Old 11-17-2014, 07:58 PM   #29
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
OFT does a full write. Tactrix (and at times Ecutek) do partial writes. Does a full write eliminates the possibility of writing an incomplete or corrupt file to the ECU. Ecutek operates in its own "close" environment so it minimizes this risk. Tactrix assumes the end user is knowing what he is doing and isn't held responsible when he doesn't. We have to be a bit more cautious than both since the OFT operates in an open environment with "hybrid" maps and pseudo CAL IDs.
Old 11-18-2014, 12:51 AM   #30
steve99
Originally Posted by Toyota John View Post
Few things i have noticed is OP2 tactrix cable seems to be less reliable at connectivity. I have had it be troublesome to connect while OFT or ECUTEk connects fine. Also Tactrix OP2 can't log live. You can only look at what was logged after the fact which can't be dangerous if you run lean or start knocking. OFT is very slow at flashing but so is ECUTEK. OP2 tactrix is very fast about a min per flash.
bend the pins on the adapter both rows inwards about half a millimtere no more issues.
Old 11-19-2014, 10:09 AM   #31
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
I will try that thanks.
Toyota John is offline   Reply With Quote
Old 05-01-2018, 10:51 PM   #32
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Necropost but this this is the only real thing duckduckgo for ecutek in KVM. I passed the USB controler in and windows picks up the key but I dont have the balls to hook it up to my car
Breadman is offline   Reply With Quote
Tactrix EcuFlash Info for BRZ 86 FRS Rom flash update and logging steve99 Software Tuning 1093 05-16-2025 10:38 AM
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
Tactrix Ecuflash? enjoyminutemaid New England 1 08-13-2014 09:59 AM
Any success with EcuFlash and F/I? D-VO Software Tuning 4 06-26-2014 03:58 AM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
