#29 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Love my AP Sprint BBK. Takes a pounding on track and asks for more. Pads are cheap and thickest around. No boots to burn up and the calipers are cheap/easy to service
![]() I think you'll be happy with it. The best BBK available for a track application. Talk to @CSG Mike about Sprint vs Endurance kits and see which one you'll want to go with. Over 400whp may necessitate the Endurance kit if you get lots of track experience and need extra thermal capacity and cooling ducts. |
#30 |
in orbe terrum non visi
Drives: violent
Thanks Ian.
What pads do you run?
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#31 |
Track: CL RC6 front (came with BBK) and Carbotech XP12 rear
Street: Carbotech Bobcats (1521) front and StopTech Street performance rear |
#32 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
#33 | |
Drives: 2022 BRZ Limited
![]() and the cost advantage on the Wilwoods are huge IMO, $1400 vs $2100 ..it will be a tough decision when the time comes
#34 |
Because compromise ®
Drives: Red Herring
As an added bonus the Essex Sprint Kit lose 4.5 kg per side over stock. Win!
#35 | |
The Wilwood SL6R caliper is virtually identical to the AP Racing 8350.... I wonder why that is. |
#36 | |
Site Moderator
Drives: Stuff
Don't get overly concerned about dust boots. If you generate enough heat on track you'll just melt them anyways (which is why race calipers don't bother with them). I've used the Sprint kit for about 17,000 miles I think, street and a fair amount of track use. They are perfectly streetable. They will make noise with track pads, but there are some street pads that are pretty quiet and you can get non j-hook rotors which should help the noise also (but I haven't tested it since I don't drive my BRZ anymore). If you are looking for pretty calipers, well I think gray aluminum is pretty, but the AP formula kits, the stillen kits and the stoptech are all good options.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#37 | |
Site Moderator
Drives: Stuff
-Dave
#38 |
Drives: violent
I think I'm decided on the sprint kit and if the winter looks like its going to be bad ill just put the stock brakes back on. What pads do you run? @Dave-ROR
#39 | |
Site Moderator
Drives: Stuff
-Dave
#40 | |
Site Moderator
Drives: Stuff
-Dave
#41 | |
Site Moderator
Drives: Stuff
More pistons will generally mean better modulation and better pad life if they are differential (more piston area in the direction of travel to prevent tapering in the longitudinal direction). AP 4 pots used in the Essex kit are diff too and I've only noticed very slight tapering. The rest comes down to piston area to determine how the brakes would feel and what their effect would be at a given line pressure.
-Dave
#42 | |
Site Moderator
Drives: Stuff
I use Project Mu 999's (from @CSG_Mike) and CL RC6 and RC6E from @JRitt Actually the RC6 might be on one of the Integras, hard to remember anymore. For street use I'd look at the blanks instead of J Hook and the street/autocross Carbotechs. They are cheaper than track pads though so get good expensive pads at the $25 rate and buy those separately
-Dave
| Deciding on LCA's. | natesparxxx | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 61 | 08-17-2014 01:33 PM |
| Need help deciding on Exhaust | DannyFRS | Engine, Exhaust, Transmission | 1 | 02-23-2014 05:10 PM |
| Deciding on an exhaust | JohnAyySays | Engine, Exhaust, Transmission | 32 | 12-28-2013 11:31 PM |
| What other car did you consider before deciding on the BRZ? | txeng86 | BRZ First-Gen (2012+) — General Topics | 132 | 10-30-2013 03:49 AM |
| Deciding between... (help appreciated) | rainmonkey | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 38 | 08-27-2013 03:53 PM |
