#29 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
I plan on trying some of the corn juice when my current tank runs out
#30 |
Drives: BR86
#31 |
see here
![]() http://www.pqiamerica.com/apiserviceclass.htm SN Current Introduced in October 2010 for 2011 and older vehicles, designed to provide improved high temperature deposit protection for pistons, more stringent sludge control, and seal compatibility. API SN with Resource Conserving matches ILSAC GF-5 by combining API SN performance with improved fuel economy, turbocharger protection, emission control system compatibility, and protection of engines operating on ethanol-containing fuels up to E85. |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | Shiv@Openflash (06-21-2014), ZZT86 (06-22-2014) |
#32 |
Drives: Scion FR-S 10 Series
I had my tuner, tr3performance.com flash my rom with this OFT tune.
I LIKE IT Looks like I now have an alcohol addiction ![]() Car just pulls better and smoother and E-85 is $3.19/gal so 0.80 a gal cheaper.. What's not to love about this? |
| The Following User Says Thank You to poptopclk For This Useful Post: | Shiv@Openflash (06-21-2014) |
#33 |
Drives: BR86
Dirt cheap fuel in good ol' US of A, it's almost twice that price here in oz :/
#34 |
TALLY FT86
I only have 1800 miles on the car, still on the Factory oil... But I want to try E85 with this tune... Should I wait until my first change so I have a more compatible oil, or does it not matter that much? @shiv@vishnu
#35 |
Drives: 86 GTS
Hey steve, would you be able to supply a copy of the tune from the below log? I'd just like to compare the changes you've made to the original OFT one.
http://datazap.me/u/steve99/e85-maf-scaled |
#36 | |
It may be close but his scale would be his specific setup even if it's stock.
#37 | |
Drives: 86 GTS
#38 | |
Drives: frs
Is the motul 8100 0w20 "compatible" with e85? How about the eneos sustina 0w20? |
#39 | |
I did a Maf scaling thread that explains how to scale your own maf, just do it on petrol before you change to e85, thread will explain why |
| The Following User Says Thank You to steve99 For This Useful Post: | tech86 (06-23-2014) |
#40 |
#41 | |
TALLY FT86
#42 |
Drives: 2014 Pearl BRZ Limited
On my third tank of e85, with the stg2 EL e85 tune, and right at 3k on the clock with the factory fill. Everything has been purring along great, and the car pulls harder than ever. I plan on an oil change in the next 1k miles, I think the factory fill is fine with e85, but don't run it out to 7500mi, or whenever the first change is recommended.
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully | | Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns | |
| Stock FR-S Tune Just Done | Zach3794 | Engine, Exhaust, Transmission | 67 | 11-05-2017 03:01 PM |
| stock BR-Z, much detonation during shifts: tune? | elefunkd | Engine, Exhaust, Transmission | 69 | 07-26-2013 05:20 PM |
| Anyone have a stock tune from Visconti? | Bleevin | CANADA | 3 | 07-03-2013 02:01 AM |
| My Initial (all stock) BRZedit tune | mad_sb | Engine, Exhaust, Transmission | 6 | 02-16-2013 01:20 PM |
| Save stock tune with ecutek? | gdrider77 | Engine, Exhaust, Transmission | 7 | 01-06-2013 01:50 AM |
