Old 04-20-2014, 05:32 PM   #29
dirtymax
Gold Member
dirtymax's Avatar
Drives: 14' SWP BRZ MT limited
sequential turbos are pretty common on diesels because they can handle some serious air and dont have air/fuel ratios other than to much fuel. One problem other than tons of piping is getting the oil temp down. even triples turbos are getting more common, 2 into 1 setups
dirtymax is offline   Reply With Quote
Old 04-20-2014, 06:32 PM   #30
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
What about 2 turbos feeding 2 turbos... a double compound setup...talk about oil cooling?! You would probably have more piping and turbo displacement than actual engine displacement
Old 04-20-2014, 06:40 PM   #31
TwinturboCamry
Drives: 4 wheels
Why not tri-turbos?
TwinturboCamry is offline   Reply With Quote
Old 04-20-2014, 07:04 PM   #32
raven1231
Or a twin turbo Camry!
Old 04-20-2014, 07:34 PM   #33
wparsons
wparsons's Avatar
Why anyone would want to squeeze in two turbos on a small car when most cars that come with two turbos are trying to find a way to run singles is beyond me.
Supra, Skyline, S4, etc all make better power with a single turbo than two smaller turbos.
flickr
Old 04-20-2014, 07:41 PM   #34
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
Originally Posted by carlitosway6891 View Post
Thanks for the correction on sequential vs compound, my mistake but also to clarify, both turbos on a stock supra are different sizes, well, maybe depending on generation....I'm referring to the mk4
52mm/44mm (inducer/exducer)
58mm/39mm (inducer/exducer)
No both turbos are the same size on all MK4 Supras 1993-2002.
I think you are getting confused between the USDM (smaller CT12B turbos) and JDM (larger CT20A turbos).
The above sizing you have stated is USDM sizing. The first pair of numbers (52/44) is for the turbine wheel and the second pair of numbers (58/39mm) is for the compressor wheel.
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 04-20-2014, 09:24 PM   #35
dirtymax
Gold Member
dirtymax's Avatar
....http://www.duramaxdiesels.com/forum/...t=23550&page=9
The Following 2 Users Say Thank You to dirtymax For This Useful Post:
andrew20195 (04-24-2014), cdrazic93 (04-21-2014)
Old 04-20-2014, 09:32 PM   #36
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
I hate this thread.
Build Thread: Breaking-Bad SWP Build
OFFICIAL NM.FT86CLUB Facebook Page
mwjcyber is offline   Reply With Quote
The Following 2 Users Say Thank You to mwjcyber For This Useful Post:
Reaper (04-20-2014), Sellout (04-20-2014)
Old 04-20-2014, 09:49 PM   #37
dirtymax
Gold Member
dirtymax's Avatar
Originally Posted by mwjcyber View Post
I hate this thread.
why? because this thread has nothing to do with your tiny motor?
Old 04-20-2014, 10:02 PM   #38
D K
Stig's dark passenger
Originally Posted by Reaper View Post
You couldn't put big enough tires on this car to ever need a sequential.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Who was talking about NEEDING anything?
Single turbo is more than enough
D K is offline   Reply With Quote
Old 04-21-2014, 12:19 AM   #39
mwjcyber
mwjcyber's Avatar
Yeah.
But did enjoy looking at that crazy quad-turbo Duramax diesel setup you posted. Thx.
The Following User Says Thank You to mwjcyber For This Useful Post:
Old 04-21-2014, 12:53 AM   #40
dirtymax
Gold Member
dirtymax's Avatar
Yeah.
cool. I dig the crazy turbo setups some of the diesels have but realize one turbo is more than enough on our cars. to bad I live in California
Old 04-21-2014, 01:23 AM   #41
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Someone just needs to be crazy enough to try and plop 4 small turbos lower the CR a lot, so those turbos would do something...but at that stage you'd do it just do say you did it.
Old 04-21-2014, 04:21 AM   #42
Poodles
Drives: 2015 Series.Blue
Originally Posted by Sellout View Post
I've seen it claimed both ways, actually. I've never been able (never cared really) to get to the bottom of which models had which set of turbos, but it seems both Toyota and Mazda at different times used different turbos in some and identical turbos in some of their sequential set ups. Hashed that out about 10 years ago on the Supraforums...
Also: those measurements you listed are the measurements for the compressor and turbine wheels in the export spec (non-jdm) Supra, not two different turbos, just the two wheels in the CT12B turbo.
The vast majority of them have identical turbos, I've never actually seen one that didn't have identical turbos, only seen somebody's evidence that they existed way back then...
Yep, same size on both. Early twin turbo setups where parallel (1G-GTE, 1JZ-GTE) and one can make the stock twins on the 2JZ act the same way. Turbo tech has come a hell of a long way, so a twin setup isn't really needed unless it's for packaging reasons (usually on an engine that isn't inline). Probably the cheapest way I know to get much the same performance is with a quick spool valve (Sound Performance makes them) and a nice modern turbo.
Been done. People knock on the Camry, but the V6 model has always been a bit of a crazy sleeper. Got a beater one and it makes ricers cry
Not exactly. It's just cheaper to go single. It's been years since I've seen the car, but there was a rare twin setup for the MKIV Supra that make pretty crazy power and the torque band was pretty nice too. It's just a hell of a lot more work to get much the same goal (turbos aren't cheap, fitting all the piping, running all the lines, etc).
I've seen compound setups on Supras before. Never seen them really pushed to their limit though, was mostly done as a proof of concept.
Twin Turbo FR-S/BRZ? KidWonder Scion FR-S / Toyota 86 GT86 General Forum 44 06-27-2014 02:22 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
Twin Turbo BRZ xn7485 BRZ Photos, Videos, Wallpapers, Gallery Forum 10 08-23-2013 08:13 PM
Dealership twin turbo brz... BRZ283 BRZ First-Gen (2012+) — General Topics 23 06-03-2013 11:59 AM
Twin Turbo kit? enjoi23 Forced Induction 15 12-03-2012 08:53 PM
