Old 09-10-2015, 05:32 AM   #29
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by tracerit View Post
I'm at - 1.9 left and - 2.5 right for the rear. I was hoping to get them both to - 1.5 but even just bringing the right to - 1.9 or - 2.0 to match the left would be okay as that's still within spec.
Are these the bolts you're referring to?
http://www.ft86club.com/forums/showthread.php?t=33415
Yup. I'm using the SPC 12mm bolts. I just didn't use the supplied washer. That's the major difference between SPC and H&R. Although there may be a hardness difference, I'm not sure. But pretty well any 12mm camber bolt will work.
The Following User Says Thank You to Calum For This Useful Post:
tracerit (09-10-2015)
Old 09-10-2015, 09:56 AM   #30
bfrank1972
Drives: 2013 FR-S Argento
I'm running the H&R bolts, works fine and allows me to dial out a little camber after lowering and even out L/R camber. About $50+/- for two bolts.
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
Old 09-10-2015, 05:10 PM   #31
Calum
That Guy
Jesus, that's a lot for two bolts. I think mine were less than $20.
Old 09-10-2015, 05:24 PM   #32
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Id like to agree with @CSG Mike on this. We get calls a lot asking about LCA's and in the cases of guys just doing springs and daily or light track and Auto X we will recommend the SPC.. But a lot of track use, extreme lowering and stuff like that we recommend other LCA's. I personally would use the SPC if i just daily my car, but i enjoyed the track and would not run them on my car.
-Thomas
86SPEED is offline   Reply With Quote
Old 09-10-2015, 06:08 PM   #33
srizzors25
Daedalus Moto
srizzors25's Avatar
Originally Posted by Khorne View Post
Anyone tried the Parts shop max ones?
http://www.partsshopmax.com/page.php?59
so keeping up with the old thread bump, I've had these on my car for about 15k miles and they've been solid. Always been a fan of PBM parts, especially when I had my 240sx some time ago. People have always enjoyed their coilovers and I almost bought theirs for my BRZ as well.
For a daily I'm happy with them. Big difference I've noticed with them is that they could have gone with a better finish. Not sure if I'd pay another 250 bucks for that but the front facing side of the arms has been chipped up pretty good. one of these days I'll pull them off and have them powdercoated or something but they are chipping pretty good. Been wonderful otherwise but I just DD at a 2" drop so not a whole lot of stress there
The Following User Says Thank You to srizzors25 For This Useful Post:
Bergen23 (09-10-2015)
Old 09-10-2015, 09:06 PM   #34
bfrank1972
Yeah I know - I figure they might be harder than the SPC bolts, less likely to shear if there's slippage. Or it might be me just paying extra money to make myself feel better They're made in Germany after all! Either way they're working nicely, enough camber adjustment for my needs, and still a lot cheaper than even the SPC control arms.
Calum (09-11-2015)
Old 09-10-2015, 10:26 PM   #35
Bergen23
Drives: '15 Halo FR-S
Pretty pumped on mine, especially with helping me get the rear lower. I had my FA 500's as low as they'd go on my old LCAs, put in the PBM ones on the lowest setting and as soon as I got the car off the jack stands and on the ground I said "oh shit" and had to raise the suspension up. Makes quite a huge difference.
Bergen23 is offline   Reply With Quote
The Following User Says Thank You to Bergen23 For This Useful Post:
srizzors25 (09-11-2015)
Old 09-10-2015, 10:54 PM   #36
RJasonKlein
RJasonKlein's Avatar
@CSG Mike, I know you have to be careful when commenting on another sponsor's products, but are you impressed with the FT-86 SpeedFactory LCA by Velox? To me, they look fantastic - do you have confidence in the testing they've done and do you expect them to be robust and safe enough to recommend?
RJasonKlein is offline   Reply With Quote
The Following User Says Thank You to RJasonKlein For This Useful Post:
strat61caster (09-11-2015)
Old 09-10-2015, 11:12 PM   #37
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
*cough* Racer X for the win *cough*
The Following 2 Users Say Thank You to dem00n For This Useful Post:
kbye (09-11-2015), strat61caster (09-11-2015)
Old 09-11-2015, 01:23 AM   #38
strat61caster
strat61caster's Avatar
Their site doesn't work for me, have a link?
Although I appreciate the mention, seems like SPC and SPL dominate the LCA conversations...
ineedyourdiddly
Old 09-11-2015, 08:38 AM   #39
cjd
cjd's Avatar
Drives: 2017 BRZ
http://racerxfabrication.com/frs-brz...r-control-arms
They offer a bushing end for STX legal use, so they come up now and again.
C
The Following User Says Thank You to cjd For This Useful Post:
Old 09-11-2015, 11:02 AM   #40
kbye
kbye's Avatar
Drives: 2014 FR-S
+1 for racer-x, my set just came in I'll have pics soon.
They're machined from aluminum, and won't break the bank. It's good if you want more adjustability than the SPCs and don't need as many mounting points as the SPLs. They're a happy medium. Like cjd said, the urethane ends are STX legal and also help with NVH a little.
kbye is offline   Reply With Quote
Old 09-11-2015, 12:07 PM   #41
OkieSnuffBox
Drives: '23 BRZ Limited
^Not necessarily true on the mounting points, one nice thing is the lower mounting holes which let raise your coilovers back up and acheive the same ride while increasing travel.
Old 09-11-2015, 01:04 PM   #42
kbye
kbye's Avatar
Drives: 2014 FR-S
I understand the purpose of the different mounting holes, that was not my point. Like I said, not everybody needs those mounting points for the extra cost.
DME Lower Control Arms and DME Toe Arms - Review FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 02-24-2015 11:53 AM
Lower Control Arms DriftEightSix AUSTRALIA 18 05-03-2014 10:56 PM
PSM Lower Control Arms Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-26-2014 02:04 PM
Wtb: lower control arms natesparxxx Brakes, Suspension, Chassis 3 04-07-2014 07:29 PM
WTB: SPC LCA (Lower Control Arms) AG3NT_5CARFAC3 Want-To-Buy Requests 9 02-19-2014 01:30 PM
