#29 | |
King of Kiwi Palace
Drives: Faster than you
Apparently having max torque at 2100 rpm is a thing. I guess people line up to race each other and slip the clutch out at 1,000 rpm, when the car starts moving they hit the gas and see who has more power from 1,000+ rpm to redline. Cause that's how people race. #sarcasm
#30 |
I would rather have more instant throttle response (shorter charge pipes, etc) than a ton of torque way down low.
#31 | |
King of Kiwi Palace
Someone make this, and ITBs.
#32 |
NASA SpecE30 Racer
Sounds like the new S55B30 in the M3/M4, but it is twin scroll as well.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#33 |
King of Kiwi Palace
I'm still not convinced the complexity/price is worth the gain for twin scroll.
#34 | |
Drives: small
Apparently the only thing people like the Fiat bomb in the back of the 4C is the massive torque available from 2100 on, at least till it falls off a cliff. |
#35 |
In an everyday car where people are using automatics and typically driving in the 2K-5K range having the faster spool is great and they demand the power down low. People hate turbo lag. BMW is also an OEM designing their own mass-produced manifolds and turbine housings. It's not like a single scroll setup is going to be a ton cheaper than a twin-scroll for them. In BMWs case I think they went to a twin scroll versus a twin-turbo setup, so it was cheaper for them to go with the twin-scroll single turbo.
In our case for the most part people are tacking a turbo onto a 12.5:1 NA motor which is way different. |
| The Following User Says Thank You to xwd For This Useful Post: | andrew20195 (04-16-2014) |
#36 |
Drives: '15 WRX '13 Legacy '07 Colorado
Cost and familiarity. Aftermarket vendors and shops need to keep cost down to maintain their profit margin on limited quantities. Sticking with what they know keeps cost down too. Realistically, the only major difference between single and twin scroll is the manifold. 4-2 instead of 4-2-1/4-1 and either dual or shared wastegate. After that, I'm sure tuning is more delicate building boost faster at lower rpm.
| The Following User Says Thank You to Mobius357 For This Useful Post: | Crawford Performance (04-06-2014) |
#37 | |
King of Kiwi Palace
Just because something is new and innovative doesn't make it end all be all, or that much better than everything else. You get more from retarding exhaust cam for spool than you get from twin setup, that's my point.
#38 | |
Drives: DGM BRZ Limited
Although I do believe that the supposed 240wtq at 2100rpm is a great attribute, I have to think that there is more at play here than simply using a twin-scroll housing/manifold setup. EVOs use a twinscroll factory, as well as countless other cars and none of them have those kind of results. NONE. Even with aftermarket tuning and modification. |
| The Following 2 Users Say Thank You to Coheed For This Useful Post: | Lee@JDLAutoDesign (04-07-2014), Rosticles (04-07-2014) |
#39 | |
Drives: small
#40 | |
King of Kiwi Palace
My point is that, if you have the money and don't give flying fuck, 1-5% better spool for 2k-4k more cost in research and development, go ahead. I can think of much better more efficient ways to get better spool. And if you think having power at 2100 is really worth something then you must be re-living the 80's when V8's had a 5k redline.
#41 | |
Drives: Corrado
#42 | |
| JDL 5130 Twin Scroll Turbo Kit | JDLAutoDesign | Forced Induction | 390 | 05-27-2021 01:14 AM |
| what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 03:36 PM |
| Centrifugal or Twin-scroll? What Ever You Choose FR SPORT Has it for Your ZN6 Car! | FRSport.com | Forced Induction | 0 | 09-27-2013 09:15 PM |
| Any Twin Scroll Kits? | Tiz | Forced Induction | 18 | 12-19-2012 08:43 PM |
| JDM Spec-C V9 Twin Scroll VF36 complete | Nico TURBO | Engine, Exhaust, Bolt-Ons | 0 | 12-05-2012 12:20 PM |
