Old 10-13-2015, 10:01 PM   #29
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
It's possible that the valves did touch the pistons ever so slightly, in which case the pistons would be slightly work hardened and if stressed in the future, may shatter.
Also, the highest RPM ever reached is logged by the ECU, apparently. In this case, good luck with any future engine warranty claims.
My sympathy-o-meter didn't hit the redline reading the original post. In fact, it stalled. Real men screw up their 110mph upshifts on the track, not on public roads.
pushrod is offline   Reply With Quote
Old 10-13-2015, 10:02 PM   #30
stugray
Drives: 2013 GBS BRZ Limited
1 - Dont believe anything someone tells you on the internet (That includes me).
2 - An overrev condition will usually over stress components such as rod ends, pistons, or rocker arms.
just because nothing broke it doesnt mean that components werent overstressed.
You dont know until something breaks.
3 - change the oil, cut open the filter, look for debris. If no extra debris, just drive it more carefully and enjoy.
Once you realize that your car really is just a tool (like a hammer) you'll quit worrying and swing the damn thing.
If you break it, youll buy new handle or youll pitch it and buy a whole new one.
Old 10-13-2015, 10:16 PM   #31
Romanov
Just another BRZ owner
Romanov's Avatar
Drives: 2014 Subaru BRZ Limited MT
Originally Posted by SloS14 View Post
You were double-clutching when you should have been granny shifting.
I read the first post and then looked for this comment.
Romanov is offline   Reply With Quote
Old 10-13-2015, 10:21 PM   #32
steve99
Also, the highest RPM ever saw is logged by the ECU, apparently. In this case, good luck with any future engine warranty claims.
maybe rpm data is logged somwhere but using techstream that dealer have it does not appear to be able to access that data. All log data in ecu that is accessable via techstream is erased on ecu reset ie poer removal, even before a reset no max rpm data is accessable. other stuff like dtc codes time since reset time since tdc actice is accessable but is also erased on reset.
dealers have tried to bluff guys, but they were unable to produce log evidence.
they may still win as their techs\engineers will analyse the failed components and they may gain enough from that to determine it was an overrev, like dents in piston crowns. or bent valves ect
Old 10-14-2015, 12:24 AM   #33
Hawk77FT
Drives: GTS 86
Drove the car like I stole it, two days after I got it! No issues whatsoever!
Hawk77FT is offline   Reply With Quote
The Following User Says Thank You to Hawk77FT For This Useful Post:
Doobster (10-14-2015)
