#29 |
Hisnamewasrobertpaulson
Drives: 2017 Golf R
i'm curious about this as well.
This is your life and it's ending one minute at a time.
#30 | |
Drives: 2013 BRZ Premium Black
Tomei gaskets work great, mines holding up well. The only pain in the whole process was getting the bolt on the collector side tightened. |
#31 |
#32 | |
Loosen the spacer, put on to test fit, take off header with adjusted space, tighten spacer, reinstall. |
#33 |
Drives: 2013 FRS
They are fine.
#34 | |
Drives: 13 Scion FRS
+1 On that one! I broke mine as well. Took a LONG LONG time to get it off.
Add me on IG @CNastySon
Mishimoto..."Do Yo Temps Stay Low, With the Throttle To Da Flo!!! |
#35 |
Drives: '13 asphalt frs
Van anyone tell me how to tighten The nuts? I can tightin two of them but the single last one is hard to get too. Wrench and socket won't work.
#36 |
Drives: 2013 FRS
If you can find a smaller socket and extender it should work. That last nut was a huge PITA to tighten, I ended up going to my local garage so they could tighten it a bit more the next day.
#37 |
Drives: 2016 STi DGM
GET A U-JOINT AND AN EXTENSION
-2014 SSM BRZ MT
#38 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
#39 |
Bringing Hachiroku Back
Drives: 2013 Firestorm FR-S
I cant believe no one has posted anywhere in the entire forum all the torque specs in one place.. I still have not been able to find the torque specs for the header to overpipe. Heres what I have so far:
header to engine studs 22lbs Overpipe to Front pipe - 31.3 FT LB Front pipe to Exhaust Pipe - 14.3 FT LB Im just going to wing it and torque it to 30 ft lb
#40 | |
2022 BRZ Build 2013 FR-S Build |
#41 | |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
As for the over pipe to header, again, no room for a torque wrench. I tightened them up and turned on the car whilst having my dad cover up the exhaust tips (leak check). As it turned out, the to head to manifold joint was fine, but the manifold to over pipe was leaking, so I had to really tighten those bolts in order to get it not to leak. Hope that helps someone. |
#42 | |||
It should always be propperly spaced out since it comes with a metal bar with a nut on each side bolted to the header. If I had to guess I'd say the purpose of this is to make sure the header doesnt shift during shipping etc. Quote:
| Evasive Tomei Header Group Buy | Evasive Motorsports | Groupbuys | 424 | 08-05-2018 12:55 PM |
| *Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* | 86SPEED | Groupbuys | 74 | 11-09-2016 01:45 PM |
| Quick tips for Remote Start installation | trueno86power | DIY (Do-It-Yourself) Guides | 12 | 12-07-2014 03:47 PM |
| Tomei Exhaust with Tomei Straight Pipe | leech | Engine, Exhaust, Transmission | 10 | 01-07-2014 10:42 AM |
| FS: Tomei UEL Header (WRX) | [deleted] | Miscellaneous | 0 | 03-19-2013 09:58 PM |
