Old 04-10-2014, 06:52 PM   #29
cortrain
Drives: Whiteout FRS
ST are fine for track, stiffer than most lowering springs. Plus they are linear, better feel and more predictable.
You don't need ridiculously stiff springs for the FRS/BRZ for track use. Most people who are lapping aren't experienced enough nor using sticky enough tires to run 8k+. Even from lowering springs to middle of the line coil overs showed very little improvement (minus, height adjustable, "stiffness" dampening) in lap times.
Arguing the semantics between the lower end brands is just that. It's opinion based on whomever bought them before you. Just find a spring rate that you'll be happy with for 90% of your driving and get it from a well known brand (not going to knock upcoming brands, just makes life less complex to use a tried and test option).
I bought ST's based on the company they are with (KW), they are valved very well, and use linear 4k/5k springs. In which in my research is more than fine for an entry level driver. Once I grow of of them and get more competitive Ill be upgrading to a higher level system along with tires, etc.
Just my opinion though
cortrain is offline   Reply With Quote
Old 05-21-2014, 08:32 PM   #30
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
I ended up going with ST. They are great in my book. Only had them on for a few days and haven't had time to dig into them yet. Great buy if anyone is still on the fence. Handling and comfort are great!
Thunderleg is offline   Reply With Quote
Old 04-27-2016, 04:31 PM   #31
Kendallkab
Drives: Black MT LMT BRZ
Originally Posted by FR-S Matt View Post
KW V3's. I lowered my rebound about 2 clicks all around on what Myles suggested on the forums here and I have a very very comfortable ride while max lowered. No wheel gap on 18X9.5 and rides better than stock.
I won't be getting rid of the V3's anytime soon. They're perfect for what I use it for and if I do a spirited drive, I'll just go up a few clicks on rebound and be set. Most people who own these never have any negatives about them. They simply upgrade to a track only setup which is completely different. The V3's balance street and track about as perfect as you can get.
What's the min and max drop on these coilovers?
Kendallkab is offline   Reply With Quote
Old 04-28-2016, 05:35 PM   #32
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
The FA500s with swift springs arent bad. But for the money I much prefered my stock struts on RCE yellows for the same type of driving you will be doing
Racecomp Engineering (04-29-2016)
Old 04-28-2016, 05:53 PM   #33
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
I'm on lowering springs and its fine for DD - I plan on going Koni Yellows Paired with my Springs.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 04-28-2016, 06:34 PM   #34
Apex-Apex
Apex-Apex's Avatar
JRZ RS Pro here and they feel pretty comfortable for daily driving.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
The Following User Says Thank You to Apex-Apex For This Useful Post:
Kristjan (04-29-2016)
Old 04-28-2016, 08:33 PM   #35
Vten
Drives: Too heavy
Tein street flex , all the way down , 4click all around from the stiffest setting , 18x9.5/10.5 w/225/40 and 235/30 stretch ....3.5' camber 0 toe all around , couldn't be happier .
Vten is offline   Reply With Quote
Old 04-28-2016, 09:11 PM   #36
Songha
Songha's Avatar
Drives: 2013 Scion FRS
I'm DD'ing with BC Racing Extreme Lows. 8k front and back. I have the rates at 8 click from softest in the front and 10 clips for the rear. Though I prefer my stiffness all the way up, this was a lot more comfortable for my girlfriend though is still stiffer than stock ride. The height adjustment is whatever the coilovers were pre-set to.
Songha is offline   Reply With Quote
Tow hooks on daily drivers... zooki Off-Topic Lounge [WARNING: NO POLITICS] 22 08-29-2013 04:47 PM
LakOfSpeed Daily Drivers III JohnAyySays Northern California 9 08-25-2013 01:34 PM
Daily drivers, do you swap street and track brake pads? qoncept Tracking / Autocross / HPDE / Drifting 31 06-26-2013 03:50 AM
So first time MT drivers (or been a while). hows your daily commute experience? chickdigger802 Scion FR-S / Toyota 86 GT86 General Forum 46 06-22-2013 03:24 AM
brief comment from tsuchiya san mokinbird87 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 16 01-08-2012 12:45 PM
