Old 11-16-2017, 01:19 PM   #29
Originally Posted by covance View Post
what happened!
What happened to what? Who are you asking? The OP has been gone for 2 years.
Did you actually mean to post here: http://www.ft86club.com/forums/showthread.php?t=89274
Ultramaroon (11-16-2017)
Old 10-06-2019, 02:38 PM   #30
caballo_glue
caballo_glue's Avatar
Drives: Red 2014 FR-S
My car (2014 Scion FRS) is doing this as well. Going in for alignment Monday, already balanced wheels last Friday. I know this is an old thread, but going to try and figure it out on the behalf of everyone else. I don't remember the car doing this when I got it, but after I did the 60,000mi service is when I noticed it.
I do have the carmax max care warranty so hopefully I can resolve the problem with my $200 deductible and figure it out for all of us.
caballo_glue is offline   Reply With Quote
Old 10-06-2019, 02:40 PM   #31
JD001
JD001's Avatar
Drives: Subaru BRZ
Sounds like the OP is driving the FWD version of the Triplet..
Old 10-06-2019, 02:55 PM   #32
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Nope.
With a wonky frontend, the car will go mostly straight but the wheel will be crooked, with a wonky rear axle, even if the wheel is straight the car will try to rotate to wherever the rear is pointing.
Even in a fwd, a loose rear end is way more unstable than a loose front.
The Following 3 Users Say Thank You to RZNT4R For This Useful Post:
JD001 (10-06-2019), Ultramaroon (10-06-2019)
Old 10-06-2019, 04:15 PM   #33
caballo_glue
Update. Swapped left rear tire with right rear tire, car pulls in opposite direction now. (To the right). Will be skipping alignment until I get new tires.
Old 10-06-2019, 05:19 PM   #34
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by caballo_glue View Post
I get new tires.
That'll happen soon. Right?
Old 10-06-2019, 06:08 PM   #35
soundman98
ProCrastinationConsultant
soundman98's Avatar
and you'll be getting 4 new tires?
i'm learning very quickly with all these posts that this car does not respond well to cheap maintenance procedures like doing 1 or 2 tires at a time.
Old 10-06-2019, 09:47 PM   #36
radroach
Drives: car
@soundman98 I got by alright on stock tires just changing 2 at a time. Now on sticky tires though, probably wouldn't work out so well.
Old 10-08-2019, 08:50 AM   #37
caballo_glue
Just got 4 brand new firestone indy 500s BRAND NEW CAR! OMG These are sticky. No more pulling to left or right on acceleration. I can no longer slide the rear end out either, it just wants to stick and go go go!
Firestone did break one of my wheel studs so I had to limp home then replace it, but a quick youtube video and an hour later, back on the road. If you want some great performance for about $100/tire Get the Indy 500's you won't be sorry.
Old 10-08-2019, 08:51 AM   #38
caballo_glue
New tires put on last night. Solved problem.
The Following 2 Users Say Thank You to caballo_glue For This Useful Post:
DarkPira7e (10-08-2019), Ultramaroon (10-08-2019)
Old 10-08-2019, 12:48 PM   #39
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
So recently I had a left rear tire separate halfway through a 4.5 hour drive home from the cottage. Had to put the spare on the drive axle, and drive 2.5 hours home like that with the car pulling like a bucking bronco every time I touched the throttle.
So I can chime in with certainty that this issue most likely has something to do with the rear axle set up in most cases, whether it be unevenly worn tires or a bad alignment. With the spare on one side, and a 9.5-inch-wide wheel on the other side, it was doing this like CRAZY.
4 new tires and an alignment and she drives laser-straight now.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 01-12-2021, 06:39 PM   #40
trashmasterdash
Drives: 2013 Scion FRS
Was this ever resolved? Having exact same problem, tire pressure and alignment are good
trashmasterdash is offline   Reply With Quote
How to properly drive aggressively? JoonPrime Tracking / Autocross / HPDE / Drifting 18 10-05-2014 12:46 PM
WTB Red Bumper, Left Fender, Left head light, Clear side markers carlossanchez89 Want-To-Buy Requests 0 09-01-2014 04:43 PM
Brz pulling trailer? subiesteve Southwest 7 11-20-2013 10:04 PM
94 octane not pulling Scalzo Forced Induction 44 10-08-2013 11:15 PM
Pulling your FRS off of the lot, what are you bumpin'?? poormans_LFA BRZ First-Gen (2012+) — General Topics 201 06-09-2012 10:52 PM
