Old 03-03-2014, 11:20 AM   #29
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by Ironsquid View Post
We should just educate the population that reading a number on a forum and thinking it's 100% accurate is bad.
There we go
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Ironsquid (03-03-2014)
Old 03-04-2014, 12:43 PM   #30
jack43
jack43's Avatar
Drives: Sterling Silver BRZ Limited MT
Someone posted this chart for the twins on stock tires.
Looks like for 60-130 you start at about 5200rpm in 3rd.
And again from around mid 5000s that in 4th.
Then 5th hauls you over 100mph from around 6000rpm.
jack43 is offline   Reply With Quote
The Following User Says Thank You to jack43 For This Useful Post:
kbogarto (03-10-2014)
Old 03-04-2014, 12:53 PM   #31
CoupedUpSubie
Drives: 2013 BRZ Limited
The unit uses GPS, so it's flat foot from any speed under 60 for a 60-130 pull. Also the best way to do a pull like that is to near redline in each gear. Shifting at 5000 rpm will make times wicked slow. Probably never make it to 130 either.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 03-04-2014, 12:57 PM   #32
tendogy
Looking at that chart I'd vote for a 30-105mph pull, only using 4th gear.
tendogy is offline   Reply With Quote
Old 03-04-2014, 01:19 PM   #33
Ross
Drives: 85 corolla gts
These are typical speeds in say a roll race in a street / highway encounter, hell speeds get much higher very quickly. I do like this idea but anyone doing these test can at no point point any fingers for any trouble they get into as they are ultimately the ones that did it. In my area a typical 100mph pull above agreed starting mph is how a lot of the roll races go down. The only thing I am curious about for the turbo cars is break boosting, as I could see that scewing the readings some instead of just flat footing at the start mph. I have yet to use one of these things and am curious about this. I am sure those that have can confirm this info for me. I would also recommend keeping the speeds the same as what other platforms are using for the simple apple to apple comparisons as well see how it performs in comparison to other platforms.
Ross is offline   Reply With Quote
Old 03-04-2014, 02:35 PM   #34
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
I can't get over why these lists don't list weight.
raul is offline   Reply With Quote
Old 03-05-2014, 12:00 AM   #35
Boss Paco
Subaru Certified Sales
Boss Paco's Avatar
Drives: '13 BRZ Premium, '05 WRX STi
30-100. Start in second and run most of fourth out. And a running start is the right way.
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85
[Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s
[Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans
"The only thing that I trust in this world is cars!" - Don 'The Goods' Ready
Boss Paco is offline   Reply With Quote
Old 03-05-2014, 12:13 AM   #36
wrxgoose
WUB WUB
Drives: 2013 Firestorm
could we not also get the data via logging and doing a 30-105 run on a dyno, so we don't have to put anyone at risk?
wrxgoose is offline   Reply With Quote
Old 03-05-2014, 12:14 AM   #37
tendogy
I was actually just thinking on the way home today that a 30-100 run solely in fourth gear AND a 30-100 run however-you-want-to-do-it give a well-rounded picture. The 4th gear run would demonstrate the power band over the entire rev range, and the however-you-want-to-do-it would demonstrate the street acceleration potential.
Edit: wrxgoose, I think the idea is for vendors to do the runs in a closed and controlled environment, not for joes to do runs down the highway.
Old 03-05-2014, 12:18 AM   #38
spdbydesignchris
spdbydesignchris's Avatar
Drives: 2013 BRZ Premium
I think through top of 4th is probably best....for simple comparison purposes.
spdbydesignchris is offline   Reply With Quote
Old 03-05-2014, 12:35 AM   #39
wrxgoose
WUB WUB
ah. good point, Tend. Though if we had any abandoned runways around here, i'd gladly go for a run.
Old 03-05-2014, 01:07 AM   #40
Boss Paco
Boss Paco's Avatar
Street racing us a helluva drug!
The Following User Says Thank You to Boss Paco For This Useful Post:
DBW (05-21-2014)
Old 03-10-2014, 04:45 PM   #41
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Can I do all my runs down hill with a 20 MPH tailwind in sub zero temps?
The Following User Says Thank You to King Tut For This Useful Post:
liewyel (10-19-2014)
Old 03-10-2014, 07:51 PM   #42
JerryMichaels7
Drives: Whiteout FRS
no you live in FL...maybe if you were from canadad
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
BBK Fitment Database? F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 163 04-06-2023 01:55 AM
Valentine One and VBOX Sport **GIVEAWAY**! (FT86CLUB Exclusive) Massdrop Announcements, Contests, Giveaways 52 09-01-2013 11:16 PM
Dyno Database E92M3Guy Engine, Exhaust, Transmission 33 04-17-2013 11:20 AM
The *Official* BRZ Pre-Ordered Database Thread Zaku BRZ First-Gen (2012+) — General Topics 727 03-17-2013 08:29 AM
Racelogic PerformanceBox (VBOX) Group Buy! Visconti Groupbuys 2 08-04-2012 12:49 PM
