Old 02-27-2015, 11:21 AM   #29
AJPG
Drives: 22RE, FA20, 4G63
Please don't drill the valve cover!
Lol
AJPG is offline   Reply With Quote
Old 02-27-2015, 11:23 AM   #30
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Thanks! Hmm, looks like the drain line is being used as in, looking at the pump assembly. Is that right?
Tye300 is offline   Reply With Quote
Old 03-01-2015, 08:26 AM   #31
puma
crew chief
puma's Avatar
Drives: Race car FR-S
can you give a link to where you got that inline pump and filter? Seems like a fuel pump, works good with the oil too?
puma is offline   Reply With Quote
Old 03-01-2015, 08:31 AM   #32
AJPG
Good morning! It should last longer, now is lubricated.
It is Sunday, so today is fun day!!! As soon as I return to reality would seen you the link. [ATTACH]103575
Old 03-05-2015, 07:29 PM   #33
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
If the engine oil is contaminated enough to damage the SC, then I think the SC would be the least of ones worries.
Yes, turbos are a bit different than a centrifugal SC, but a turbo's oil cooling requirements are considerably greater.
I don't see any reason, if given the choice, to go V3 instead of V2 for a heavily track-driven car.
Sleepless is offline   Reply With Quote
Old 03-06-2015, 07:29 AM   #34
AJPG
1. Normal engine particulate could damage the gear side of the SC, now imagine... If the engine breaks the SC goes with it due particulate (mmmmm)
2. Correct turbo need more cooling capacity and work way hotter than SC (but there are some other differences)...
3. You could do the conversion to the V2 and use my setup OR you could keep the V3 well cooled and as soon it fails go to the V2.
4. Anyway is you car and your money, feel free to do what ever you consider is better, but keep in mind that I'm not selling anything so no hidden agenda here.
I was trying to contact vortech to get the parts for the bigger turbine (the one with 1150 CFM and 22 psi, but apparently they prefer that we send the unit...
That and the 2.88" would validate my set up... No luck
Old 03-07-2015, 08:05 AM   #35
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
In for more information on this cooler and pump. Are you selling it? If not can you provide the info needed to piece it together? Thanks
Sent from HTC M8 while in burnout mode
cruizin01 is offline   Reply With Quote
Old 03-17-2015, 02:08 PM   #36
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Getting supplied bung welded to valve cover is cake
Cost less than an hour
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
High performance Vortech at track Sonolin Forced Induction 41 03-18-2016 07:19 PM
Vortech SC - Leak & Loud Whine after Track (<6k) SonnyBRZ Forced Induction 37 05-14-2015 04:42 PM
DVSIDBOY - NWMotiv Project BRZ Track Build (Vortech / 2500lbs) dvsidboy Member's Car Journals 26 03-05-2015 01:55 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 12:45 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 06:46 PM
