Old 09-30-2014, 09:48 PM   #29
Naeblis
Drives: Subaru BRZ
Originally Posted by kingnba6 View Post
sometimes the battery has been abused at the dealership so even leaving the lights on without the engine running, can kill the battery. if you car is still under warranty, then they should replace the battery free
Yeah, towing and battery replacement were free, and now my wireless charging works! Just need to get a 3d model for a single cupholder so I can use them both simultaneously
Naeblis is offline   Reply With Quote
Old 10-06-2014, 05:48 PM   #30
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Originally Posted by NJ10 View Post
I've got a suggestion on the parts front,
you wouldn't have to go through the micro USB conversion hassle and all,
http://www.aliexpress.com/item/QI-wi...325747887.html
Good Initiative man. I have a slightly similar idea, I'm not sure it'll work but I'll post that up once I verify it.
What do you mean? The downconverter box is not to convert to micro USB, it's to get a 12V source to output at 5V.... the Micro USB box was just the one I chose because that coil used Micro USB, you'll still need to down convert no matter which USB plug type you use.
Deathalo is offline   Reply With Quote
Old 10-06-2014, 05:53 PM   #31
Deathalo
Originally Posted by Naeblis View Post
Any way this could kill your car overnight? I added the charger in last night and the car started fine. This morning though the battery is almost completely dead
No, this will not take power unless your car is on or in ACC mode, if your battery was almost dead it wasn't because of this. I left my car in the airport lot for a week and started up fine as well.
Old 10-14-2014, 05:41 AM   #32
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
I've been waiting for a decent writeup on how to do this. I plan on doing this in the FRS little slot (where the push start should be) since I always throw my phone in there. Definitely gonna do this eventually once I get a Qi phone lol.
l0aded is offline   Reply With Quote
Old 11-13-2014, 09:52 PM   #33
Chimera
Drives: FRS
Just learned my phone has wireless charging as a feature.
Thinking the same exact thing.
Anyways my question to those that have done this. Any interference issues? I know for instance that dash cams are known for causing minor issues with GPS. Any known issues here before I put a big induction coil in middle of my dash near the radio?
Old 11-14-2014, 04:02 PM   #34
Deathalo
No, there are no issues like that with Qi charging, the induction only works when placed right over it anyway..
Old 11-21-2014, 01:29 AM   #35
mynameis940
mynameis940's Avatar
Drives: WRX
Just did this myself, thank you for the write up really appreciate it.
mynameis940 is offline   Reply With Quote
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 04:00 PM
need help on jpm center console Jhon19lopez Cosmetic Modification (Interior/Exterior/Lighting) 4 06-24-2013 08:57 PM
red center console? gusbarragan Cosmetic Modification (Interior/Exterior/Lighting) 13 02-19-2013 09:03 PM
Center Console help mbh1101 Cosmetic Modification (Interior/Exterior/Lighting) 2 08-22-2012 10:56 AM
