#29 |
not playing cards
likely culprit. I assumed single partition.
#30 |
Drives: 2014 Porsche Cayman S
Sorry, forgot that I went back and deleted that NTFS partition so that it was unallocated...still did not work.
Let me know if you figure this out...otherwise, I will have to consider a large flash drive. Cheers!
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
#31 |
not playing cards
Is the unallocated part before, or after the fat32? If it was first, then delete the fat32 partition and start over. What software are you using?
#32 | |
Drives: FRS
Agreed, it's been awhile for me too since I messed with this sort of thing but you might now have a single partition that is actually partition 2 instead of 0. Try formating the drive then partition your fat32 sector only. If that doesn't work I'd call it a bust myself.
#33 |
When I created the fat32 partition, it allocated it at the end...I could not see how I could make it partition 0, but I will go back and double check. I am using Windows Disk Management.
#34 | |
#35 | |
not playing cards
Then create a 64 GB partition and format it to fat32. If you make the partition any larger you won't be able to format it to fat32 with native Windows tools.
#36 | |
Thanks for the help, but I think we have exhausted all possibilities. Cheers!
#37 |
not playing cards
I'll give it a shot and let you know what I find.
#38 |
Thanks!
In theory, it should work, but nothing I have tried has worked out yet...maybe you will find the key.
#39 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Taking a guess here, but make sure the disk is formatted using MBR and not GPT. Google it if you need instructions or are curious. tldr; GPT is more modern and allows for larger HDDs, MBR was only compatible with HDDs of total volume <= 2TB.
And there are reasons for FAT32 not being commonly used, a big one being the fact that it cant handle files larger than 4GB. |
#40 | |
I tried making the partition Active to see if that helps, but no. Thanks.
#41 |
Just tried a 256gb flash drive and it works flawlessly, even with high bit rate lossless files. Unfortunately, the head unit sucks, so I cannot choose individual folders. This is not a big deal as I tend to play shuffle anyway.
I am still interested in using the hard drive if someone figures it out. Thanks for all the help so far.
#42 |
Drives: 2014 BRZ
Format the entire hard drive to Fat32 do not partition it. You can download software that will allow you to format larger hard drives than the drop down box would normally allow. Again I use a 250GB USB powered hard drive and it works great. I have several hundred albums on it.
| Replace the entertainment system 2014 BRZ | Max1957 | BRZ First-Gen (2012+) — General Topics | 15 | 02-26-2014 05:45 PM |
| 86 Accent Photography via Elysiam Entertainment | kayhettin | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 07-05-2013 12:25 PM |
| Is it possible to get a BRZ without the av/entertainment system? | chickdigger802 | BRZ First-Gen (2012+) — General Topics | 27 | 05-06-2013 10:35 AM |
| Rear fog light on FR-S already connected? | RPhong | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 09-01-2012 08:49 PM |
| Cars & Cafe, Orlando: Route 46 Entertainment District | Arsenal Autosport | Southeast | 1 | 05-25-2012 04:47 PM |
