Old 05-30-2015, 03:16 AM   #29
Bach415
Bach415's Avatar
Drives: Whiteout FRS
@Scott@HKSUSA Just wondering, is the sp's suspension suppose to make noise when going over speed bumps slowly? It sounds like when you jump on a old spring bed kind of sound.
Bach415 is offline   Reply With Quote
Old 05-30-2015, 04:40 AM   #30
troek
troek's Avatar
Drives: 2012 Toyota 86
i got this noise too when first installed, it went away after a while. i did alot of video watching trying to match the sound and i attributed it to bushings from it being lowered. it went away before i could definitively pin it down though.
Old 05-31-2015, 08:12 PM   #31
nzbrooke
Drives: 2013 Firestorm GT-86
Mine are doing this now too - but as noted above, mine have been on max hard for a few months, and are now on max soft, so guessing it will go away after awhile.
nzbrooke is offline   Reply With Quote
Old 06-01-2015, 05:04 AM   #32
Bach415
Bach415's Avatar
It doesn't sound like it's from the bushings though cause I had it on sportline (which is lower than what I have it now) and it didn't make those noises on sportlines. Maybe I'll attach my gopro in the wheel well then go over the bumps and see. I've had these since October and the noise is still there. Everything is tighten and checked. It might just be the spring compression/rebound.
Mine has been on full hard and full soft and right now is in between and still have the noise since install.
Old 06-01-2015, 09:11 AM   #33
Scott@HKSUSA
Scott@HKSUSA's Avatar
Drives: 2013 FR-S, HKS V2 S/C
Definitely not. There are only two things I can think of: A) you have a little rock or pebble stuck between coils or B) if you're compressing the spring a lot it may be twisting a couple mm on the perch.
Scott@HKSUSA is offline   Reply With Quote
Old 06-02-2015, 01:40 AM   #34
Bach415
Bach415's Avatar
Well, I doubt it is a pebble stuck between the coils because this sound happened right on first drive after the install (there's a small bump off my driveway onto the street). I'll check the compression of the spring when I get back from my vacation but I doubt it's that as well because I only move the perches to a snug fit with spring and tightened from there.
Old 12-08-2020, 08:15 PM   #35
3k1n
3k1n's Avatar
Drives: 2017 BRZ limited PP WRC Blue
Sorry for bringing this thread back. I'm getting the same clunking noises. Its largely due to front spring bind it seems. Anyone figure out how to fix it? Does hks offer a radial bearing option to upgrade?
3k1n is offline   Reply With Quote
FS: HKS HiperMAX GT IV Coilovers RyanITV Brakes, Suspension, Chassis 16 11-27-2014 02:06 PM
HKS HIPERMAX IV SP Special AlphaMotorsports.ca Canada Classifieds 15 08-22-2014 04:50 PM
HKS Hipermax IV GT vs KW V1 Stayreal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-17-2014 01:17 PM
FS: HKS Hipermax IV darthwong1138 Brakes, Suspension, Chassis 33 01-24-2014 09:04 PM
HKS HIPERMAX IV GT - Under $2200 from TAP Auto! TAP Auto Parts Brakes, Suspension, Chassis 5 06-06-2013 05:26 AM
