Old 04-24-2014, 10:23 AM   #29
nadbrz
Learnin a little everyday
Drives: '13 Crystal Black Silica BRZ
Originally Posted by eric6 View Post
I add a full 3.5 ounces of 2-stroke oil (specifically Amsoil Saber) and the crickets went away. This works out to ~500:1 ratio with a full tank of gas.
I experimented 2-3 full fill ups with Amsoil saber 2-stroke oil and it works.
nadbrz is offline   Reply With Quote
Old 04-24-2014, 10:35 AM   #30
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
If youre chirping on the new pump, warranty it.
i have the revised pump, 5k ish on it now, no chirps. but as soon as it makes a peep, subaru is going to know about it.
you didnt pay tens of thousands of dollars to bandaid a problem in design.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 04-24-2014, 10:44 AM   #31
BRZJunkie
Drives: BRZ Sportech
So true!
Everybody shouldn't sit on it during warranty. Only repeated replacements can send the correct message.
BRZJunkie is offline   Reply With Quote
Old 04-24-2014, 12:23 PM   #32
Vmax911
Drives: WRB BRZ
How much are you adding?
Vmax911 is offline   Reply With Quote
Old 04-24-2014, 08:28 PM   #33
BRZnut
Drives: BRZ DGM Limited
Thumbs up
Yes it does!
Old 04-24-2014, 09:26 PM   #34
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
A full 3.5 oz bottle of the saber oil.
I have a few reasons for going about it the way I did:
1) It's because American gas is shit... yes the Japanese car company should have tested it on our gas but apparently they didn't?
2) I don't like technicians working on my car. I was a tech for 3 years, I know the kind of people employed at dealerships.
3) If a true fix came out, I'd replace it but so far all signs point to an ongoing issue that can't be remedied except with a very small bottle of additive.
Love the car and I'll be rockin' the $2.00 bottle of 2-stroke till she dies lol.
eric6 is offline   Reply With Quote
Old 04-24-2014, 09:35 PM   #35
Allch Chcar
Drives: N/A
Originally Posted by Mad1723 View Post
Actually, the top tier fuel requires additive, not ethanol last I checked =)
Sent from my Nexus 7 using Tapatalk
I just checked. Top tier is in fact required to use between 8 and 10% Ethanol.
http://www.toptiergas.com/deposit_control.html
1.3.1.2 Base Fuel. The base fuel shall conform to ASTM D 4814 and shall contain commercial fuel grade ethanol conforming to ASTM D 4806. All gasoline blend stocks used to formulate the base fuel shall be representative of normal U.S. refinery operations and shall be derived from conversion units downstream of distillation. Butanes and pentanes are allowed for vapor pressure adjustment. The use of chemical streams is prohibited. The base fuel shall have the following specific properties after the addition of ethanol:
1. Contain enough denatured ethanol such that the actual ethanol content is no less than 8.0 and no more than 10.0 volume percent.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 04-25-2014, 04:03 AM   #36
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Huh, interesting. Guess I missed that part. Thanks for the info!
Mad1723 is offline   Reply With Quote
Old 04-25-2014, 05:07 AM   #37
Muskokan
Drives: white Sport-tech
Yea I picked up some tcw3 last week, put in two cap fulls and no crickets for last two tanks. Found my additive!
Muskokan is offline   Reply With Quote
Old 04-28-2014, 04:13 PM   #38
nadbrz
3.5 ounces to a full tank of fuel.
Old 04-28-2014, 05:07 PM   #39
Boxer486
Drives: small
Probably the least harmful additive would be insulation.
Boxer486 is offline   Reply With Quote
Old 04-28-2014, 06:04 PM   #40
strat61caster
strat61caster's Avatar
Patience.
ineedyourdiddly
Old 04-28-2014, 06:28 PM   #41
winsometang
Drives: Scion F-RS 2013 Asphalt MT
i had crickets for the first couple months i had the car. just went away with time
winsometang is offline   Reply With Quote
Old 05-05-2017, 11:21 PM   #42
JMon85
JMon85's Avatar
Drives: 2019 WRX
Originally Posted by dannyboy8793 View Post
I use Lucas fuel injected cleaner and seems to work for me.
Yup same here! Also use Shell V-Power.
I tried Royal Purple's first, didn't eliminate the chirping.
JMon85 is offline   Reply With Quote
chirp, cricket fix, di pump
Tire smell harmful? eSOLOR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 01-27-2014 09:15 PM
Substantive Evidence K and N that harmful? BlackyRose Engine, Exhaust, Transmission 22 06-11-2013 03:27 PM
Local airport has 100 octane gas, would it be harmful to run? VesperLynn BRZ First-Gen (2012+) — General Topics 26 05-19-2013 09:02 AM
Myth about Fuel Additives Grishbok Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 09-20-2012 12:32 AM
Fuel Additives ArKiTeCkT Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 40 06-13-2012 03:26 AM
