Old 02-26-2015, 06:28 AM   #29
OMG, Tony, you just got Squaddied.
Holy crap you took it serious again!
Do I need to remind you of the "How to Drive Like an Ahole" thread
You oughta know by now that I enjoy the subtle satire and the response to that obvious joke question required a semi formal answer. If I had had more time at that point I would have copied a bunch of tech info and attached it to make it even more like one of the "I will answer every dumb question with a long technical answer" guys.
Old 02-26-2015, 11:28 AM   #30
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
The older model S2000's used to have a traditional key AND a push button. You turned the key to ACC then hit the push button, problem solved (and all the negatives of push button start).
V_86 is offline   Reply With Quote
Old 02-26-2015, 12:25 PM   #31
Ultramaroon
not playing cards
Ultramaroon's Avatar
I know, fuck. I wondered about that. You really take it to another level.
Old 02-26-2015, 12:32 PM   #32
In order to avoid future confusion I shall incorporate the safe word "aardvark" into any such reply so you will know!
Ultramaroon (02-26-2015)
Old 02-26-2015, 01:35 PM   #33
De-bounce
Drives: 1
Have you guys tried re-wiring the radio straight to the battery instead of the switched power? It will solve all your problems I promise you.
De-bounce is offline   Reply With Quote
Old 02-26-2015, 02:22 PM   #34
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
why not just sit in the car idling for another minute while you let that jam on the radio come to an end.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 02-26-2015, 02:37 PM   #35
Ultramaroon
not playing cards
Prius swap because global warming
Tcoat (02-26-2015)
Old 02-26-2015, 04:32 PM   #36
Loetke
Drives: 2015 Scion FR-S Release 1.0
I know what he's talking about here. If you push the button once all of your electronics will turn on but it will shut off again after about 10 minutes. If you push it twice everything comes on and stays on, including the fans and all that jazz, which significantly reduces the battery life. I left mine in that mode to listen to music while working on my car and it lasted about 60 minutes and then I had to get a jump from my Jeep.
Loetke is offline   Reply With Quote
Old 02-26-2015, 06:00 PM   #37
De-bounce
Drives: 1
It sounds like someone needs an OPTIMA battery.
Old 02-26-2015, 08:12 PM   #38
Loetke
Or next time I could be smart about it and just use my phone.
The Following 2 Users Say Thank You to Loetke For This Useful Post:
De-bounce (02-27-2015), Tcoat (02-26-2015)
Old 04-09-2016, 03:38 AM   #39
Tech
Tech's Avatar
Drives: White MT GT86 with TRD extras
I have posted my electronic solution to this here:
http://www.ft86club.com/forums/showt...62#post2615962
Tech is offline   Reply With Quote
Running e85? HSayaovong Engine, Exhaust, Transmission 16 04-24-2014 11:05 PM
Something running while car is off. grostoine Issues | Warranty | Recalls / TSB 5 04-11-2014 08:56 PM
Noticeably low and sharp volume with AM radio stations with stock BRZ radio tracerit Electronics | Audio | NAV | Infotainment 0 07-24-2013 02:38 AM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 02:45 PM
Radio, Iphone?? Radio cuts out when surfing the web Fugazi Electronics | Audio | NAV | Infotainment 5 07-30-2012 11:24 AM
