#29 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
I think if what you're suggesting were generally true, the line at the race gas pumps at the track would be seriously backed up; instead, almost no one is using them. Not back here, anyway. If BMW and Porsche drivers thought they could get a performance boost from race gas, they'd be lined up for it - the cost isn't going to stop them. I seem to recall that 93 octane is not available at the pump in Southern California - is that correct? |
#30 | |
I am a little surprised that other cars don't benefit from higher octane, I've read about people wanting higher octane for some BMW engines. In the end though, I can only speak to my own experience that a little race fuel gives a small boost in power.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
#31 | |
Also, the manual says that you can run 91 without damage. When they say this it is going to be a probabilistic statement based upon some number of cars having their lifespan shortened by a tolerable amount. These conditions are almost certainly considered with fairly normal driving patterns, not race track conditions. With the introduction of higher heat loads you very well might shorten you engine's lifespan by an appreciable amount. If you are not running an oil cooler the extra stress is even more pronounced. Remember also how the engine deals with knock; it pulls timing. Pulling timing reduces the dynamic compression ratio of the engine (and with it charge density and associated heat). This reduces the amount of power you get. I absolutely can feel that difference. It could be my engine is more prone to knock than yours, it could be CA gas, it could be that my driving is more sensitive to small power changes or maybe I am more sensitive. I really don't know. It is noticeable to the point that I have forgotten that I put a half tank of 100 in before lunch and then wondered in the next session why I am picking up extra speed out of a corner when general conditions should be reducing my speed.
#32 | |
Drives: '23 BRZ Limited
Mazda SkyActive 13:1 in the US, 14:1 in the rest of the world. Ferrari LaFerrari 13.5:1 458 Speciale 14:1 Last edited by OkieSnuffBox; 10-28-2014 at 08:16 PM. |
#33 |
#34 |
The SkyActive is an economy engine; both output and redline are significantly lower than the FA20. If we lowered the FA20 to those specs, we'd have no issue either...
#35 | |
The SkyActiv on the other hand is something worth comparing. For that you should consider that it is a purely direct injected engine which tends to yield more controlled deflagration of fuel than port fuel injection. This combined with (from a quick google I think they have) continuously variable valve timing and valve lift with independent exhaust and and intake controls gives much better control over chamber temperature and dynamic compression ratios than we get with our engines. They might have a higher compression ratio, but they have control systems that facilitate that. Also, most of the SkyActiv engines are not being tracked. They aren't usually being asked to operate in the 5-7K RPM range for 25 minutes straight five times a day (or worse). Even if you do track those engines I've heard they have a broader torque curve so you don't have to brutalize it as much as the FA20.
#36 | |
My point is that it shouldn't be a problem to make a tune that works on the track with 91/93 octane. Will you have to give up some power? Yes. Is 8hp at 7300rpm worth the engine not going "boom?" I think I'd probably answer yes as well. |
#37 | |
Don't fool yourself into thinking those Ferraris are reliable on track, because they're not. |
#38 |
#39 |
#40 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
All naturally aspirated 991 911 models except the GT3 have 12.5:1 The 991 GT3 has 12.9:1 The 997 GT3 RS 4.0 has 12.6:1 The 981 Cayman/Boxster (all 3 engines) has 12.5:1 The R8 (all 3 engines) has 12.5:1 The Lamborghini Aventador has 11.8:1 The Lamborghini Huracan has 12.7:1 The 918 Spyder has 13.5:1, as does the LaFerrari (though now we're getting into silly expensive territory) If you look at motorcycles, it's even easier to find examples: The BMW S1000RR has 13.0:1 The Ducati 1199 Panigale has 12.5:1 The Suzuki Hayabusa has 12.5:1 The Yamaha R1 has 12.7:1 Admittedly, these are all substantially more expensive and exotic than the BRZ (or are motorcycle engines), but it isn't as outlandish of an engine design as you're implying. I know a lot of 981/991 owners who happily track their cars on 91 octane, and I haven't heard of any problems related to it. |
#41 | |
Drives: 2016 FR-S
#42 | |
| Oil Weight Poll For Track Usage | brillo | Tracking / Autocross / HPDE / Drifting | 49 | 07-01-2015 05:34 PM |
| Custom tunes safe for track usage? | Sleepless | Software Tuning | 21 | 12-23-2014 08:54 PM |
| Best kit for occasional track usage | yomny | Forced Induction | 14 | 02-06-2014 08:10 AM |
| Looking for someone who can do custom tunes in NY | AceNiNe | Engine, Exhaust, Transmission | 9 | 04-03-2013 06:48 PM |
| Powder Coated Wheels Safe for the Track?!? | BlaineWasHere | Tracking / Autocross / HPDE / Drifting | 21 | 03-24-2013 09:46 PM |
