#29 | |
RPM Engine Load KC Learned Knock Correction IAM Original post has more info. ![]() see logs here http://www.ft86club.com/forums/showp...6&postcount=26 They shows plenty of knock correction and KC Learned dropping |
#30 |
Codename: Stitch
hello my Australian bros,
I am wondering if the 98 RON tune you've worked out might also be helpful for those of us in California that are running the Stage 1 OFT tune on 91 AKI. I've definitely seen my IAM drop below 1.00 a few times and it would seem it's the same issue, just poor quality fuel with insufficient octane for the S1 OFT tune. If I'm understanding this right @steve99 what you've developed here is a tune that dials back the timing a little from the S1 OFT tune, to avoid the knock you guys are experiencing. If that's right then there should be little risk to try these adjustments over here right? At most maybe lose a little power if the timing reduction is a little too much, but typically somewhere between where the stock timing is and where the S1 OFT would be?
| The Following User Says Thank You to PMok For This Useful Post: | steve99 (03-31-2014) |
#31 | |
Drives: 86
i don't think there is any harm to try for you guys but you might not be able to load Steve's rom directly as he has a G type rom for Australia spec cars. |
| The Following User Says Thank You to Nardi330 For This Useful Post: | steve99 (03-31-2014) |
#32 | |
Drives: 86 GT MT
Thanks. Do I understand correctly? Data log and view later on the computer is the best way to monitor for knock. Is there any realtime data you look at on the OFT while driving? Last edited by keen as; 03-31-2014 at 02:22 AM. |
#33 | |
you need to log it and analyse as you need to know the RPM and Engine load where the knock occurrs and the serveity of the knock to know how much timing to pull. Remember you IAM will drop some time after the knock events so you need to log the actual events and also the kc learned for high rpm knock in general. |
| The Following User Says Thank You to steve99 For This Useful Post: | keen as (03-31-2014) |
#34 | |
Or just look where I pulled timing by comparing my ROM to the standard OFT G ROM stage 1 and adjust yours accordingly. As your fuel formulation is different you may have to pull timing in different areas or pull a bit more on 91 AKI fuel than I have done, but it would be are starting point if you log knock in similar areas of RPM and Engine load Its really best to log your knock events and pull timing where it knocks. Found if you see a -1.5 knock event pull about half that from table and it generally enough to fix it. Sometimes you need to pull a bit from the adjacent load/rpm cell as well as it was probably crossing through adjacent cell when knock occurs. The ECU appears to average the values across cells. Remember your going to loose the power anyway if the ECU is dialing back timing. If the ECU drops your IAM you have lost the timing over the entire RPM/load range until it comes back to 1 which may take quite a while if ever. The ECU is quite aggressive in dialing back timing when it sees knock, so if you adjust your map to reduce or eliminate the knock you will generally only have to pull about half the timing the ecu was going to pull anyway. Last edited by steve99; 03-31-2014 at 02:26 AM. |
#35 | |
Codename: Stitch
When I do get around to it I may have to post up and get some help with looking at the logs to determine/confirm where the knock is happening.
#36 |
Drives: 86
just flashed steve99's tune last night. have been taking it easy and IAM seems to be solid at 1 even i spent most time between 2000-4000rpm.
will drive it more this week then do logs on the weekend. looks promising so far. thanks @steve99. |
#37 | |
#38 | |
Drives: 86
thanks again. |
#39 |
Senior Addict
Drives: 86 GT
I've got a hfc on an aftermarket front pipe, and drop-in filter, but stock everything else (apart from OFT of course)....would this make my car run slightly leaner than yours hence more prone to knock? I haven't had time to log my IAM yet since the feature was enabled for us here, but I'm interested in what you've done and may try running your adjusted tune soon.
#40 | |
From what I have seen 86/brz's here knock on stock tunes more than on the OFT tunes. The exhaust mods you have are similar to nardi330's and I did notice from his logs he ran slightly leaner than my stock car on the stage 1 tune (it might just be his car ). It not going to make much difference, but just might need a bit more timing pulled , its just one of those things you will have to log and see. Some guys with high flow cat have been running the stage 2 tunes, but ask shiv about that. |
#41 |
Senior Addict
Drives: 86 GT
I just did a 30 minute log (on the drive to work) which included mostly metro/urban driving. I managed to put in a few low rpm high load, but since it was morning traffic I wasn't able to do any high rpm runs. For the most part the IAM stayed at 1, but then drops to 0.7 toward the end.
I've attached my chart below, not sure how useful it is to you guys, but hope it's good enough to get some feedback ![]() http://datazap.me/u/fizz/data-loggin...log=0&data=1-9 |
#42 | |
RPM Load 1600 0.8,0.9,1.0 2000 1.0,1.1,1.2 2200 1.0,1,1,1,2 2400 1.0,1.1,1.2 2600 1.0,1.1,1.2 2800 1.0,1.1,1.2 3200 1.0,1.1,1.2 Take out another -0.35 degrees at those load RPM points and see how it goes. If their was nothing taken out at those points already make it -0.7 degrees I don't think I pulled any at 1600. You look like you more aggressive on the accelerator pedal than me at low rpm seeing 50-70% sometimes below 3000, the knock occurs at throttle tip in. your long term fuel trims seem high -3 to -7 do you have intake/exhaust mods ? Last edited by steve99; 04-02-2014 at 12:08 AM. |
| Knock Correction vs Knock Correction Learn values? | swift996 | Software Tuning | 19 | 11-03-2015 11:09 PM |
| Dynosty Fuel System Upgrades- Billet Fuel Rails!!! | Dustin@Dynosty | Forced Induction | 4 | 10-08-2014 11:00 AM |
| FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. | MmmDieselFumes | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 02-02-2014 09:19 PM |
| Fuel gauge misreading actual fuel in tank. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 10-09-2013 04:39 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 05:53 PM |
