Old 05-23-2012, 06:03 PM   #29
Deepmist
Drives: Honda Prelude
Isn't there a nob or something to close the vents?
Deepmist is offline   Reply With Quote
Old 05-23-2012, 06:16 PM   #30
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Try venting it to the windshield defrost setting.
mines13 is offline   Reply With Quote
Old 05-23-2012, 06:25 PM   #31
chris@wagnersubaru
Drives: Fozzie XT, 02/04' Mini S', 57' Bug
The two center vents have shut-off switches so you don't get drafts.
The outer vents also close completely.
This should take care of it....just make sure you don't have the vent setting set to Floor just in case.
chris@wagnersubaru is offline   Reply With Quote
Old 05-23-2012, 06:31 PM   #32
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
I tried something today that may help. I turned the AC on for about 5 minutes to cool the vents and then turned the AC off. The vents remained cool after that. Could be that letting it sit outside heats the vents.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 05-23-2012, 06:40 PM   #33
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
Originally Posted by Big T View Post
I live in Texas and if the AC isn't on then you won't get cold air period. We can only use the fan with no AC in November.
This is so true...
Exhaust is offline   Reply With Quote
Old 05-23-2012, 06:48 PM   #34
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
It seems that the cabin air intake is located above the firewall just outside of the hood but also on a location that's close to where engine heat exits. I noticed this too...
However with all cars equipped with standard AC it may well be part of very rigorous design exercise where minimal ducting is required to save weight. I know this may sound ridiculous by normal standards, but in my recent conversation with Mr.Tada, on my inquiry as to why seat recliner memory latch was omitted from the FT86, his response was that however convenient it was, added 2kg to the weight, and his goal was to reduce it by every gram possible.
So I just want to think positive. Also, if the engine bay is emitting heat well, and engine itself is dissipating it well. It also means that the overall, the engine will stay cooler on heavier track duties. Possibly even offsetting the consumption by ultra efficient AC system by keeping engine efficient, cool, and well advanced on timing of ignition.
Just food for thought, and one of many choices the designers made?
Moto Miwa
R&D Driving Engineer, Product Designs
Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance.
Moto-P is offline   Reply With Quote
Old 05-23-2012, 10:44 PM   #35
kanundrum
Drives: 2013 Whiteout FR-S
I remember with the First Gen Toyota Matrix the A/C didn't blow that cold on those hot and humid days and the A/C Line needed proper insulation which helped drastically.
Maybe look into that and get some foam piping insulation from Lowes.
Old 05-24-2012, 12:39 AM   #36
bestwheelbase
Drives: 1985 P-Type
Originally Posted by avusblue View Post
Some cars are just that way, depending on how the underhood packaging, the exhaust pipe routing, and the HVAC ducting coincide with each other. My Miata's were always that way. The "vent" always issued warmer-than-ambient air, and having hot footwells was a very common pet peeve.
One of the things I hate about Miatas.
Old 05-24-2012, 12:46 AM   #37
bestwheelbase
Drives: 1985 P-Type
We have a vehicle (non-Toyota) that blows cold AC while driving but when stopped, it's not nearly as effective. This is because of the small AC components used for weight savings and packaging. It took some getting used to (we inspected the equipment to be sure it was functioning properly) but now it's just a character traits of the car.
Old 05-24-2012, 08:04 AM   #38
kayen
Drives: 2002 WRX w/ STi Spec C Swap
Send a message via AIM to kayen
Originally Posted by MTeator View Post
The dealer put in 93 octane, and this is my third tank of gas (I refill on 1/4 tank)
Perhaps you picked up a bad batch of Fuel? It happens more often than you think. Also you may want to try resetting your ECU, so that your Learning Trims default back to stock parameters. Hopefully everything is fine.
kayen is offline   Reply With Quote
Old 02-02-2023, 04:43 PM   #39
toyinhawaiiz
Drives: '73 Toyota Corona 2 DRHTP
Hi all,
New here to the fr-s/BRZ forums. my daughter and i just bought a 2014 BRZ for her about 3 weeks ago.been reading, watching youtube videos,etc. on this new toy we bought. former owner had a problem with the A/C. beeing cold on driver side and hot on the pass. side. so i did a little researching and found it to be maybe the blender door. took this pic up underneath the dash, had to remove the glove box to see it (i also changed out the cabin filter). I cycled the controls and found that this actuator never moved ,so i assumed i did find it to be the blender door actuator and looking thru this old thread, it doesnt seem that anyone found the cure. Can i assume it just needs changed out/replaced?Thanks in advance
toyinhawaiiz is offline   Reply With Quote
Old 02-12-2023, 09:35 AM   #40
gtpvette
Drives: 2015 FRS - FFR GTM
Did this a few years back...
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 07:56 AM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
