
You won't. 98% of manuals don't have this spring and it literally only affects the portion of the pedal sticking through the firewall.
Old 04-01-2015, 02:19 PM   #36
keithr
keithr's Avatar
Yeah, I was referring to @Ultramaroon 's suggestion to swap the slave cylinder.
The Following User Says Thank You to keithr For This Useful Post:
xxBrun0xx (04-03-2015)
Old 04-18-2015, 05:49 PM   #37
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Even tho I've gotten really used to the stock clutch i'm definitely trying this when I get a chance.
Great thread
Kronos is offline   Reply With Quote
Old 04-20-2015, 11:30 AM   #38
sato
sato's Avatar
Drives: Dodge Patitas
I did the modification about a week or two ago. Didn't notice that much of a pressure increase but definitely feels more like a clutch than a on-off switch. The engagement point is felt more easily, and modulation too.
Oh, and now my Camry's clutch doesn't feel like a truck clutch (when I change cars)
The Following User Says Thank You to sato For This Useful Post:
Kronos (04-20-2015)
Old 04-22-2015, 11:51 PM   #39
BRZ_STI
Drives: 2015 Blue Series Brz Sti
Thanks for the instructions they were very helpful! One question though, does your clutch have a bit of "play" before you put a lot of pressure on the clutch pedal?
BRZ_STI is offline   Reply With Quote
Old 04-23-2015, 10:02 AM   #40
rlpaul
Drives: point A to point C. Screw point B!
OK, so I spent like 20 minutes trying to wedge myself far enough under my dash to do this, but my shoulders are too wide. Pushed the seat all the way back, and can only get one arm in, without the needed leverage to get the c-clip off.
Any suggestions, short of removing the driver's seat? I suppose I could try (much) longer pliers. If I could get my left arm in, this whole thing would be a cinch.
rlpaul is offline   Reply With Quote
Old 04-24-2015, 12:59 PM   #41
Kronos
Kronos's Avatar
How To: Clutch Spring Removal in 15 Minutes
I've got the e clip and pin off but the spring won't budge still. How did you guys get the spring off?
Edit: never mind. I managed to get it off.
And wow what a difference. I've been driving with the spring for two years!
Old 04-24-2015, 02:14 PM   #42
Kronos
Kronos's Avatar
So did others reattach this piece? I took this piece, the spring, the pin and the e clip off and never reinstalled any of it.
Clutch return spring removal MikeyBRZ Engine, Exhaust, Transmission 186 09-16-2020 01:40 PM
Car dies after 15-20 minutes? PolishFrs13 Issues | Warranty | Recalls / TSB 28 10-08-2015 05:28 PM
Toyota 86 in 10 minutes. KKaWing FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 03-28-2013 10:06 PM
32 Hours 7 Minutes Wes B. Other Vehicles & General Automotive Discussions 11 12-26-2012 10:10 AM
How to hack a BMW and steal it in 3 minutes Dadhawk Other Vehicles & General Automotive Discussions 9 07-11-2012 01:11 PM
