Old 05-22-2012, 11:32 AM   #29
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Originally Posted by DanPO View Post
I hope Perrin comes out with a straight back (center exit) race pipe with dual tips (no muffler). You would obviously need a different rear lower fascia/valance (whatever it's called) to make the center single exit pipe look nice. Would be cool if there was a carbon fiber option on the rear lower fascia/valance. This setup without a muffler would save a ton of weight and be an aggressive option for track go-ers.
Prova has a center exit system available
We are working on the details with Prova Japan, however this will also include the new lower rear section as well for the bumper.
RallySport Direct is offline   Reply With Quote
Old 05-22-2012, 11:41 AM   #30
Scooby
Scooby's Avatar
Drives: Audi A5 Coupe
Wow, that is ehhhhh.... special
Scooby is offline   Reply With Quote
Old 05-22-2012, 11:57 AM   #31
Turbowned
Turbowned's Avatar
Love the Prova exhaust, HATE the diffuser.
Old 05-22-2012, 06:50 PM   #32
LivingLegend
Drives: 1994 Toyota Tercel
^I agree! I don't like how you can see the exhaust pipe from a distance...
LivingLegend is offline   Reply With Quote
Old 05-23-2012, 02:37 AM   #33
Gardus@Supersprint
Drives: Clio TCE
They could have fit just a mesh grill there, at least it would look like a race car.
Gardus@Supersprint is offline   Reply With Quote
Old 05-23-2012, 09:41 AM   #34
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Do any of these exhaust mods require ECU mods as well? I'm concerned that if I make a change it will screw something up.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 05-23-2012, 09:45 AM   #35
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
As long as the changes are after the last O2 sensor, you won't need a tune. Generally, a "Cat-back" exhaust is after the cats and therefore won't need to be tuned for.
Old 05-23-2012, 10:22 AM   #36
Gardus@Supersprint
Drives: Clio TCE
Agreed, also, if the reading of the post-cat O2 sensor is correct, regardless of what do you fit, you can leave the ECU alone. The auto-adaptive ability of the ECU will get the A/F ratio, spark advance etc right.
It's rare that a modern ECU of a NA engine is not able to compensate a full exhaust system.
You can have problem if the pre-cat O2 sensor position is very different, for example it happens when you fit a long tube header on a car which had short primary pipes and the original sensor plug very close to the engine. The delay of the reading of the sensor or the different wire lenght confuse the ECU. A good programmer can modify the target of the sensor or the delay of the reading.
This doesn't mean that a ECU remap can't improve the car, as there are also other characteristic of the management that are not subject to auto-adaptation, for example, throttle mapping, rev limiter, valve lift and timing if there is a variable system etc.
Old 05-23-2012, 03:03 PM   #37
PERRIN_Jeff
PERRIN_Jeff's Avatar
Drives: Matte Black STI
MAF based cars rarely have issues with any kind of bolt on exhaust pieces. The ECU sees more air flow and the car runs the proper air fuel ratio, so its perfectly. Proof of this is when someone dyno's an exhaust and shows the AFR curve before and after. Like this:
No, that is not the catback dyno results, just an example.
PERRIN_Jeff is offline   Reply With Quote
Old 05-23-2012, 03:26 PM   #38
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
I'm not a fan of the muffler and how the pipe is routed, but I wouldn't mind having the rear diffuser and fabricating my own center exit.
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
Old 05-23-2012, 04:45 PM   #39
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
Not a fan. Makes it look like the car has got it's junk all exposed.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 05-24-2012, 12:08 AM   #40
2fast4you
2fast4you's Avatar
Meh... the only people complaining about it will be crossing the finish line after I do.
Old 05-30-2012, 10:02 AM   #41
DanPO
DanPO's Avatar
Drives: Future BRZ owner
I don't like the Prova Muffler set up. I was thinking a race pipe option as well. My brother in law had his BRZ at a performance shop last week where they fabricated intake and various exhaust options... After each part was installed the first initial dyno showed great HP increase levels...(Then the bad news) the ECU quickly remapped everything to only show a 6HP increase with exhaust and intake set up. It appears you can't obtain extra horsepower out of this car without a proper tune.
So hopefully Perrin can come out with something in less than 6 months? Perrin - Have you seen the same results so far? Any thoughts?
DanPO is offline   Reply With Quote
Old 05-30-2012, 08:51 PM   #42
PERRIN_Jeff
For sure less than 6 months! A sneak peak for you.
Is there HP to be gained? Yes
The Following 2 Users Say Thank You to PERRIN_Jeff For This Useful Post:
ESBjiujitsu (05-30-2012), Subaruwrxfan (05-30-2012)
Stock Wheel Weight Dionysus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-01-2012 01:46 AM
Official JDM BRZ weight and MPG ayau BRZ First-Gen (2012+) — General Topics 50 02-08-2012 02:04 AM
weight loss cynic Scion FR-S / Toyota 86 GT86 General Forum 36 10-24-2011 04:04 AM
Weight of FT-86? Levi Engine, Exhaust, Transmission 38 06-14-2011 10:43 PM
FT-86 weight distribution? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 15 04-04-2011 10:58 AM
