Old 06-03-2014, 01:04 AM   #29
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
[ame="https://www.youtube.com/watch?v=Mp4lk7zH-tg"]Dual bar modular arduino obd gauge - YouTube[/ame]
There is an issue with color changing only changing part of the bar's color...I'm working on that now.
(Also, all of the colors are configurable...so in the config file on the sd car I can change them to whatever...maybe in my next video I'll show that.)
robot is offline   Reply With Quote
Old 06-03-2014, 01:13 AM   #30
aeon
Drives: Toyota Corolla e11 pre Facelift
Okay i think i'd take this anytime over displaying it on the 7 segment clock
Gesendet von meinem HTC One mit Tapatalk
aeon is offline   Reply With Quote
Old 06-03-2014, 01:30 AM   #31
robot
There we go:
[ame="https://www.youtube.com/watch?v=ggMrQ_KHyXE&list=UUXQz23trpy-vaCZrUAbSCTQ"]Dual bar modular arduino obd gauge themeing - YouTube[/ame]
I should give that color scheme a patriotic name.
The graphics are a little jumpy. This is probably because I'm using a random number generator to generate the values and that makes them jump around. I think i'll make a new "fake"/test harness sensor that only jumps a max of 5 units each direction each time and if it reaches the max or 0 will rest to 0.
Old 06-03-2014, 01:36 AM   #32
stugray
Drives: 2013 GBS BRZ Limited
Very nice!
I have been working on a very similar device but had no need for CAN or OBD.
Mine is for logging & displaying data in a racecar.
It also uses an Arduino Mega and a 2.8" LCD.
The basic requirements for mine are:
Log serial data (RS-232) from an Innovate system
LC-1 AFR and TC-4 4 channel EGT/CHT
Log Engine RPM from coil (old style tach signal)
Log various analogs
throttle position
oil temp
oil press
batt voltage
Control a small number of loads
Shift light
Alarm light
Display readable data to driver (oil temp/press, AFR, EGT) at low rate.
Trigger alarms and alert driver via Alarm light.
I have all of that with code working and logging data to a SDcard.
My latest upgrade was to be a 2.8 TFT Touchscreen, but I am having trouble getting it to work.
I also intend to experiment with a carbon fiber housing for my display when I am done.
If we agree on a common platform, we could coordiante some.
I chose the sparkfun arduino shields because I drive by their warehouse every day.
Do you have a link to the display you are using in the examples above?
Old 06-03-2014, 01:40 AM   #33
robot
I'm using the ebay varietal of this: http://www.adafruit.com/products/358
I'd love to incorporate your code for the LC-1. You are welcome to whatever I have on my Github repository. I'll warn you, it is messy and written by someone who decided to get a Cog Sci degree and not a CS degree.
Old 06-04-2014, 12:56 AM   #34
robot
The config file now looks like this:
Code:
#all of the config items for a page have to be kept in order or defaults might be use (at best)
#colorscheme use these colors -> yellow, red, green, black, blue, white, magenta
background:black
outline:red
fill:red
textdefault:blue
alert:white
#monitorlist - a list of sensors to monitor constantly and switch to if there are issues
#monitorlist:3
#sensor1:oiltemp
#sensor1pin:10
#sensor1alert:300
#sensor1:oiltemp
#sensor1pin:10
#sensor1alert:300
#sensor1:oiltemp
#sensor1pin:10
#sensor1alert:300
#pin config
#sensorName:pin
#legal sensor names:
#	oiltemp
#	oilpressure
#	boostpressure
#	temperature
#	accelx
#	accely
#	obdoiltempf
# 	obdoiltempc
#	obdbrzoiltempc
#	obdbrzoiltempf
#	obdspeedkph
#	obdspeedmph
#	obdvolts
#	obdcoolant
#	obdafr //not yet
#	obdmaf //in grams/sec
#	obdiat //in deg C
#	fake
#obd sensors don't have pins associated with them
#page (aka mode) config
#as many pages as you want...the sketch will flip through until EOF and start again
#each sensor is configured per page
#obd sensors don't have pin assignments after them
#page types:
#	twobar - two horizontal bar graphs with text
#	onebar - one horizontal bar graph with text
#	cross - cross chart for accelerometer
#	round - 1 round gauge for one sensor
#sensor*text can be about 8 chars long on the one sensor pages...a little longer on the others (due to font size)
#There is a "fake" sensor...give it a pin number that is the max value you want...allows for easy testing.
#a page called logging will log the given parameters and display the first 4 as plain text
#because of the way logging closes and opens a file...make sure logging is always the last page...
#pages after logging will be skipped
pagetype:twobar
sensor1:fake
sensor2:fake
sensor1pin:300
sensor2pin:100
sensor1text:Oil Temp
sensor2text:Water
sensor1max:300
sensor2max:100
sensor1alert:190
sensor2alert:0
sensor1units:F
sensor2units:F
pagetype:round
sensor1:fake
sensor1pin:300
sensor1text:Oil T
sensor1max:300
sensor1alert:190
sensor1units:F
pagetype:round
sensor1:fake
sensor1pin:250
sensor1text:Oil Pressure
sensor1max:250
sensor1alert:200
sensor1units:Psi
pagetype:onebar
sensor1:fake
sensor1pin:300
sensor1max:300
sensor1alert:250
sensor1units:F
pagetype:onebar
sensor1:fake
sensor1pin:21
sensor1text:Boost
sensor1max:21
sensor1alert:19
sensor1units:Psi
pagetype:round
sensor1:fake
sensor1pin:21
sensor1text:Boost
sensor1max:21
sensor1alert:20
sensor1units:Psi
pagetype:logging
sensor1:fake
sensor2:fake
sensor3:fake
sensor4:fake
sensor1pin:300
sensor2pin:200
sensor3pin:250
sensor4pin:100
Old 06-04-2014, 01:01 AM   #35
robot
My todo list includes:
-design and build accelerometer display
-clean up graphics
-buy sparkfun obd II device (And test and debug)
-decide if slowing down the animation of the displays is a good idea or not
-add peak displays
-write code to actually log to the sd card on the logging mode (I figure I'll set it up so if the user lingers on the logging page for more than 10 seconds it will start to log.)
-background all sensor check for warnings...then display and alert to those
I got button presses working for page turning tonight:
[ame="https://www.youtube.com/watch?v=JIIwZtxxgqY"]Modular arduino TFT gauge mode switching - YouTube[/ame]
Old 06-04-2014, 01:04 AM   #36
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Would there be a way to replace the clock by a tiny gauge ?
Sent from my SGH-I337M using Tapatalk
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 06-04-2014, 01:21 AM   #37
robot
Sure, I don't see why not. I mean with time and $ anything is possible
I bet that there is one circuit board back there that does the clock, the flashers, and the airbag lights. The hard part will be cutting the clock out without harming the other stuff. After that I think it's just a small area with some tinted plex/plastic and you could always put your own thing back there.
Old 06-04-2014, 07:01 AM   #38
mabviper
Drives: WRB BRZ
That was my primary choice for placement as well. I'm nowhere near your development progress though. It's still on an alpha build and I'm using STM32 micros. Hopeful before the end of the year, a prototype will be done. I'm still working on an improved shift light thing for the car.
Sent from my Nexus 4 using Tapatalk
mabviper is offline   Reply With Quote
Old 06-04-2014, 05:30 PM   #39
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
subd
do you have a diagram on how you wired this up to your arduino. Im not very experienced arduino, I have an uno but have barely used it. but I do know how to follow instructions and work with the code a bit.
marcoaferrer is offline   Reply With Quote
Old 06-04-2014, 05:47 PM   #40
robot
Originally Posted by marcoaferrer View Post
subd
Wiring is all in the source code for the arduino mega to the lcd (it uses high speed SPI).
Code:
//pin reference for tft from;
/*http://webshed.org/wiki/18tftbreakout
 eBay Board	 Adafruit Board	Arduino conections
 VCC	 VCC	 5V
 BKL	 LITE	 GND on eBay, 5V on Adafruit
 RESET	 RESET	 8
 RS	 D/C	 9
 MISO	 MISO	 12 (50 for mega)
 MOSI	 MOSI	 11 (51 for mega)
 SCLK	 SCLK	 13 (52 for mega)
 LCD CS	 TFT CS	 10 (53 for mega)
 SD CS	 CARD CS 4
 GND	 GND	 GND
The mega is weird because it uses different pins for SPI stuff than the standard arduino. I'm using a mega because I included so many libraries that the "sketch" got over the 32k size limitation. The mega uses a bigger chip. It also has multiple serial hookups, so that means you can do uart serial stuff to something like the obd II device at the same time you log to a serial console, which is handy.
Sensors go to whatever analog input on the board you configure them for. The OBD II thing I have yet to buy wires into a Serial connection on the board (the arduino mega has more than one...I have it set at Serial1 now). The obd thing I plan on buying shortly is this: https://www.sparkfun.com/products/9555
I also just realized I didn't put the github link up before: https://github.com/stirobot/arduinoModularTFTgauges
Also, last night I got some peaks displaying on the bar charts and I started spacing stuff out for the accelerometer display.
I also started looking into using acrylic to make cases...so I can put this in my car in a prototype sort of way. Something like this:
http://madlabindustries.com/shop/pro...lic-mega-case/
or this
http://www.instructables.com/id/Home...-LED-Displays/
I also updated the first post to make more sense.
Old 06-04-2014, 06:07 PM   #41
marcoaferrer
awesome man thanks for all the info.
If would be sick if we could get someone here on ft86 with a 3d printer to make a custom case
Old 06-04-2014, 06:16 PM   #42
mabviper
Drives: WRB BRZ
If you get stuck on the CANbus stuff, maybe I can help out.
EGT gauge SubBrZ Engine, Exhaust, Transmission 23 11-10-2015 09:31 PM
Gauge pod ikeryder13 Want-To-Buy Requests 4 03-30-2014 01:02 PM
WTB DCW gauge pod mikepaul21 Want-To-Buy Requests 1 03-26-2014 08:28 PM
FS DCW Gauge Pod whitefrs Interior Parts (Incl. Lighting) 7 03-26-2014 02:39 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
