Old 01-15-2015, 10:14 AM   #29
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Originally Posted by Calum View Post
One more question, please. What was the exhaust setup used for the dynos posted in the first post?
4-2-1
Header- http://aceheader.com/index.php/gt86-...-header-detail
Front Pipe- http://aceheader.com/index.php/gt86-...nt-pipe-detail
Mid Pipe- OEM
Muffler- ACE 160mmOD twin tip muffler (not released yet)
4-1
OP- http://aceheader.com/index.php/gt86-...er-pipe-detail
Mid Pipe- OEM
Muffler:
Top curve= ACE 160mmOD twin tip muffler (not released yet)
Mid curve= muffler delete
Low curve= OEM muffler
Again, all pulls with Stock ECU and K&N air filter. We will dyno again with Delicious Stage 2 and post results when we get a chance. Probably won't be for a while as the we're in winter re-build stage and the car is in pieces.
AceHeader-MT is offline   Reply With Quote
The Following User Says Thank You to AceHeader-MT For This Useful Post:
Calum (01-15-2015)
Old 01-15-2015, 10:27 AM   #30
AceHeader-MT
Drives: 2012 FR-S
4-2-1 dyno pull
Old 01-15-2015, 10:27 AM   #31
rlpaul
Drives: point A to point C. Screw point B!
Interesting design. So this should increase the header pipe length, which should produce a flatter torque curve vs the shorter headers most of the aftermarket employs? The dyno looks a bit funky, but that's what it appears to be doing if I'm reading it right.
Will be interesting to see what kind of results occur with a tune. Peak HP/TQ is nice and all, but I'd rather have a flatter, more predictable torque curve personally, and this looks promising in that regard.
rlpaul is offline   Reply With Quote
Old 01-15-2015, 11:04 AM   #32
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
I really like this.. Something to keep in mind as I'm doing headers sometime in the summer.
cameronjones239 is offline   Reply With Quote
The Following User Says Thank You to cameronjones239 For This Useful Post:
AceHeader-MT (01-15-2015)
Old 01-15-2015, 08:59 PM   #33
Calum
That Guy
Drives: 2013 asphalt FRS MT
Sweat Jesus that setup is quite.
The Following User Says Thank You to Calum For This Useful Post:
Old 01-16-2015, 05:02 PM   #34
V3rtigo
Drives: 2006 S2000
Does the header(421) come wrapped as it is in the photos?
V3rtigo is offline   Reply With Quote
Old 01-16-2015, 05:23 PM   #35
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
So that dyno is the 4-2-1 header with a tune. That torque "rollercoaster"? is quite horrendous IMO.
The design is impressive; however, the numbers are not. Once again, my opinion.
-Jack Burton
Old 01-16-2015, 05:45 PM   #36
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
@AceHeader-MT: any way to do... local pickup?
I am going back to Taiwan in August and may be interested in picking it up. Can probably ship for others worldwide if paid in advance.
Thanks.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
AceHeader-MT (01-17-2015)
Old 01-16-2015, 08:10 PM   #37
Dimman
Kuruma Otaku
Dimman's Avatar
To all you metric lovers, how many kW is this?
Serious note:
Curious why no photos of the primary merges.
Also dyno graphs that don't start the power and torque at zero are EXTREMELY deceptive in comparisons.
Just saying...
Because titanium.
Old 01-16-2015, 10:31 PM   #38
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The dyno is without a tune.
The Following User Says Thank You to Andrew025 For This Useful Post:
tahdizzle (01-17-2015)
Old 01-16-2015, 11:56 PM   #39
Dimman
Kuruma Otaku
Dimman's Avatar
Part of the reason is the graphs don't start at zero. We are basically zoomed in, which magnifies the changes. Useful technique for visually looking much better than a competitor if your advantage is small. But the side effect is amplifying the ups and downs.
A graph starting from zero would show that the roller coaster isn't that crazy. But also that there's a negligible difference with 'Brand X'.
In short, meh.
Because titanium.
The Following User Says Thank You to Dimman For This Useful Post:
Old 01-17-2015, 12:36 AM   #40
AceHeader-MT
Drives: 2012 FR-S
Yes, the header comes wrapped. But only if requested
That particular header came off the car after the Tsukuba and Suzuka runs.
It's the latest revision of our design so the other un-wrapped versions are slightly different. We didn't want to post photos of inferior parts
Production set-up should be finished in a few weeks. After that we'll post better photos of the header, runners and collector
Old 01-19-2015, 05:01 AM   #41
AceHeader-MT
Drives: 2012 FR-S
Unwrapped version
The Following 4 Users Say Thank You to AceHeader-MT For This Useful Post:
Calum (01-21-2015), mad_sb (01-21-2015), twag4 (01-19-2015), V3rtigo (01-21-2015)
Old 01-21-2015, 05:03 PM   #42
V3rtigo
Drives: 2006 S2000
ETA for these being ready to ship? You've got my business on the 421. It seems expensive at first but then when you compare it to other headers plus overpipe its not bad.
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
