#29 |
Drives: 2014 BRZ MT (Sold); 2006 V70R
Wrapped header is no where near equivalent to coated. Wrapping is for a different goal (although some goals are shared) and comes with different risks. For a DD, coating is best imo.
Sent from my D6503 using Tapatalk
'14 BRZ LTD MT DGM
#30 |
Alexandrino_Auto
Drives: series.Blue
So much misinformation in this thread. I ceramic costed my header in my NA Rx7 Trac car and saw under good temps drop by over 50*. Not only that, but insolating the heat in the exhaust keeps the energy in the exhaust and will allow a properly designed header to scavenge better. The problem here is that I have yet to see a single header on the market with a scavaging collector. If you're just getting a header to sound cool, then don't worry about ceramic coating it. However, if you're doing it for the competitive advantage, then it's a must as every last bit counts. Plus, a coated header will outlast a noncoated header two fold.
The Shadetree Project: I turn wrenches
#31 | |
Drives: 2015 Series.Blue
Depends if they're coating internal and external and the type of coating used. Also, there's sealers that should be used over the wrap to keep them from falling apart and this also stops them from acting like a wick. |
#32 |
Turbo 86
Drives: GT86
Ceramic Coating is need as IMO, used to own M3 with aftermarket header, ceramic coat keeps the engine bay not reach too hot to burn the car out.
10 - 1 = 0
real math |
#33 | |
If you're going to coat it, do both inside and out. The whole point is to keep the gasses hot and prevent heat from escaping. |
#34 |
Drives: '13 BRZ Ltd
I believe the Borla Headers are ceramic coated. No idea on the quality of it though.
#35 | |
Drives: First SWP BRZ-L
Nameless is coated inside and out as well.
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
#36 |
Drives: 2013 Brz sport-tech
True, but i have been told from the fab shops that have built my products, that a lead cause to cracking of stainless is tightly wrapped headers, that the the general rule of thumb is to have the less possible overlap, and to not get it too tight as stainless needs to breath and absorb ambient air as it expands, it also moves alot and a pipe that is wrapped to tightly will prevent it from moving, also if one section has minimal overlap and one section is doubled up then that section will become hotter and expand at a different rate, having minimal overlap and consistanty tru out the wrapping process insures even expansion and "breathability" for the steel. i have seen the spray and im sure it does work great but ive been told to either light wrap or not wrap the headers to insure longevity , personnally ive tightly wrapped my overpipe with 50/50 overlap but it does not reach the same temps as primarys on a header. i didnt even wrap my header or coat it, there are no well know coaters here they have all been a joke. so we stick to wrap or sheilds.
#37 | |
Because compromise ®
Drives: Red Herring
Lee@JDL gives his design process for their collector. (For some reason I can't quote from that thread.) "The gist of it is, I designed several collector profiles and then compared the resulting flow fields to the "baseline" collector design that has already been built and tested. I repeated these CFD runs for a range of exhaust flow rates to see if the benefits I found were across the board or only at a specific operating point. When I say a "benefit", I'm referring to reduced pressure losses across the collector. This benefit will be realized via reduced backpressure to the exhausting cylinders (and hopefully more power!)."
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Hyper4mance2k (06-05-2014) |
#38 | |
Alexandrino_Auto
Drives: series.Blue
| Ceramic coating header only vs header/over pipe/front pipe | pixel67 | Forced Induction | 8 | 08-18-2015 03:39 PM |
| P&L EL 4in1 header w/ high flow cat+black ceramic coating(N/A) | madpcsupreme | Engine, Exhaust, Bolt-Ons | 3 | 05-09-2014 05:17 PM |
| Ceramic coating recommendations | mrk1 | Forced Induction | 5 | 03-03-2014 11:51 AM |
| Ceramic Coating options or Jet hot coating | brzadmir | NY / NJ / CT / PA | 4 | 07-10-2013 01:35 PM |
| AVO FR-S/BRZ Turbo Kits with Ceramic Coating | JoeBoxer | Forced Induction | 23 | 06-19-2013 11:59 PM |
